Question about Canon NP 6545 Copier
E002 error - Canon NP 6545 Copier
  • Canon Expert
  • 228 Answers
Symptom
E000/002/003/261/733 may occur when connecting the machine with power source having much noise, such
as a private power generator
<Cause>
The power line noise prevents the normal operation of zero cross signals, causing poor control of power supply
to the fixing heater.
<Factory Measures>
New type of switching regulator PCB is used to decrease the effect of power line noise.
try to change Switching Regulator PCB (FH3-2614-020 ) ..old-FH3-2614-000
Check version of system software
iR3300 Ver.11.01
1)Countermeasure for E002
2)Modification of the temperature adjustment control for free
size paper
3)Multi-purpose tray for B6 size (out of specification)
supported
4)Modification of the problem for the service mode
(REGIST) performance
5)Modification of the problem for the service mode (TRYSTP)
performance
Posted on Oct 15, 2013
Sir you tell me how can I reset canon ir 2002n error code e002-0000
Hello . to clear that error you need to replace the fixing heater unit
Apr 25, 2016 | Canon Office Equipment & Supplies
Error code E002
I googled: canon imagerunner 2022 copier error code e002
This appears to be the best and most informative: http://www.fortwayneprinterrepair.com/wordpress/2014/08/12/canon-ir-2200-2800-reset-fuser-error/
If not, try some of the others from the above search.
May 07, 2015 | Canon Image Runner 2022 Copier
Error e002 slendertone flex belt
Dear Karen! I have the same problem white my slendertone e002 error,if you deal whit it,please helm me!
Oct 24, 2012 | Slendertone Abdominal Muscle Toner
My machine is canon NP3050 type F127500 and the problem is that, when you start up the machine, the screan show error code E002 please what can i do?
E002 is a clasic Fuser error
"E002Fuser temperature too low"
Turn OFF and ON the machine, if that dosent help you need to replace the Fuser Unit.
May 25, 2012 | Canon Office Equipment & Supplies
My Sony Walkman nw-e002 is showing an error "Format error"
It is caused by the music file you are trying to play. Play it on the computer to see if it works, then check the properties see if it meets the nw-e002's spec. If it does, your file maybe corrupted
Feb 20, 2011 | Sony NW-E002 MP3 Player
I have canon ir400 machine... it displayed error codes e002.. what i do? plz help me....
If the fuser assy has been repaired and you keep experiancing an E002 the problem is most likely a faulty DC Controller (main board) The DC Controller handles the voltage applied to the fuser assy and gives the error code E002 or E003. Have your tech clean & reseat connectors on the DC Controller before just replacing it. I have found cleaning the connectors & reseating them solves the problem 75% of the time.
Jan 12, 2011 | Canon imageRUNNER 400S Copier
Code error E002 for Canon NP6030
hi 1. cheq the fuser heater lamp & thermal fuse,
2. enter in the sim mod by pressing service swich located in side the front cove you can see the $ sing at the screen left upper corner then press *4* then scroll to find the error then ok macine will re start and hope your error will go
thanks
May 13, 2010 | Office Equipment & Supplies
Cannon MF8180c - E002
Go to this link. Type "error E002" in the search window and click Search. Select the System Error E002 link and you will see some things to try to resolve the problem. If it persists, you may need to have the unit serviced.
May 22, 2008 | Canon imageCLASS MF8180C All-In-One Laser...
Canon NP-6035 persistent E002
e002 error normally indicates that the heater {fuser} is off
to clear that in most canon models there is a small press switch is to be activated to reset the error
at the rear right side of machine there is a small cover take it out and look for that small black button, press it while or immediately after switching the machine ON , switch OFF and ON again
if the error still exist may a real damage in fuser e.g. blown thermo fuse or lamp
Jan 25, 2008 | Office Equipment & Supplies
Canon NP 6545 Copier Logo
71 people viewed this question
old marine
old marine
