Question about Whirlpool LBR4132JQ Top Load Washer
Used the soak feature in washer, will not drain or turn
The washer filled and soaked items on soak feature, now will not do anything. Can not drain, spin, not working in any area
  • 43 Answers
Check your motor coupler.
Posted on Apr 25, 2009
My GE spacemaker top loading washer GUD27ESSJ0WW won't drain.
Most likely the drain pump is plugged with a soak or other small item.
Jun 19, 2017 | GE Washing Machines
Washer fills with water when not in use. Doesn't completely drain and spin cloths, and I get an E10 error code
Hello Lahoma, thank you for your post!
I understand that your Frigidaire washer fills with water, will not drain completely, and is flashing an "E10" error code. The error code stands for your washer fill time is too long. This could be an issue with your water valve, main control, or water pressure. You should check to make sure that your water flow is normal and that your water line is not restricted. This could cause an issue with the way water is distributed within your washer. The water pressure coming into your washer should be at 30 PSI. You can also clear out any false error codes by performing a reset on your washer. In order to reset your washer you need to disconnect power from it for roughly ten minutes. If this does not help resolve your issue I would recommend consulting with a professional technician for a proper diagnosis to be completed. I hope this information is helpful to some degree. -Matt
Mar 18, 2015 | Frigidaire Washing Machines
I want to keep the water in my Roper top load washer overnight so it will soak the load of whites I have started but the machine drains.
You should be able to select a soak cycle without having to turn off the water supply, but it may time out eventually and drain the tub. This p[events oversoaking the clothes
Oct 13, 2012 | Roper RAS8445KQ Top Load Washer
How does the soak cycle work. Does it start at the end of the wash cycle, or does it drain the soap and soak in clear water
typically on the soak cycle it will fill with water..pause and soak then at the designated time it will advance into the regular agaitate/spin cycle
Aug 26, 2011 | Fisher and Paykel GWL11 Top Load Washer
I put a fairly large load in washer. As the washing started I needed to add an item. I was surprised that the machine had very little water in it. Is there a way to add more water. Also when soaking I had...
The Series 10 and 11 machines have three level fill points the Series 12 and above have two level fill points.
I know Bulky Items wash selection will give you a High water fill which is only 7 inches or so of water in the wash basket. 3.5 inches of water for a medium fill.
You can turn on/open the water inlet valves in Service Mode but I would not recommend that. A manual fill as you did is the only safe way to set the additional water level IMOP.
FAV6800A/FAV9800A Service Manual for reference.
Rich
Jul 05, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Whirlpool top load washer no low-speed agitation. The unit fills, starts the wash cycle with normal agitation, but after a few minutes it just sits there soaking until the it's time to drain/spin. Drains...
Either the wire going to motor for non working speed is loose or damaged, or motor is bad. It could also possibly be timer not sending power to motor for that speed.
Sep 27, 2017 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer will not fill up
IS YOUR DRAIN HOSE AT LEAST TO THE TOP OF THE MACHINE - OTHERWISE IT MAY RUN OUT OR SYPHON OUT/
Jul 26, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer fills and drains at the same time. doesn't change cycles
check the washer drain hose, it is probably sipening the water back out, try pulling it out of the drain a few inches
Apr 07, 2009 | Kenmore 24032\24036 Top Load Washer
Cloths were soaked !Won't restart, door locks and you hear a buzzind sound ??
Greetings JohnnyWrench,
Information provided by the manufacturer would indicate a few things possibly causing this:
1) Washer was overloaded, remove some of the clothes and continue the cycle.
2) Washer load was too small. Add 1 or 2 similiar items to help balance the load.
3) Load is out of balance, rearrange clothes to allow for more balanced spin.
4) Drain hose might be kinked, straighten drain hose.
You can also find a copy of your owners manual at
http://www.frigidaire.com/products/laundry/washers/front_load/prod_ATF7000FS.asp
I hope some of this helps!
Thank you,
Dorothy
Go Ahead. Use Us.
Apr 30, 2008 | Frigidaire Affinity ATF7000E Front Load...
Whirlpool LBR4132JQ Top Load Washer Logo
89 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
