Question about GE Deluxe 30" Convertible Range Hood - Stainless-Steel
Replacing GE Profile range hood light switch - GE Deluxe 30" Convertible Range Hood - Stainless-Steel
ngafm
  • 166 Answers
SOURCE: GE Profile gas range
hello dreeden5
Ngafm at your service,
You have a GE Profile oven range. I and you just cleaned it and the pilot light on all four burners continues to click on and off.
It sounds like the gas line or the gas valve, have some debris in them!
They need to be evacuated by an experienced tech.
This time you need service.
Bless You ngafm
Please give me a good rating at this sight before you leave!
Thank You
Posted on Sep 11, 2008
docjohn174
  • 943 Answers
SOURCE: GE Profile Gas Range Igniters working but gas takes a while to start flowing
HI thanks for your question. the igniter is the cause for this problem. the heat from the glow bar is just not hot enough to ignite the gas. i would replace the igniter. thanks
Posted on Oct 14, 2008
  • 291 Answers
SOURCE: GE Profile Gas Range oven light doesn't work even after changing
  1. After self cleaning the range the door won't open
  2. Amana gas range conversion from NG to propane
  3. A tip on cleaning the surface grates
  4. Checking an common oven temp sensor
  5. Checking an common oven temp sensor: What does an oven temp sensor look like?
  6. Gas range repair aid - such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
  7. GE gas range conversion from NG to propane
  8. How to change the oven temp on some common electronic controlled ovens
  9. How to re-light a surface or oven pilot light
  10. How to change a common oven glow igniter coil
  11. How a common gas valve works - click here.
  12. How Ranges, Ovens, and Stoves Work
  13. Help for storing an appliance
  14. Important Disclaimer
  15. Installing a gas flex line connector
  16. Maytag, (some) Magic Chef, (some) Jenn-Air gas range surface spark module - new module kit
  17. Maytag ( Magic Chef - Crosley - Jenn Air ) gas range conversion NG to propane
  18. My gas range flames die when I turn on more than one thing at a time
  19. My Range is flashing an " F1 F2 F3 F4 F5 F7 F9 " something, what does this mean?
  20. My surface burners keep "clicking" even after the burner is light
  21. Oven door and door hinge help
  22. Oven temp sensor - how to change helps
  23. Repair tips and information on surface burner spark modules and igniters
  24. Some "how to set the self clean" on my range
  25. Stainless Steel Cleaning
  26. Surface burners wont work
  27. This morning I noticed the range top ignition was clicking all by itself every 15-30 seconds
  28. Test for F1 fault code
  29. WCI - Frigidaire ( some Kenmore's ) gas range conversion from NG to propane
  30. WCI - Frigidaire /open burners/ (some Kenmore's) gas
  31. Whirlpool Direct Spark Ignition (DSI)
  32. Yes, your glow bar igniter can glow red and still be bad!!
Posted on Apr 01, 2009
SOURCE: ge profile range door wont close
My GE Oven door won't close all the way. I just bought the house so i do not know what caused the problem. Please help
Posted on Sep 03, 2009
roger_bri797
  • 23 Answers
SOURCE: My GE Profile fan switch is inoperable. Can I get
Go to apd.com....Appliance Parts Depot...
Posted on Oct 05, 2009
How do I light a pilot light on a GE profile oven?
Modern ovens, especially Profile top-of-the-GE-line don;'t usually have pilot lights. Light with electric element when thermostat is good.
Aug 26, 2014 | GE Profile Spectra JGBP90 Gas Kitchen...
Doesn't turn on - dead Motor or switch???
Could be either...
the way to tell is to check for power at the motor...no power switch is bad... power there then the motor is bad...
heatman101
Jan 11, 2011 | GE Profile JVB37H Kitchen Hood
Hood Light Problem
This is a light socket problem, and it has plagued hoods for years simply because grease builds up there and is acidic. One fix is to disconnect the power and wash the socket with alcohol, then buff with steel wool being careful to leave no steel wool behind. After cleaning you will need to re-tension the little aluminum/brass button at the bottom of the socket by placing a screwdriver under it and gently lifting it about 30 degrees upwards. Replace the bulbs with ONLY the stated wattage bulbs indicated on the panel.
Mar 05, 2010 | GE Profile Designer JV936DSS Stainless...
Lower oven burner will not light.
Hi I have a older GE that the oven won't light. It is a gas range that is electric ignited. The top burners do work but the oven will not light. Is it pricey to have this fixed?
May 28, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge downdraft vent
try removing the switch from the ribbon connector, and then jumping the two pins momentarily with a screwdriver blade or other metallic tool. It could be that the switch itself is bad. This is the same problem I'm having and I am currently looking for a replacement switch online.
Jan 23, 2009 | GE Profile JVB67 36" Telescopic Downdraft...
I have a ge profile gas range and the burners are making a constant clicking noise and spark. The only way to stop it is by either unplugging it or turning the power off to it
Under each gas control is a switch that will turn on the spark module when rotated to the light position. One or more of these switches has failed. Some models these switches are individually replaceable, others the switch is an assembly of all four.
Jun 15, 2008 | Whirlpool SF368WWH Gas Kitchen Range
How to replace up/down switch in downdraft vent for cooktop
Does any body know where I can get the schematic for the PC Board P/N 959-0138-003 by ACT, Inc.?
Thank you.
Jul 27, 2007 | GE Profile JVB67H Kitchen Hood
GE Deluxe 30" Convertible Range Hood - Stainless-Steel Logo
47 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
