Question about Exercise & Fitness
Trimline treadmill E3 error code
taran_2005
  • 10515 Answers
SOURCE: Shortly after starting my Trimline 1050 stops with
This is a common error on this machine.
The E3 error code indicates an overspeed warning.
The cause is excess drag on the walk belt or board. The drag prevents the belt from starting easily and the controller will send more power to the motor to accomodate the drag, but the controller sends to much power and thus the treadmill races. The controller then senses the overspeed and shuts it down and gives the E3 code.
The motor controller weakens over time because of the excessive amperage draw of the motor do to lack of lubrication (which wears the walk belt and walking deck).
Take an amperage reading of the motor it should be 2-3 amps with no one on it, with someone walking on it it should be around 6-12 amps. I would bet yours is elevated above 6-12 amps.The controller is dropping output because of the friction problem.
The first thing to try after testing the amperage is to lubricate the walking platform. Then retest and see if the amperage comes down and it doesn't shut off.
If it does then the next step would be to replace the walking deck. If the amperage still is up you may need to replace the walk belt second and finally if after replacing the deck and belt, if the unit is still shutting down replace the motor controller.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Apr 11, 2011
ercupa190
  • 12223 Answers
SOURCE: I cannot lower my Pro Form Treadmill 725 TL to the lowest position for storage
Watch the videos:
http://www.youtube.com/watch?v=TquYcOzGIw4&feature=related
http://www.youtube.com/watch?v=9G4MZh8JO2Q
http://www.youtube.com/watch?v=M7qJrRbdfBc
http://www.youtube.com/watch?v=MIIxoPtvhy8hthttp://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitnesshttp://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=relatedSome system has board relais: one for DOWN AND ONE FOR UP: Please a) test for open and close the relais b) clean the contacts with spray contact cleaner and test. If the relais ARE not closing or oping the board is faulty.
See the block diagram.
12_6_2011_6_04_05_pm.gifGood luck, sincerely. G-d bless you, if you need additional help, please reach me.
E.CUADRA
MANAGUA, NICARAGUA. C.A
Posted on Dec 06, 2011
ercupa190
  • 12223 Answers
SOURCE: need user manual for trimline 7150 treadmill
plelase go to www.fitness.manualsonline.com or www.iconservice.com
God bless you
Posted on Sep 01, 2012
ercupa190
  • 12223 Answers
SOURCE: Treadmill FN 10282 shows code E3
Try to RUN the software calibration for diagnostic, troubleshooting and fix it.
2( However LUBE the deck belt, very IMPORTANT
3) LUBE the rollers bearing too.
4) Test the input voltage motor, if there are the motor need repair, see my persona TIPS.
5) test the output voltage board, for input voltage motor, if there are NOT the board is faulty. see the block diagram
God bless you
Posted on Sep 21, 2012
ercupa190
  • 12223 Answers
SOURCE: what does an E3 error code mean on my vitesse endurance xt treadmill
"E03': No sensor signal. Sensor wire is faulty, replace the sensor wire. Magnetic sensor wire is not working replace see the diagram attached.However clean it. and tight the connector very well.God bless you
Posted on Apr 04, 2013
Trimline treadmill T340. what is error code 905? symptom: it runs for fine for a minute, then cuts off, and console starts beeping and flashing. i just replaced speed sensor
Try to align the speed sensor. It should be closer to motor pulley.
If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Dec 21, 2016 | Exercise & Fitness
My reebok irun treadmill suddenly stops with E3 error code displayed can you help me please.
Try lubricating the belt. My treadmill requires lubricant every now and then. Its not your treadmill but a treadmill is a treadmill. That's what stops the belt from slowing down due to friction. Go to your nearest Gym they may be able to sell you a tube of lubricant. Good Luck
Oct 23, 2016 | Reebok Exercise & Fitness
Where to buy trimline 7050 motor cover(plastic)
Trimline Treadmill ' eBay
www.ebay.com/bhp/trimline-treadmill
eBayGREY TRIMLINE TREADMILL MOTOR HOOD HOUSING KK-2439 FRONT ENDCOVER PLASTIC. $45.00. Buy It Now. This auction is for a good used treadmill ..
Jan 05, 2016 | Exercise & Fitness
What does an E3 error code mean on my vitesse endurance xt treadmill
Apr 03, 2013 | Exercise & Fitness
Diagram control board trimline t315
see if this diagram serve you. Otherwise you can give your email or reply to my email ercupa@netscape.net and I will give you a better information diagram.
God bless you1_22_2013_4_41_53_pm.png1_22_2013_4_42_22_pm.jpg1_22_2013_4_42_42_pm.gif
Jan 22, 2013 | Nautilus Nautillus, Trimline, Schwinn...
Hi, i have an Error signal " 2 - 9 F " the treadmill stops and cant run anymore. thanks a lot!
I have a Matrix Treadmill t4. An error of "E1 and E3" occurs when it is started? Can you tell me the solution?
Mar 15, 2011 | Matrix T3Xi Treadmill
I havea new balance 1400 I keep getting two error codes on my screen the first is E1 and then A E3 on elevation.?
Hi This is dinesh here,
The E1 Error is for the sensor problem and the E3 error is for the IC crasg in the machine...
Jul 22, 2010 | New Balance 1400 Treadmill
Error code E2
Hi most of the treadmill with e2 error code are related to the motor speed sensor so check the sensor
May 12, 2009 | Exercise & Fitness
Exercise & Fitness Logo
71 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
