Question about Honeywell HE250 TrueEase Advanced Bypass Humidifier Large
I would like to wash and re-use the filter for Humidifier HE250-C
Need manual for Holmes humidifier model HM-220. Don’t see replacement filter numbers on Amazon. Is there another that will work
For a manual, try Googling (holmes)(HM-220)(manual) without parens.
Fixya is unable to advise regarding filter interchangeability.
May 12, 2018 | Humidifiers
CF is displayed on my humidifier...what is that?
Check Filter Indicator
The ability of any humidifier to efficiently supply humidity output relies heavily on the
condition of the filter. As the filter loads with impurities it gradually loses its wicking
capability. When this happens, moisture output is reduced and the humidifier has to work
longer to satisfy the selected setting. This humidifier has a check filter reminder timed to
appear after 720 hours of operation. When the Check Filter (CF) message is displayed,
disconnect the power cord and check the condition of the filter. If a build-up of deposits or
severe discoloration is evident replace the filter to restore maximum efficiency. The CF
message is reset when the humidifier is plugged back in.
Mar 05, 2011 | Bemis 826 800 Humidifier
We havehad this humidifier for 3 months ans have has problems with a foul odor coming from it. We have replaced the filter 3 times! Is this normal? The cost to keep replacing the filter is ridiculous. Any...
I have the same poblem with mine. I'm telling you it was the brand new filter...after about a day the odor would start. I washed the filter out with white vinegar, then a drop or two of Dawn in hot water, then rinsed in cool water. Worked fine so far. It's been about a week. good luck
Jan 14, 2011 | Vicks V3100 1.2 Gallon Humidifier
We had our furnace repair turn on our Aprilaire 760 last summer. It gives off a very strong smell similar to an air freshener. We'd like that to be less in intensity. Furnance company says it's just fine....
I hope this helps you, have the repair person check to see if a furnace filter air freshener was installed at your last furnace check up without your knowledge. Also checked all wall and or floor registers to make sure the source of smell is not coming from them, it may be circulating though the duct system.last thing is to replace media pad in humidifier along with furnace filters, if you have air cleaner wash filters with hot water and baking soda, wipe & let dry before re- installing them. Your repair person may have use a strong smelling cleaning solution in humidifier that is now circulating though out your home, good luck.
Jan 24, 2010 | Aprilaire 700 Humidifier
How do I clean Hunter Humidifier # 34407 Nite Glo
the brown stuff is dust dirt unless you smoke then its that if you have washabule filter then wash it if not you must buy replacement filter thank you for useing fixya
Feb 17, 2009 | Hunter CareFree Plus 33222 Humidifier
Cleaning a furnace humidifier steel filter?
Most water panels are generally replaced once a year on flow through humidifiers.
Dec 20, 2008 | Honeywell Power Humidifier: Furnace...
Replacement filter question
Filter part number is BCM100. Filters are sold at Sears. Also available online. Part number is listed on bottom of humidifier.
Dec 04, 2008 | Bionaire BCM7204-U 3 Gallon Humidifier
Doesn't humidify
hi first of all: disassemble the device to its basic components and clean them well - clean the filter of the device well: take it out, wash it well with hot water, dont squeeze it let it dry ... maybe the humidity gauge isnt working ... check it with antoher gauge good luck
Feb 22, 2006 | Honeywell HCM535 Humidifier
Honeywell HE250 TrueEase Advanced Bypass Humidifier Large Logo
26 people viewed this question
Top Honeywell Humidifiers Experts
Dennis
Simon Benzekri
Level 1 Expert
Bill Long
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
