Question about Texas Instruments TI-30 XIIS Calculator
How to turn on the third function for factorial
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
Press PRB right-arrow right-arrow
Posted on Jun 01, 2014
Tip
How to reset your Eee pc to factory settings (just like it came out of the...
How to reset your Eee pc to factory settings (just like it came out of the box)
  • Turn on your Eee pc
  • Continuously press F9 until a screen comes up with three options.
  • The third will be 'reset to factory settings.
  • This will delete all data and reset your eee pc.
  • Press down until it is highlighted then press enter.
  • It will tell you what it is about to do and ask you to type yes to continue.
  • Type in yes - no capital letters
  • It will reset your Eee pc and ask you to press enter to reboot.
Your eee pc will then reboot and ask you for a name and password and all that stuff it asked you to do when you got it.
on Jul 14, 2008 | ASUS Eee PC 4G Surf
How do you deactivate demo mode on the buglit?
Demo(factory) mode is deactivated by holding the switch on for approximately 20 seconds, until light flashes and goes out.
Normal function is press once for high, a second quick press for low, a third press for strobe.
Sep 03, 2014 | Nite Ize BugLit LED Micro Flashlight Red
How to update older ti-84 plus
The function keys originally have twp functions: One function accessed by pressing a function key directly, the other by first pressing the 2nd key then the function key.
With the newer operating systems, there is a third function associated with the function keys F1.F2,F3 and F4, but not F5 nor F6. This third function is revealed after you press the ALPHA key.
Jul 25, 2012 | Texas Instruments TI-84 Plus Calculator
Phone not working
hrm... this is an odd one, you may need to back up all your settings and contacts to your sd card and restore your phone to factory default. It may be the only way to fix the home key functionality. there is also a master reset which can be done following these instructions:
  1. Turn the power off. If your Samsung Galaxy S is frozen, pull the battery out and reinsert it
  2. Hold the Volume Down button
  3. Press and release the Power button
  4. You are now presented with a menu that allows for Fastbook, Recovery, Clear Storage, and Simlock
  5. Select Clear Storage by pressing the Volume Down button
  6. Press and release the Power button
  7. Now simply confirm your decision: Volume Up for YES and Volume Down for NO
If you selected YES, all data including third-party applications will be deleted from the Samsung Galaxy S. Once the wipe is complete, the phone will reboot to its factory fresh state.
Jan 26, 2012 | Samsung Galaxy S GTI9000 Smartphone
How do i calculate combinations
Your calculator has three keys, next to which are the following markings:n! , nCr, and nPr. The one with the exclamation point is for factorials. The second is for combinations, and the third with permutations.
Syntax of the command.
If the markings are on the keys, the functions are accessed directly. If the markings are on the body of the calculator, you access the functions by pressing SHIFT and the key.
12 [!] gives 12 factorial
12 [nCr] 4 gives the combinations of 12 objects taken 4 at a time (order not important)
12 [nPr] 4 gives the permutations of 12 objects taken 4 at a time (order is important.)
Jun 09, 2011 | Texas Instruments TI-30XA Calculator
I dont know how to turn camera on
Q: Camera Usage Instructions
A:
For use with systems including an Acer Orbicam, CrystalEye, or other factory installed camera.
Taking still pictures
  1. Double click the Orbicam Icon to start the program, which will open the main application screen.
  2. Set the configuration choices by clicking on the "gears" icon, which should open an additional window that slides out. Clickthe tabs and select the options for the desired settings. By default, still pictures will be sent to the "Pictures" folder.
  3. Set the resolution for still pictures by pressing the arrow under the main display. A drop down menu should appear with the available resolutions. Larger resolutions will result in larger file sizes.
  4. To take a picture, align the subject in front of the camera so that the display appears in the window as desired. Click Take Photo.
  5. The pictures should appear along the bottom of the application window if the Gallery view is enabled.
Recording video
  1. It is suggested to find a third party application to use this functionality.
Using the camera as a webcam
We cannot support third party application configuration or use.
Feb 18, 2010 | Acer Aspire 5315 15.4-inch Notebook PC
I have a TI-30XS and I can't figure out how to do factorial problems
Press the prb key. You are offered two menu options PRB and RAND. The factorial function is the third choice under the PRB menu.
Exemple. Calculate Factorial 4.
4 then prb key, then 3 , then ENTER key. Screen should show 4! and the result is 24.
Hope it helps.
Nov 03, 2009 | Texas Instruments Office Equipment &...
Reinstall factory settings using Functions keys on a Dell
Turn off the system.
Turn on and press Ctrl+F11 immediately. It will take you to the DELL Complete PC restore which will help you restore to factory settings.
Sep 06, 2009 | Dell Inspiron 700M Notebook
Texas Instruments TI-30 XIIS Calculator Logo
12 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
