Question about Pride Mobility Products Pride Jazzy 600
Just replaced batteries in Jazzy 600 chair. Has on-board charger, when plugged in, meter rises to "6" then falls to zero.
  • 32 Answers
SOURCE: battery charger on board doesn't work. Replaced everything, stil
try replacing the battery fuse
Posted on Jul 13, 2009
  • 29 Answers
SOURCE: jazzy jet 3
Look in your owners manual for the flash code anwser. Make sure when you hit the power button you only touch it for 1 sec not more. If you press the power button for more the 2-3 seconds you place the power chair in LOCK OUT mode. lights will flash and not power. also check your free wheel levers. one on each moter. Mike
Posted on Sep 07, 2009
  • 103 Answers
SOURCE: Batteries won't charge w/ on board charging unit.
Since you have replaced the batteries and the charger there is most likely a problem with the wiring.
Posted on Nov 10, 2009
  • 692 Answers
SOURCE: I have a jazzy select 14 with an on board charger.
Mike since you know that the charger is not working you have two options purchase a new on-board charger or try to locate a good off-board charger from the area. A friend that has an extra charger or from a local provider that sells chairs. The off-board charger will plug into the charger port under the front of the joystick and will charge the batteries just as well. Just don't use the on-board charger but leave it in the chair. Hope this helps
Posted on Sep 20, 2010
SOURCE: Jazzy Quantum 600 power wheelchair - On the
THE WHEELCHAIR WILL ONLY TILT IT WILL NOT GO FORWARD OR BACKWARD USING THE JOYSTICK
Posted on Jul 14, 2011
How do I charge my battery I try with the charger and will not charge it
The user manual warns that if the batteries are discharged to nearly zero, the charger will not operate. So the batteries may require replacement. See p29
file:///C:/Users/Geoff/Downloads/US_Jazzy_600_om.pdf
Alternatively the charger may be faulty. In either case contect the distributor for the chair.
Nov 11, 2014 | Pride New Jazzy 600 Power Wheelchair by...
My jazzy 600 electric wheelchair won't stay on unless its plugged in
Replace the batteries. Your charger appears to be supplying the power to the chair and when you unplug the charger the batteries are not continuing the same amount of power and the chair will not stay on.
Jan 26, 2014 | Health & Beauty
My jazzy is used but i bought new batteries for it but the key pad will only cut on when the charger is attached. and wont cut on at all with out the charger.
super hmmm new batteries? well I would check the battery connections because you should be getting power to the joystick. The charger is providing power thru your joystick to be able to turn it on. Now when you plug in the charger are you getting any movement on the meter at the rear of the chair? If not but staying at zero then the charger is not charging the batteries and your batteries are not hooked up correctly. You will have to remove the seat and cover over the base to have access to the batteries check all the connections and make sure that if the plugs are colored that the red and white plug is plugged into the red and white plug going to the front of the chair and that the black and white plug is plugged into the black and white plug going to the front of the chair. If the wiring is ok then get a meter and read the voltage across each battery they should read 13+ volts fully charged. Plug in the charger and read the voltage at the batteries again if charging then you should read 16+ volts. If the voltage doesn't change then the charger isn't working correctly and if reading a good voltage then the batteries are bad and need to be replaced. Hope this helps
Apr 17, 2011 | Pride Jazzy Select 6 Indoor Power...
Replaced batteries in Jazzy 600 but they will not charge up.
doug then you could have received a bad battery or you have a charger problem or a charger circuit problem. If the chair comes on then the wiring is ok. when you plug the charger in do you have a green light and a yellow light on the charger? (when fully charged the light goes from yellow to green indicating full charge) If when you plug the charger in and you have a red and green light then there is a problem with the charging citcuit. I would contact your provider where you got the chair to have them check it out for you Hope this helps
Feb 19, 2011 | Pride New Jazzy 600 Power Wheelchair by...
I have a jazzy select 14 with an on board charger. The on board charger appears to not be functioning. What steps should I take to try and trouble shoot this myself. Im wondering if the circuit breaker has...
Sep 20, 2010 | Pride Mobility Products Jazzy Select 14
No lights on charger when connected to wall socket or chair
flobo I assume that its the on-board charger and that it is the gray charger with one light. This charger light will only come on when the chair is fully charged. Now if you have left it plugged in all night and still have no light then I would think you have a bad charger. If you have a digital voltmeter you can check the battery voltage throught the external charger port under the joystick. Set it on 200 volts and insert each probe into the outter pin holes and you should be able to read the voltage. Without the charger plugged in you will be reading the total battery voltage 24-27 volts with the charger plugged in 27-30 volts also check the meter with the charger plugged it should show something above zero and gradually decrease as the batteries become fully charged. Hope this helps
Sep 04, 2010 | Pride Jazzy 1103 Ultra Standard Power...
I have a jazzy power chair and when you turn it on all the lights come on for about 3 seconds then they go off and all you have is the red lights. we live in alaska so nobody around here to take it to
John Do the red lights blink or steady? this indication on the joystick usually means low batteries. Now this could be caused by bad batteries or a bad charger. On the jazzy if you have an on-board charger the light on the charger will come on green when the batteries are fully charged. If you can look under the rear of the chair you will see the charger and can tell if the light is green with the charger still plugged in after charging overnite. If the light is not lit then you probably have a bad charger. If you have a digital volt meter put it on dc volts 200 volt scale and plug the leads into the two outter charger port holes located under the front of the joystick. Your battery level should read 24-26 volts after charging all nite and with the charger plugged in up to 30 volts if there is no change in the voltage from charger plugged in and not plugged in then the charger is bad. You can then look to purchase an off-board charger that plugs into the joystick charger port to charge your batteries. If your battery readings are lower than 21 volts even after trying the new charger then you will have to replace the batteries. You might try to find someone in the local area that has an off-board charger you could borrow to see if you can get the batteries to charge. This will help you find out if the batteries need replacing. Hope this helps
Aug 25, 2010 | Pride Jazzy 1103 Ultra Standard Power...
When I replace my power chair jazzy 1100 batteries is it normal for the amp meter to start at 0?
The meter will not indicate anything until you have the charger plugged in and will move to zero when fully charged Hopes this helps you
Aug 24, 2010 | Pride Mobility Products Health & Beauty
How do I know when the chair has charged? I see one red, two green, two yellow lights on.
If you have an off-board charger that plugs into the joystick there are two lights on the charger one red(power on) and the other yellow (turns green when fully charged). Plug it into the chair and if the light is green then you have fully charged the batteries. Now if you have the on-board charger the charger meter on the rear of the chair will resd zero when fully charged. Hope this helps ya
Aug 18, 2010 | Electric Jazzy 1115 Power Wheelchair
Batteries won't charge w/ on board charger-+
sounds like blown fuse which is at rear of chair. may be underneath rear cover. this fuse wont keep the chair from working, however, it will keep the charging from working.
May 29, 2009 | Invacare Supply Group Invacare Pronto M91...
Pride Mobility Products Pride Jazzy 600 Logo
48 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
