Question about Whirlpool Dishwashers
I want to remove the strainer or filter from my model w10130987a whirlpool dishwaser
2 Suggested Answers
SOURCE: we have a mdb7600aww dishwaser that does not clean
Mine would not drain properly, so I am not sure if that correlates to your problem (water pooled in bottom). I pulled the drain hose off my garbage disposal and put a long wood dowel through it to clear any blockage (about 3 feet long). It cleared the blockage and the dishwasher drained fine after that! I have had to do this a few months later, so it must be a chronic problem.
I have had problems with impeller blockage too, and have had to take that apart. I HATE this dishwasher for the continual problems encountered. NEVER a "Paytag" again.
Posted on Dec 14, 2009
Gas filter for Nissan Altima2006
Like many late model cars the fuel system in this car doesn't use an in line filter anymore, this has been the case since the early 2000's, so there is no part number. The only filter in the system is the fine mess nylon screen at the intake to the fuel pump inside the gas tank.
Feb 04, 2012 | 2006 Nissan Altima
Washer does not finish wash cycle. flashes F-21 half way through. Detergent is used up bu does not get to where is uses the fabric softener.
the filter/strainer is partially blocked. Take the kick panel or inspection cover off the bottom of the unit at the front(sometimes back) and you will see a round plastic cap that unscrews approx 3" round.After removing it you can pull the strainer out of it and clean it, there may be some residual water so have a towel or tray ready.Hope tis helps, any questions go ahead and ask
Jan 20, 2011 | Whirlpool Duet GHW9150P Front Load Washer
What does code F21 mean on a front loader?
The water is taking too long to drain from tub, remove the lower acces panel on the front of the washer and unscrew the round cap which contains the strainer filter. Take filter out of the housing and see what has all collected you may be very surprised what you find, let me know if this solves your problem or need more help
Jan 19, 2011 | Whirlpool Washing Machines
How do i clean a filter of a whirlpool awm 5080 front loader
If you are talking about the drain pump strainer, you need to remove the lower front panel. should be 3 screws on the bottom facing forward. Once you have that off, the pump strainer is almost in the center, facing you. unscrew it counterclockwise to remove.
Apr 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Bosch dishwasher wont drain. At end of cycle is full of cloudy water.
It is possible if you have broken a glass recently that the piece of glass has made its way to the drain pump impeller. You need to remove bottom basket. Remove the filter strainer clamp by rotating CCW. There may be another round filter under the strainer (depending on model). Then with a torque screwdriver remove one screw which holds the plastic pump cover on. Remove the pump cover and pay close attention to the pump impeller. Does it rotate by finger movement? If not it could be jamed with a piece of broken glass. You must remove any obstruction to allow the impeller to turn. I usually force a paper towel piece (half piece while rotating the impeller by finger to allow the paper towel to bring up any obstruction below the impeller) Reassemble the cover and filters carefully and make sure the final strainer clamp aligns correctly with its marks. This insures nothing will make its way to the impeller in future.
Regards Sam
Jun 15, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Whirlpool HE WFW9200SQ00 is Dead
control unit dead, replace main control and possibly user interface. Sorry this is very common failure on whirlpool.
Apr 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
FDW60 Dishwasher
HI
The strainer is located directly under the lower sprayer arm. When the strainer becomes clogged with food and detergent debris, the dishwasher may flood or overfill. On some dishwashers, the strainer is a plastic or metal component consisting of two semicircular halves. To remove this type of strainer, pry it up. On other dishwashers, the strainer is a one-piece component. To remove this type, remove the cap that holds the sprayer arm on its shaft. Then remove the sprayer arm and the strainer.
Wash the strainer in the kitchen sink with water and a mild household detergent. Use a fairly stiff brush to get all the debris out of the holes and slots in the strainer. Rinse the strainer well and replace it. If part of the strainer lifts out for regular cleaning, check it and clean it -- if necessary -- after each load of dishes is washed.
Oct 13, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Strainer and a Filter differences
Actually there isn’t any since a strainer is, in reality, a coarse filter. The question is then one of semantics. Generally it is assumed that if the particle to be removed is not visible to the naked eye, the unit is filtering, and if the particle is visible, the unit is straining. The average human eye can detect a specific particle between 50 and 70 micros. Most people cannot see anything smaller than 325 mesh, or 44 microns. Since 200 mesh is equivalent to 74 microns, a general rule would be that if the screening device is coarser than 200 mesh, it is a strainer and if it is finer than 200 mesh it is a filter. One of the best uses for a strainer is in conjunction with a filter. By installing a strainer directly ahead of a filter, the large heavy pieces which would quickly clog the filter are removed. The filter is then free to do its major job of fine particle removal and does not have to be cleaned so often.
Aug 27, 2008 | Brasstech Jr. Basket Strainer with washer...
Strainer for drain pump
There is no filter that goes over the strainer. The strainer is just to catch coins and such that would lock up the pump.
Oct 18, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Dishwashers Logo
29 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
