Question about AT&T Cell Phones
Backlight keypad how to turn the backlight on in a at&t smartphone
No backlight or key pad light nokia e71
There is a light sensor in your Nokia E71
This light sensor senses the outside light and activates the keypad light accordingly.
When you have enough backround light the keypad light wont light up.If the background light is less then the keypad light wil light up.
You dont get the keypad light ON because the light sensor might have activated.
If in dark also you wont get the keypad light on then the fault lies with the keypad light unit.please give your mobile to the nearest authorised service centre for service.
Thanx
Jul 26, 2010 | Nokia E71 Smartphone
How do you get the keyboard lights to stay on? They come on and off at will.
For you to extend your keyboard lightening time, please do this;
1. Click on the Home button > Options > Screen/Keyboard > Scroll to Backlight Timeout increase to the highest probably 2minutes. This should should keep your backlight on for as long as 2 minutes before it goes off.
This should do.
Regards
Jan 25, 2010 | RIM BlackBerry Bold 9700 Smartphone
Keyboard backlight not working
try resetting or reformatting the phone...if that does not work it may need to be checked by a technican.
Jan 02, 2010 | AT&T Blackberry Curve 8300 Smartphone
Is there a way to turn off the keyboard lights. It is nearly impossible to see the letters when the lights are on.
I went to Settings/Display/Backlight Timer/Display & Keypad then selected off.
You can see the keys on the keypad a lot better with the backlight off.
Nov 19, 2009 | LG Neon GT365 Cell Phone
Backlights (LCD or keypad) not working on brand new handsets
Could they be turned off by default? Find out how to get to the menu and check this out.
Sep 25, 2009 | Vtech CS62192 Cordless Phone
Is there any way of turning on the backlight on the numeric keypad on the u600?
From your main menu go into "Settings". Select.
Scroll down to number 5 "Light settings. Select.
Scroll down to number 3 "Keypad light". Select.
It will probably be set to "Night time" 05:00 PM.
Use your direction pad to change it to "Any time" Save.
The keypad backlight will be on all the time.
Aug 17, 2009 | Samsung SGH-U600 Cellular Phone
Motorola Razr V3a Backlight Stays On
From the manual, p. 31:
"BACKLIGHT
Set the amount of time that the display and
keypad backlights stay on, or turn off backlights
to extend battery life.
Find it: (on menu) > Settings > Initial Setup > Backlight"
Jun 22, 2009 | Motorola Mobility RAZR V3
The wired keyboard backlight turnes off too quickly
You would need to go into the Setting Menu and find the Backlight or Power setting to lengthen the display and keypad backlight times. Just know that your battery life will decrease the higher the settings especially since it is a VGA screen.
Dec 18, 2008 | HTC Touch Pro Smartphone
Keypad backlight function turns off when call is connected
Plain and simple there is something wrong with the LCD on your phone, needs to be repaired if possible
Mar 13, 2008 | Samsung SCH-u740 Cellular Phone
Cell Phones Logo
13 people viewed this question
Top AT&T Cell Phones Experts
William Alequin
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
