Rank: Wiz
Rating: 79%, 59 votes
Sounds like your keyboard is sticking
Unplug the keyboard and do the following
Look on the bottom you should see some screws, remove the screws and leaving the keys facing down, pop the two pieces apart.
Leaving the electronics aside you can now continue with the following instructions
Ok, once you have the two pieces, all of the keys should stay in there proper place, take and soak that in the sink with some soap and water.
Moving all the keys to get the water to flow through.
Then dry off the Keyboard and vacuum all the excess water off, then replace and screw back together, you should be good to go.
I wouldn't recommend a dishwasher, this could get to hot and melt the keys
Comments:
Apr 24, 2009
- then better open the keyboard, take a soft brush and clean everything.
