Question about Rosetta Stone V3 Spanish (Latin America) Level 1 Personal Edition (Win/Mac) for PC, Mac (1580228542)
The language CD was not found to install. Please make sure your CD is in the drive
Hi i want to install the chinese,japanese and korean language!! but i dont have a xp cd... what should i do??
  1. Download the files needed to install the East Asian Languages here: http://www.4shared.com/file/HZ2CQc0I/east_asian_language.html
  2. Extract the I386 folder from the Zip file to a folder on your hard drive. Remember the location of this folder.
  3. Click on the Start menu, open Control Panel, then open Regional and Language Options.
  4. Select the Languages tab and under the Supplemental language support frame, check the the box next to "install support for East Asian languages".
  5. Click on Ok or Apply, then you'll receive a dialog box which says that "The following file ' - ' is missing.." and it also allows you to specify a directory where it should be found. Click on Browse and select the "I386" folder you extracted from the downloaded Zip file.
  6. After the files are installed, you must restart your computer.
Feb 26, 2011 | Computers & Internet
Tip
How To Install East Asian Language Support In XP Without XP CD
  1. First, check to see if you have the i386 folder on your hard drive. This folder will have the East Asian Language Support files that you need to install. The i386 folder can be found here: C:\WINDOWS\Driver Cache\i386 or here: C:\i386
  2. If you cannot find the i386 folder, you will need to obtain a copy of the Windows XP CD and copy the i386 folder to a USB thumb drive.
  5. Click on Ok or Apply, then you'll receive a dialog box which says that "The following file ' - ' is missing.." and it also allows you to specify a directory where it should be found. Click on Browse and select the "I386" folder on your hard drive or thumb drive.
on Feb 26, 2011 | Computers & Internet
Dell w5300 failed to install language monitor
You surely bought a new monitor. So you would have got a cd with the monitor. insert that cd into the disk drive and install the drivers.
If you don't have the cd then insert the cd you got with your (Motherboard CD)) Hope it helps.
Jul 16, 2010 | Dell W5300N Laser Printer
My AR-5316 dont work in network with computer i am using. it shows that "required user intervention" when i am printing cadd drawing.. what should i do?
Before starting the installation, make sure the USB or parallel interface cable is not
connected to the MFP.
Insert the supplied CD-ROM into your CD-ROM drive.
Double-click "My Computer" (
), and then double-click the
CD-ROM (
) icon.
When any of "Hardware Found", or "Found New Hardware Wizard"
messages appear during the software installation, be sure to click the
"Cancel" button.
Double-click the "setup" (
) icon.
If the language selection screen appears after you double click the
"setup" icon, select the language you wish to use and click the "Next"
button. (Normally, the correct language is selected automatically.)
Select the software packages to be
installed, and then click the "Next"
button.
The software packages with checkmark (
on the list on the screen will be installed.
Click the "Display README" button to show
the information on the selected package.
In Windows 95/NT 4.0, "Button
Manager" does not appear. In
Windows 98/Me/2000, do not select
the "Button Manager" checkbox.
because this is not supported when
using the parallel interface.
5
The next screen appears. Make sure that the parallel interface
cable is not connected, and click "OK".
Windows 95/NT 4.0 Windows 98/Me/2000
6
Check the contents of the package on the screen, and then
click the "Start" button.
The software packages to be installed will be displayed on the screen. If
inappropriate packages are displayed, click the "Back" button to select only
appropriate software packages.
28
7
Copying files for MFP driver installation and parallel interface
setup (This step will start if it was selected in step 4).
After confirming the message in the "Welcome" window, click the
Aug 06, 2009 | Sharp AR-5320 Black and White Copier
LG CD ROM not found it need toupdate the driver
your problem is very clear... your cd-rom is corrupted.. install new windows... NOTE-do this only if your cd drive is NOT displayed in my computer..
please vote for me...im sure this will solve your problem...
Jun 30, 2009 | LG CRN 8245B (CRN-8245B) Internal 24x...
Language on installing software CD's & internet is in Greek?
hmmm!..simply go to the control panel and here is language and region icon....just click it and change the language that you want ( in this case english)....It may want XP cd ..just put the cd and it automatically change your prefferd language
Mar 31, 2009 | Microsoft Windows XP Professional for PC
Install problem
It sounds like the Windows installations are missing the language-library file LATIN.LNG that the STEP module is trying to load in order to work.
First. see IF the file is on your HDD via DOS commands:
From START search-bar, type CMD then click the CMD icon.
At the command prompt, enter
CD\
dir/a/s/b'find/i "latin.lng"
sit back... this takes awhile....
You can also redirect output to a text-file with >X:\phoundit.txt
X:\ being replaced with the drive-letter of your flash-drive.
If not found on HDD, check your Windows OEM install disks 2C if the file exists there, maybe stored in a cabinet file named Languages or similar.
If all else fails, the Microsoft website may have a download version of the missing file.
Nov 20, 2017 | Parsons QuickVerse 7 Essentials (fe11044)...
Ubuntu Install Problem
i gav encountered this prob while i was helping my frnds install UBUNTU......then i found out they had low RAM.....but if ur patient n wait for a lil longer it does work on som comps.....its better u upgrade ur RAM....
Aug 12, 2008 | Canonical Ltd. Ubuntu
Language
Hi-
Try uninstalling and reinstalling the driver and that should default it back to english. keep me posted for any progress and pls rate solution if it helps. Thanks!
Jul 16, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Epson stylus dx7450
Windows uses a foreign language information file when installing a printer driver via USB. This then installs the associated foreign printer driver and utility files.
This can be corrected with a full uninstall of the printer driver. The standard uninstall will not remove the original foreign language files. Please follow the steps below to install the English version of the printer driver:
Step One:
Switch off and disconnect the printer. Go to Add/Remove Programs in Control Panel, and remove EPSON PRINTER SOFTWARE (this may be named in a foreign language like 'EPSON DRUCKER SOFTWARE' - when you are at this stage and have selected to 'change/remove' this item, a window will appear titled 'EPSON Printer Utility' - above the icons of each of your EPSON printers will be a 'Printer Model' tab and 'Utility' tab (Note, if there is no Utility Tab then just continue). Please click on one of the printers so it is highlighted, then select 'Utility' - please tick every box listed in the 'Utility' section and select 'OK'. Answer positively to all questions and once the uninstall is complete, you will need to follow the same procedure to remove the other EPSON printer drivers by clicking on 'EPSON PRINTER SOFTWARE' again and 'CHANGE/REMOVE'.
Step Two:
Open up Windows Explorer or My Computer, and navigate to the drive (usually C) where windows is installed. Browse to the folders called windows/inf on XP, or winnt/inf on 2000. If you can not locate the INF folder please go into the START MENU and select RUN. If there is any text within this box please remove and type C:\windows\inf and press enter. Please be advised that 'C' represents the hard drive on your PC. If your hard drive is a different letter please amend as necessary.
Find the files labelled OEMxx.inf or OEMxx, where xx is a number from 00, 01, 02 etc upwards. You will need to double click on each INF file in turn, and if it says “SEIKO EPSON” or “EPSON” within the first few lines, then you need to close the file, and then delete it. Please also can you delete the corresponding PNF. Repeat this until all EPSON INF files are removed.
Note: You cannot open a PNF file.
Step Three:
Staying in Explorer or My Computer, stay within the windows folder (winnt folder on 2000) and navigate to system32/spool/drivers, and go into the folder named "w32x86". Delete any folders that begin with "epson", and then restart. Once rebooted, empty the recycle bin, and attempt reinstallation of printer, using the instructions below.
Step Four:
MAKE SURE YOUR PRINTER IS STILL SWITCHED OFF AND DISCONNECTED AT THIS POINT. Insert your driver CD. Double Left Click on My Computer and select your CD drive by right clicking on the CD icon and select open. When you first open/browse the CD-Rom then you should see various folders. Please browse to the Common Folder. Within here select the Printer Driver Folder then choose the WinVISTA/XP_2k folder. Run the Setup.exe file and complete the installation as normal making sure you only connect the printer when requested to do so.
Step Five:
Once this has completed installing, please remove the CD from the CD drive and reboot the PC. The foreign language tabs will now appear in English.
Mar 16, 2008 | Office Equipment & Supplies
Rosetta Stone V3 Spanish (Latin America) Level 1 Personal Edition (Win/Mac) for PC, Mac (1580228542) Logo
198 people viewed this question
Top Rosetta Stone Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Jax Planet
Jax Planet
IT GURUS OF ATLANTA
IT GURUS OF ATLANTA
Are you a Rosetta Stone Computer and Internet Expert? Answer questions, earn points and help others
