Question about Intel DP35DP Desktop Board - P35 Express - Socket T - 1333MHz, 1066MHz, 800MHz FSB - 8GB - DDR... (BLKDP35DPMPAK10) Motherboard
Need to replace p35-157-11z9 ethernet module, how?
Forget password
You can restore your setting and your password will be default else contact to customer support help line .
Mar 22, 2014 | Advantech ADAM-6000 Series Ethernet I/O...
My computere does not accept any driver for ethernet adapter :rtl8139d from lightwave company that module lw-ncrt plz help me
uninstall it's driver then shut down your module then reinstall it...........
check it's requirement............
Feb 03, 2011 | Zonet Fast Ethernet Adapter Realtek 8139D...
Hi how a 1GB ethernet passthrough can connect to 10/100 base t network or switch port. pls answer. regards NR nayan.dhn@gmail.com
No, The 1Gb Ethernet Pass-Thru module does not auto negotiate and will not accept commands to operate at any uplink speed other than 1Gb.
Jan 18, 2011 | HP Bladesystem c-Class 1GB Ethernet...
When I turned on my printer today all the lights on the front started flashing and this error message showed: "C4EB8000. Turn power off then on again." I've tried googling it and nothing seems...
Follow these steps to resolve the error message. It might not be necessary to complete each step to fix the issue. Step one: Disconnect all data cables and devices from the HP product
  1. Disconnect any USB, Ethernet, or parallel cables from the back of the HP product.
    CAUTION: Do not disconnect the power cord during this step. Figure 1: USB connectionc01661620.gif Figure 2: Parallel connectionc01369986.jpg
  2. Remove any memory cards or USB drives from the HP product.
Step two: Turn the HP product off and then on
  1. Press the Power button (c01602202.gif ) to turn off the HP product.
  2. Wait 15 seconds.
  3. Press the Power button (c01602202.gif ) to turn on the HP product.
Step three: Reconnect the data cables and devices
  1. Press the Power button (c01602202.gif ) to turn off the product.
  2. Reconnect one USB, Ethernet, or parallel cable to the back of the product.
  3. Press the Power button (c01602202.gif ) to turn on the product.
  4. Check the display for the error message.
    • If the error message does not display , reconnect another cable, and then repeat steps 2 through 4.
    • If the error message displays , replace the cable you just reconnected with a new one. Go to the How to Buy HP page to buy the replacement power supply for your product.
Step four: Determine if the HP product uses a power cable or a power module as the power supply If the power supply is a cable with electrical connections at each end, the product uses a power cable . Figure 3: Power cablec01369983.jpg If the power supply is a cable connected to a module or box, the product uses a power module . The power module might have a permanently attached power cord, or the power cord might detach from the power module. The term power module refers to both the power module and the power cord. Figure 4: Power modulec01369984.gif c02020663.gifIMPORTANT If the product uses a power module, make sure that the power module part number is the same as the part number listed in the User Guide to ensure you have the correct power module. If the part numbers do not match, replace the power module. Go to the How to Buy HP page to purchase the replacement power module for your product. Step five: Check the electrical connections and outlet
  1. Disconnect the power cable or power module from the back of the product.
  2. Disconnect the power cable or power module from any power strips or surge protectors.
    NOTE: If the product uses a power module with a detachable power cord, unplug the cord from the power module, and then plug it into the power module again.
  3. Wait 30 seconds
  4. Plug the power cable or power module directly into a wall outlet.
  5. Reconnect the power cable or power module to the back of the product.
  6. Press the Power button (c01602202.gif ) to turn on the product.
  7. Monitor the product to see if it turns on then off again.
    • If the product remains on , you might have too many devices plugged into the power strip or surge protector. You might also need a new one.
    • If the product turns off , the source of the problem is the electrical outlet. Continue to the next step.
  • If these steps resolved the issue , there is no need to continue troubleshooting.
  • If the issue persists , see the next step.
Nov 11, 2010 | HP Photosmart C5280 Printer
Module: x3200m2 type:4368 i1s server how many lan (ethernet) ports are available for usage
Number of all ports available: Six USB; Ethernet,two serial,parallel and Video.
One x8 high-speed PCI-E adapter slot offers investment protection by supporting high-performance adapters, such as Ethernet, Fibre Channel and InfiniBand cards, none of which will run in older conventional PCI slots.
The x3200 M2 includes one integrated Broadcom 5722 Gigabit Ethernet controller for up to 10X higher maximum throughput than a 10/100 Ethernet controller. In addition, the 5722 supports IPMI-over-LAN.
Jun 26, 2010 | IBM System x3200 M2 Server
Enthernet cable
Ethernet 100/1000MBPS cables need to be Cat6 cables. These can be purchased at your friendly computer shop or over the Internet.
Do a Google search for Cat6 ethernet cables on the Internet.
Oct 23, 2009 | HP Module Enthernet 100/1000MBPS 1-PORT...
Speedstream 6520 driver
Windows doesn't detect Ethernet connected devices. You could hook up a dozen Ethernet Modems and Windows would not see any of them, but they all would work fine using TCP/IP. It is not like you installed the DSL Modem/Router inside the case of the PC. You do know how Ethernet works, right? The only driver needed is the correct one for your Ethernet card, but that comes the Ethernet Card or the Motherboard Drivers CD for onboard Ethernet.
Found a few things, here are some websites to try:
Troubleshooting: Here
USB Driver for your Speedstream: Here
Sep 25, 2009 | Computers & Internet
Most times no ping...every now and then a boot. ideas?
RAM or Ethernet module...
Try to disable Ethernet on Bios, and see if it still reboot...
Meanwhile use another Ethernet Adapter on one of your PCI slots...
Regards
Jun 24, 2009 | HP (D7580-60003) Motherboard
Ethernet and upgrade from 8.5
you can't simply upgrade. You will need a osX CD or DVD to install it
Jan 24, 2009 | Apple Power Mac G4 Desktop
One of two 3com pci gigabit ethernet cards is not working
If you have the driver disk that was distributed with the card , try reinstalling the card drivers first.
If the card is faulty, buy a new pci ethernet adapter and replace it, inserting the ethernet adapter into the pci slot.
After installing install drivers for the new card with the disk that will come with the card.
Ensure that you are logged in as administrator when you reinstall the drivers.
Nov 05, 2008 | SysKonnect Gigabit SK-9843 Network Adapter
Intel DP35DP Desktop Board -  P35 Express - Socket T - 1333MHz, 1066MHz, 800MHz FSB - 8GB - DDR... (BLKDP35DPMPAK10) Motherboard Logo
35 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
