Question about Pride Jazzy 614 Hd JAZZY 614HD
RESET YELLOW WRENCH LIGHT - Pride Jazzy 614 Hd JAZZY 614HD
A wrench is showing
The definition of the warning light should be in your owners manual.
Normally a yellow wrench warning light is a problem with the engine controls, and a red wrench involves the drivetrain.
The warning light tells you there is a problem and the computer needs to be scanned to get the trouble codes to proceed.
May 10, 2013 | 2005 Ford Explorer
Yellow wrench light came on my chevy equinox
their is a wrench next to the oil light and the engine light stays on what is the problem with the equinox it is a 2005
Jan 26, 2013 | 2005 Chevrolet Equinox
Blinking yellow wrench light on pride jazzy 614 HD
Your version has a Dynamic Controls model controller and joystick.
Unplug the charger and engage the motor/brake lever so the chair is no longer in free-wheel mode (con't push by hand)
Turn the chair off, wait 5 seconds, turn the chair back.
If chair still does not run and your wrench is flashing you have a problem. Count the wrench flashes - the flash count indicates the error detected. 3, 4, 5, and 6 flashes indicate and error with the motors.
3=Left motor fault
4=Right motor fault
5=Left brake fault (may not be engaged)
6=Right brake fault (may not be engaged)
Any other fault code usually means the electronics or wiring is bad and not worth fixing.
Jan 06, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
What does the yellow wrench light indicate on a 2008 dodge caravan. THANK YOU!
a yellow light indicates maintenance interval has passed whether it b oil change maintenance or egr maintenance,(exhaust gas recirculation valve) can b reset as per ur owners manual.theirs specific instruction in ther on how to reset ur light. maintenance is recommended though,not a good idea to reset an keep driving w/o required maintenance.. hope this helps
May 01, 2011 | 2008 Dodge Grand Caravan
Red wrench light in on, wont copy- no jams, display shows error, call for help - ricoh aficion 720 copier
first we need to know what is the code.
ex. SC_ _ _
after that we could lock on the problem.
the reset code for this is either off the machine and run SC reset clear/mode (yellow button) 107 press for about 5 seconds cancel button (red button) then exit off machine after 5 seconds on machine
Feb 26, 2010 | Ricoh Aficio 450 Copier
Yellow/gold wrench light 2006 honda accord is still on after an oil change . How do I reset it?
Is the oil life low? If so scroll up the oil life and hold down the RESET knob until it goes out. If the oil life is high, then service is needed.
Dec 15, 2009 | 2006 Honda Accord
Yellow/gold wrench light 2006 Honda Accord
take it back to the servicing firm and aks them to finish the job.
Jun 19, 2009 | 2006 Honda Accord
Yellow wrench service soon light comes on
The difference is the yellow wrench is a mantinence required light it doesent mean there is a problem its a reminder to get service like oil changes . Everytime you get an oil change the tech has to reset the mantinence light . The reset instructions are in the owners manual
Mar 24, 2009 | 2006 Mercury Mariner
Yellow wrench/service light is on no codes in system, dont have owners manual is this an oil life reset light?
I had the same problem... yellow wrench "service" light and a clicking noise on my DRL (daytime Running Lights) icon. I found no codes when I put my diagnostic computer on it. Turned out I had a headlight out. Replaced the bulb and everything is hunky dory now!
Feb 23, 2009 | 2003 Pontiac Sunfire
Pride Jazzy 614 Hd JAZZY 614HD Logo
23 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
