My oki c330dn printer says filter failed when i try to print
4 Suggested Answers
flopez
  • 161 Answers
SOURCE: Paper Jam in OKI B4300 Led Printer
This printer is designed with a dual toner/drum chamber. Do not separate these two parts. Upon opening the lid, you will find the toner/drum assembly right in front of you. Pick it up with both hands and pull straight up. After that, you should be able to take the jammed papers. Know this: once a paper is jammed, printing another paper will NEVER take the first out. Just make sure to remove the complete papers. If they break, make sure you extract all the pieces.
Posted on Sep 22, 2007
SOURCE: printing index cards on oki printer
i changed the settings on media to rough paper & made sure all paper was to come from mp tray, but it does jam frequently, and every time it does, i need to open & re-open the front cover to get it to clear the error that appears. the error reads mismatched paper size, as there is not a custom size of small index cards of 3.5 x 5.
Posted on Mar 07, 2008
SOURCE: I have a OKI B2500 Series. When Print Says Printer Error FuserTem
If you have not fixed this by now, I have the fix.
Turn the printer on, hit the following keys on your printer:
down arrow, *, #, ok, 1, ok
After that, hit the down arrow until you see T>Printer and then hit ok.
Next turn off the printer, count to 5, and then turn back on.
Repeat the first step, but in place of the number one, insert the number 0.
These were the steps given to me by the oki customer service and it fixed my printer. If you have problems, the number is 800-654-3282.
Posted on Nov 11, 2009
OKI C330dn Call Service fatal Error:980
That particular error indicates a fuser failure. Try turning off the printer and re-seating the fuser. If this does not clear the message then the fuser needs to be replaced. With such a low number of prints warranty should cover it.
Aug 29, 2014 | Oki Electric Industry C330dn Led Card...
Okidata printer c330dn copies have black smudged edge on the right
your drum cylinder (opc) or dev roller needs to be replaced
Aug 05, 2014 | OKI C Office Equipment & Supplies
My Okidata C330dn has a "Service Call 991:Error" code. How do I resolve this without a service call?
probably one of colour cartridges (usually not original from OKI) is updetting the printers logic Swap they around (even if you have to use old cartridges), find offending one and replace.
Simple.
Sep 29, 2013 | OKI C Office Equipment & Supplies
Memory overflow
try printing a different file format. is teh printer connmected via network or USB? connect either way and see
Apr 09, 2013 | Oki Brand Oki 62435103 C330dn Laser...
Filter failed
Go to "IP" in the add printer section. It is a "globe" at the top of the page. In address put the address of your printer there and name the printer at the bottom. Worked for me.
Aug 27, 2012 | Oki Electric Industry Oki C9650hdn 512mb...
Service Call 069: Error
My printer (Oki C330dn) experienced a hardware issue that placed it in a mode where it displays a 'Service Call 069: Error' on startup after the hardware problem was corrected. I used the following button combination at startup, which corrected my issue. Press and hold the BACK, DOWN ARROW, and OK buttons and power-on the unit. Continue to hold the buttons until you see RAM CHECK and some asterisks then release. This forces the unit to ignore all warnings and errors while placing it in an online mode. My printer came up to a ready state and worked normally. The next time I turned it on, it started up without any errors.
Aug 17, 2012 | Cisco Oki C330Dn Led Printer - Color -...
Setting up an OKI printer on an IMAC
Without mac drivers you do have a problem. Put it on ebay and get another printer that supports mac and windows.
May 12, 2009 | Apple MacBook Pro Laptop Computer with...
27 people viewed this question
jasbo
jasbo
