Question about Home
Replacement glass shelving - Home
Where can I find a glass shelf 79cm width?
Call a glass shop and they should be able to steer you in thhe wright direction
May 04, 2014 | Furniture
Turned it off,Took out glass shelves to clean, now shelves won't slide back in!!
sounds like liner has expanded because it warmed up try turning it back on let it run overnight and try again
Nov 03, 2012 | U-Line 1175BEV Beverage Cooler
Replacement shelves
already checked but still is not cool how
Aug 29, 2012 | Frigidaire 3.1 Cu. Ft. Compact...
How to get glass out of shelves for cleaning
most shelves have the glass attached to the side brackets,, empty the shelf, and at the back of the fridge,, you'll see slotted rails that go top to bottom,, tap the shelf bracket upwards and it should come right out,, be careful,, once off the glass may come out too,,
Jun 13, 2011 | Refrigerators
Samsung Cooltech spare shelves available in b'lore??
it is possibly cheaper to go to a glass firm and get glass cut and edges polished to fit than it would be to buy replacement shelves.the mark up is horrendous on any spare parts......
Apr 20, 2010 | Samsung CoolTech Plus / Basic Bottom Mount...
Glass shelves stuck together when shipped. can't separate new glass shelves for installation in medicine cabinet. there wasn't any paper between the glass shelving when it was shipped. it is impossible to...
You could try soaking them in hot water and see if the warming of the glass will allow some water to seep between the shelves, thus separating them.
Please rate this answer for me. Thank you
Mar 22, 2010 | Home
Glass shelve on bottom over grisper is broken Sanyo SR-9510W
You didn't say what size or model Sanyo you have, but the solution is easy. I have a Sanyo under the counter refrigerator in which the glass over the crisper is 1/8" thick frosted glass, 16" by 6 3/4" with the two back corners cut off diagonally. The frosting is simply to prevent you seeing through into the crisper below. It is maybe fifteen minutes work with a piece of window glass and a glass cutter to make a replacement. My full size refrigerator uses 1/4" glass since it is much larger and I have replaced it myself this way. If you don't have a glass cutter -- they are cheap and available in all harware stores -- you should be able to get any hardware store to make the cuts for you. They are accustomed to making custom cuts for people replacing their own windows. The have, and I use, what is known as an oil cutter which is a lot easier to use than the little hardened steel wheel cutters you will get if you buy a cheap one. Those work fine for straight cuts. Oil cutters make curver cuts equally easy to do.
Dec 07, 2008 | Sanyo SR-9510W Refrigerator
Cleaning Glass shelves mold.
the shelves can be removed not taken apart. sorry they're glued together, just use a bristle brush and some bleach. no problem.
Mar 30, 2008 | Refrigerators
Home Logo
235 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
