Question about Viper Security and Remote Start System (basic install included)
Car is NOT starting. Lights are not "flashing" when I hit the yellow start button. It will LOCK and UNLOCK using the remote, but it's not STARTING the 2008 Honda CRV. Do I need a new battery in the remote or is ther something in the car itself that I have to turn on or off? It was working until about 3 days ago. cgarcia1109@gmail.com thank you
  • 20 Answers
Is the car starting using the key? (manually), if so, then replace the remote battery, if problem still persists, then check the remote & the car's receiver...
or
the car's battery or some controller might be out-of-service!
new cars are electronically controlled, if any problem occurs, it jams the whole car,  perhaps this might be your case.. For your Safety: it is recommended to ask help from Honda Service Centre!!
Posted on Apr 24, 2009
Go to use the remote starter and the lights will come on so will the radio but it wont start.
Posted on Dec 13, 2009
    Problem Solver:
  • 10 Answers
I would change the battery in the car and in the remote just as a precaution. It could also be your starter.
I bought a 2007 Camry with a remote start. The seller doesn't know how to start the car with the remote. The remote is a 4 button Viper 474V.
First, be sure that the remote is programmed for the vehicle by using it to operate the door locks(pressing the lock and unlock buttons). The parking lights should flash if nothing else works.The usual way to operate the remote starter with this remote is by pressing the * button once but, the option could have changed if the remote has been reprogrammed differently. So, try pressing the * button once. If this doesn't work press it twice within two seconds.If this doesn't work try pressing the lock and unlock buttons at the same time. If these steps fail to initiate the remote starter try the steps listed for the * button with the aux button. If either of the remote starter inhibits (hood pin, neutral safety) are active you should receive flashing parking lights for a failed attempt to remote start.
Jan 16, 2011 | Remote Start System
I bought a 1996 Subaru Impreza L 4dr 5speed AWD that runs and starts fine but when I was installing fog lights i noticed that there appears to be an alarm hooked up (it says "code alarm elite DM...
Battery Constant 12v+ Positive Wire (+): Black/Yellow
Battery Constant 12v+ Positive Wire Location: Ignition Switch Harness
Starter Positive Wire (+): Blue/Red
Starter Positive Wire Location: Ignition Switch Harness
Ignition Positive Wire (+): Red
Ignition Positive Wire Location: Ignition Switch Harness
Accessory Positive Wire (+): Red/Yellow
Accessory Positive Wire Location: Ignition Switch Harness
Parking Light Positive Wire (+): Red
Parking Light Positive Wire Location: Low In Drivers Kick Panel
Power Door Lock Negative Wire (-): Add Actuator. This vehicle uses a central door locking system. When connecting a keyless entry, you will need to add a door lock actuator and some units will also require (2) extra relays.
Power Door Lock Negative Wire Location: To Drivers Door Only
Power Door Unlock Negative Wire (-): Add Actuator. This vehicle uses a central door locking system. When connecting a keyless entry, you will need to add a door lock actuator and some units will also require (2) extra relays.
Power Door Unlock Negative Wire Location: To Drivers Door Only
Door Trigger Negative Wire (-): Red/White
Door Trigger Negative Wire Location: In Black Plug, Above Hood Release
Domelight Supervision Wire: Use Door Trigger, Requires Relay
Domelight Supervision Wire Location: N/A
Horn Negative Wire (-): Red/Green
Horn Negative Wire Location: At Steering Column Harness
Tachometer Wire Negative Wire (-): Black/Blue
Tachometer Wire Negative Wire Location: At ECM, Under Drivers Side Dash
Brake Light Positive Wire (+): White/Black
Brake Light Positive Wire Location: At Switch Above Brake Pedal
CODE ALARM SYSTEM
Used on:
Impreza 1996-2001
Legacy 1995-1999
Forester 1998-2000
codealarmremote2.jpgBattery GP-23A
Lock: Left button will lock all doors. Double chirp indicates locked.
Unlock: Right button will unlock driver's door only. Hold unlock button app 6 seconds, it will unlock all doors including rear gate. Single chirp indicated unlock.
If the car chirps or lights flash 4x the alarm was triggered.
Panic. Press both buttons to activate emergency honk and flashing lights.
Valet mode: With optional alarm onlyPress the red alarm button on the left of the steering wheel. The light will quickly double flash. To re-set back to normal mode, press the red alarm light button again
Battery failed and lights flashing?
Parking lights will flash when the vehicle's battery is disconnected and reconnected.
To stop lights from flashing, either:
Press remote transmitter "UNLOCK" button once OR turn the ignition switch to the "ON" position and press programming button for one second (see below).
The vehicle interior (courtesy) light and door open warning light (DOOR AJAR indicator) will then illuminate for 60 seconds when the ignition is turned off, or until the doors are locked with the remote transmitter. Yes, the dashboard instrument panel lights will flash when the parking lights flash.
Programming or Overriding the Alarm when you have lost the remote
Open driver's door.
Turn ignition key to 'On'
Press and *hold programming button* in (see diagram, button under dashboard)
After 15 seconds the the door locks will cycle 3 times. Do not release Programming button.
Press lock (left) button the remotes to be programmed. The door locks will cycle one time. Exit programming mode by releasing Programming button under dashboard and turning key to off.
codealarmremote1.jpgCode Alarm Programming Button is under dashboard on the kick panel by the driver's left knee, left of the steering column. If you can't find it, it might still be tucked up in the wiring harness higher up in that same general area. The botton is recessed in a plastic ring (see diagram).
This button must be pressed while programming remotes or if the battery was disconnected and the lights are flashing.
Jan 05, 2011 | Subaru Impreza Cars & Trucks
Lost original car alarm control... need to reset a new one...
programing a Nissan remote , is hidden secret by Nissan Dealers. As a Nissan Technician i will share it.
Just get in your vech , close all doors. Using your power lock switch , lock all doors. After doors are locked take your Ignition Key and insert it and remove it from ignition switch in a slow fashion , but consitant pace. (97 and earlyer are fast) When you see the hazzard lights flash, put key in ignition switch and turn to the On postion .. Do NOT CRANK or you will have to Start over .. After in the On postion .. Hit the Lock button on remote... Hazzard lights should flash..( note..you have to reprogram all remotes when adding a new one , if you don't your old remotes will not work ) If your doing just the one , turn igntion switch off and unlock door and get out and try it. If you are doing more than one. While still in Vech with Key on . After you hit the Lock button on Remote and hazzard light flashed .. with key still on .. use master lock switch unlock doors and relock and then hit Second Remote, Lights should flash again , repeat if adding a 3rd remote.. after done just turn key off and unlock door and get out and try.
Oct 29, 2009 | 2002 Volvo S40
The doors lock when I start the car - I don't want that!
the unit can be programmed to lock the doors after starting, to make it leave it alone you have to enter the programming(ignition on, press the valet switch 5 times within 5 seconds, the lights will flash 3 times to signal you have entered programming, then press valet switch 10 times(lock after start setting) within 5 seconds hit the unlock button on the remote (button closest to the side with the other buttons)
then turn off the ignition to save the settings and it should be done
manual for the system is found at scytek.net under the download section
Apr 14, 2009 | Scytek 2000RS Remote Control
Redo code for 2007 Pilot key
ok get in the car, close the door, make sure all doors are closed.... put the key in the ignition, turn the key to on but without starting the car (lights on dash light up only) press and release the key lock button, turn key to off, without removeing the key.. turn to on without starting the car (dash lights up only) press and release the key lock button again, turn the ignition off, without removeing the key then turn back on (lights on dash on only without starting the car, press and release the key lock button , turn off the ignition without removeing the key, ..turn on the ignition once more without starting the car , press and release the key lock button and u should hear the door lock cycle ....leave the key in the ignition ... now press the lock button or unlock button on the other remotes one at a time if u have them.....u should hear the lock cycle indicateing all remotes are programmed.... kind of tricky to explain but you will get it, the sequence of turnin the key in the ignition on and off is only done with that one first key,,, remember after the door lock cyles press the lock or unlock button on the other remote fobs if if any...and ur done..may take u a few trys.. let me know how it worked out.
Apr 06, 2009 | 2007 Honda Pilot
Program a remote key for 03 A6
I have an A4 and did this to re-program my key:
1. used the key to start the car...then turned it off
2. put the key in the driver door (door closed)
3. pressed the lock button on the key fob once
4. turned the key to lock the door.
This is basically the steps in the owners manual, but the car must be started with the key first, and the key must be in the door lock before pressing the lock button.
Dec 10, 2008 | 2003 Audi A6
Remote starter does not work but will unlock and lock doors.
I have a 2003 sierra and my remote starter would not work, it would lock and unlock only, checked out this site found the solution, tried it and in two seconds i solved the problem, Just press the lock button and the start button and viola it works again, thanks for all your help , GGGreat site glad i found it John
Dec 08, 2008 | 2005 Pontiac G6
New key fob
Just get in your vech , close all doors. Using your power lock switch , lock all doors. After doors are locked take your Ignition Key and insert it and remove it from ignition switch in a slow fashion , but consitant pace. (97 and earlyer are fast) When you see the hazzard lights flash, put key in ignition switch and turn to the On postion .. Do NOT CRANK or you will have to Start over .. After in the On postion .. Hit the Lock button on remote... Hazzard lights should flash..( note..you have to reprogram all remotes when adding a new one , if you don't your old remotes will not work ) If your doing just the one , turn igntion switch off and unlock door and get out and try it. If you are doing more than one. While still in Vech with Key on . After you hit the Lock button on Remote and hazzard light flashed .. with key still on .. use master lock switch unlock doors and relock and then hit Second Remote, Lights should flash again , repeat if adding a 3rd remote.. after done just turn key off and unlock door and get out and try. Good Luck :)s.gif
Oct 26, 2008 | 2001 Chevrolet Blazer
Key fob not working
hello mate.. if it has stopped working you might want to check the battery first.. if you are sure that the battery is fine then consider reprogramming the fob to your car.. here are the steps to follow.. NISSAN
Remote Control Fob Procedures:
The Central Door locking is controlled by the Multi-Remote Control system which controls
the door locking, door super locking and emergency hazard reminders.
When the doors are locked and unlocked the unit flashes the hazard lights once for lock and twice for unlock.
A maximum of four remote controls are allowed to be programmed:
ALMERA
ALMERA TINO
PRIMERA
MAXIMA
MICRA
SERENA
VANETTE CARGO
TERANO II
Ensure all the doors have been unlocked, either by using a good transponder key or remote
control plip key.
Procedure:
1. Turn the ignition switch from Position 0 to ON 6 times within 10 seconds.
2. Next, turn ignition switch to OFF position. Leave key in ignition switch.
3. Wait 2 seconds then the system will enter programming mode and will flash the warning
lights twice.
4. Press and HOLD the unlock button on the Plip.
5. While pressing the unlock button, press the lock button 3 times.
6. Release the unlock button.
7. The warning lights will flash once to indicate successful programming.
8. Repeat procedure 4 to 7 for up to 4 plip key's.
9. When completed turn ignition ON, and the warning lights will flash 2 times.
10. Remove key, and check all plip key's for operation.
NOTE : The programming mode will stop when either the ignition is switch ON, 4 plip keys
have been programmed or no input signal either from the switch or plip keys has been received
for 120 seconds.
http://www.autokeysquad.com/nissan-fob-programming
i hope this can help you.. :)
Jul 28, 2008 | 2005 Nissan Sentra
Open Questions:
Viper 4806v won't program I am trying to install a viper 4806v two-way remote start/keyless entry in my automatic 2004 toyota camry LE 4cyl. I got the lock/unlock, horn, lights to work, and trunk pop to work. I can't seem to get the remote start to work. When I press the remote start button on the remote keypad, the car does not start and the headlights flash 7 times. Troubleshooting says 7 flashes mean a manual transmission mode error. This means I have to enter programming menu 3 and change the starter to automatic mode. When I follow the directions to get to menu 3, nothing happens because I cannot get to menu 3 when I hold down the control button after turning the ignition off. In other words, the control button is not working. The neutral switch is on like it is supposed to be. Kind of bummed about this. Could use some guidance. My wiring goes accordingly and this car does not have an immobilizer because I used a regular metal key to start it. This car has no alarm, just a stock keyless entry, trunk release, and panic button. Again, the problem is :The remote start comes in default manual transmission mode so I have to switch it to automatic transmission mode but I can't seem to enter programming. When I try to enter programming with the procedure followed using the control button, nothing happens. It does not chirp and the LED does not blink. I also cannot enter valet mode using the control button. When the car is locked, the LED blinks and stop blinking if car is unlocked ignition is turned on. I do not understand what is going on. VIPER 4806V Wires --->Camry Wires Main Harness 6pin connector H1/1 Red 12volt input (+) --> (+) White/Red at ignition Harness H1/2 Black Chassis Ground (-) --> Car Frame (-) H1/3 Brown 200mA Horn Output (-) --> Green/Black (-) at steering column H1/4 White/Brown Light Flash Isolation Wire --> NOT USED H1/5 White Light Flash --> Hazard Light Flash Relay Lt. Green Black wire (-) H1/6 Orange Ground when armed --> NOT USED Door Lock 3 pin connector 1 Blue 500mA Unlock Output (-) --> Blue Wire (-) white connector at driver kick panel 2 Empty --> NOT USED 3 Green 500mA Lock Output (-) --> Blue/Yellow wire (-) blue connector at driver kick panel Auxillary/Harness 24 Pin Connector 1 Pink/white 200mA Ignition 2 output/ Flex output (not used) --> NOT USED 2 Blue/White 2nd Status/Rear defogger output (-) --> NOT USED 3 Red/White 200mA Trunk Release Output (-) --> 5pin Relay Pin 85 (86 & 87 to +12V, 87a White/blue trunk wire toward dash, 30 white/blue trunk wire toward trunk) 4 Black/yellow 200mA Dome light Output (-) --> NOT USED 5 Dark Blue 200mA Status Output (-) ---> NOT USED 6 White/Black 200mA Aux 3 Output (-) ---> NOT USED 7 White/Violet 200mA Aux 1 Output (-) ---> NOT USED 8 Orange/Black 200mA Aux 4 Output (-) --> NOT USED 9 Gray Hood Pin input (-) ---> Installed at hood and Switch is open when hood is closed 10 Blue Horn input (Jumper set (-)) --> Green/Black (-) at steering column 11 White/Blue Activation Input --> NOT USED 12 Violet/White Tachometer Input --> Black/Orange wire on the Datalink Connector 13 Black Neutral safety/Parking Brake Input (-) ---> (-) Ground to metal frame of car. 14 Green/Black 200mA Factory Alarm Disarm Output --> NOT USED 15 Green Door Input (-) --> Red/Black Wire (-) (Door open indicator on dashboard) 16 Empty --> NOT USED 17 Pink 200mA Ignition 1 Output (-) --> NOT USED 18 Violet Door Input (+) ---> NOT USED 19 Violet/Black 200mA Aux 2 Output --> NOT USED 20 Brown Brake Shutdown input (+) --> Green/White Wire (+) at brake switch above brake pedal 21 Violet/yellow 200mA Starter Output (-) ---> 5 pin Relay pin 85 (Pin 86 & 87 is +12volts, Pin 30 black/yellow starter wire (+) at pin 8 in ignition harness) 22 Gray/Black Diesel wait to start Input (-) --> NOT USED 23 Orange 200mA Accessory Output (-) --> NOT USED 24 Green/White 200mA Factory Alarm arm output (-) --> NOT USED Remote start 8 pin Connector 1 Red/black 12v Constant Input for Acc and starter relay (+) ---> White/Red wire 12v (+) at ignition harness 2 Pink/black Flex relay input 87A key side (+) --> NOT USED 3 Pink/white Ignition 2/ Flex Relay output (+) --> Black/yellow pin 4 at ignition harness 4 Red 12V constant input for ignition 1 Relay (+) -->White/Red wire 12v (+) at ignition harness 5 Violet Starter Output (+) --> Black/White wire (+) at ignition harness 6 Accessory Output (+) --> Blue/Red (+) at ignition harness 7 12v Constant input for ignition 2 and flex relay (+) ---> White/Red wire 12v (+) at ignition harness 8 Pink Ignition 1 input/output (+) --> Black/Red wire (+) at ignition harness.
Oct 20, 2014 | Viper Security and Remote Start System...
See all Viper Security and Remote Start System (basic Questions
Viper Security and Remote Start System (basic install included) Logo
547 people viewed this question
Top Viper Home Security Experts
Kevin Daniels
squeely
Are you a Viper Home Security Expert? Answer questions, earn points and help others
