Question about Haier RDE350AW Dryer
How to readjust pulley tension on haier dryer
Haier 6.5 current ft dryer, how do you put the belt on after it came off?
if its still wrapped around the drum an drum turns with it fine .. see the white idler belt goes on bottom then around the motor idler.
take the right side of belt an pull it around motor an down an under the idler .
Oct 12, 2014 | Dryers
Haier dryer RDE/RDG 350AW
Replace the drive belt must have slipped off maybe loose from use.
It does say in manual to store and move in an upright position.
Sorry don't have a reapir manual but crack it open, and either fix the belt if it has slipped off its tension pulley or you will need to replace the belt just did my LG dryer last weekend a 4 out of 10 difficulty,,,about 1and half job....belt costy me $25.00 hope this helps some.
Jul 23, 2014 | Haier Dryers
REPLACING THE DRUM BELT
Belt should go around entire drum then around motor pulley (which is metal) and tensioner/safety pulley (which is the white pulley)
Apr 17, 2014 | Haier HLP140E Electric Portable Dryer
NEED TO PUT THE DRUM BELT BACK ON ASAP
The other pulley is spring loaded it puts tension on the belt.
Pull the pulley back and the belt will slip ight over then release the tension pulley and your done!
Is the idler pulley what sets the tension on the serpentine belt
yes and that's how you change the belt also. just turn it with a wrench to loosen it if you want to change the belt.
Dec 18, 2009 | 1996 Dodge Caravan
How to change a belt on a 1995 Buick Century
A listing of serpentine belt diagrams can be found HERE. It will show you the location of the tensioner pulley, which must be loosened in order to remove and install the new belt. When the new belt is on, just readjust the tension via the tensioner pulley.
Oct 07, 2009 | 1995 Buick Century
Belt installation for a maytag dryer model# sde305day
Usally put dryer belt around the drum first
then around motor the tensioner pulley has to to be pulled up when you do this to get the belt around tensioner then you release the tensioner pulley to put tension on belt
Jun 18, 2009 | Maytag PYE2300AY Electric Dryer
Change a belt?
Replacing the belt is not that hard.
  1. You have to take the back of the dryer off.
  2. Then lift the tension arm on the motor releasing the pressure on the belt.
  3. Inspect the tension pulley, checking the bearings on the pulley.
  4. Wrap the new belt around the drum, and wrap it around the tension pulley, lifting the tension pulley to adjust the belt.
  5. Reinstall the back of the dryer.
Please rate this solution
Aug 03, 2008 | Whirlpool LEQ9858P Electric Dryer
Belt tension
there is a spring-loaded belt tensioner pulley. make sure it is part of the belt loop. you will need to move the tensioner pulley against the spring force then place belt on tensioner pulley and then release the tensioner pulley and belt will now be tight.
Sep 12, 2007 | GE DLSR483EE Electric Dryer
Haier RDE350AW Dryer Logo
Top Haier Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Haier Dryer Expert? Answer questions, earn points and help others
