Question about Dewalt 7.2-18.0 Volt One Hour Charger
De0246 charger diode blown - Dewalt 7.2-18.0 Volt One Hour Charger
2 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: rowdy its the sds dewalt dc222 model
just sent you a response on other request you made, let me know if you don't get it
Posted on Jul 18, 2009
Schematic dewalt de0246
depending on the location of the diode in your charger just try replacing it with a ginaric type diode of the same size, but be forewarned that the diode blew up for a reason and you must first find the cause before you replace it for it will blow again and possibly cause more destruction, is it worth it to you to repair or just bye a new one ?
best regards Falco
Oct 31, 2013 | Drills
Can"t charge battery
Could have 1 or more problems. Bad battery, bad charger, bad wiring/connection, blown fuse, or some had a protection diode in the + line in which could open. Would check fuse first.
Sep 26, 2013 | Craftsman 675 Series 190cc 22" Briggs ...
Charger won't charge just power light comes on no output!!
That looks pretty old to me. There can be several things wrong with it. It might have bad diodes, bad regulator or bad transformer. If you dont have test equipment, it will be hard to tell
Jan 19, 2013 | Cars & Trucks
Makita 1850 battery charger FIX. A friend asked me to check his charger unit which had failed after it had been connected to a portable petrol generator that incorrectly generated 317 Volts AC and not the...
I have a BL1830 Lithium Ion LXT battery that will not charge because the charger tells me the battery is broken. I have taken the battery apart to find no problems with the connection from cell to cell. There is a small circuit board that I cant find any visible signs of damage on. The battery will still run a flashlight or a drill but it is almost drained.
May 16, 2010 | Makita Drills
Rowdy its the sds dewalt dc222 model the charger is air cooled de0246 regards mike
Jul 18, 2009 | Dewalt 18 Volt Compact Drill Kit
Car Battery Charger - Repair
thats what i did on mine they blew when i hooked the cables up backwards (gotta watch that)
but i used 130 amp alt diodes from an old tractor alt i had
Jul 03, 2009 | Kitchen Appliances - Others
Charger problem
A phone charger is supposed not to be serviceable (you must not replace components). As this is a safety device, and even a bad solder joint can cause a serious hazard (fire, shock, phone blown).
The only way to find out the value of this transistor is by using a multimeter with diode tester function and testing the transistor as if it was a circuit of two diodes (that is what a transistor is), see here: Testing semiconductors with analog and digital multimeters. , also Transistor.
If the transistor has blown this will be impossible.
Try also going to a spare component shop with the transistor and circuit, this is what we all do when we do not have the schematics and value.
Being this a $8 charger, better buying a replacement:
Sagem my202C European Mains Charger EU 2-Pin
Sagem my202c Chargers uk 3 pin plug
Apr 15, 2009 | Sagem my301L Cellular Phone
Laptop problems
Yes fuse/diod, but you'll have to take board out.
To take cd out you'll need to stick pin in the small hole on cd drive's bezel.
Mar 22, 2009 | Computers & Internet
Neff combi blown diode.
If the diode failed by opening, there may be no other damage. If the dioded failed by shorting, the alternating current may have damaged other components. Ohm it out. You can get diodes from digikey.com, mouser.com, or radio shack or any electronics or appliance supply. If the diode is charred and you can't get the part number, the oven rating can be used to select a replacement. Since the fuse was 10 amps, the diode should also handle at least 10 amps. If you can power the unit and read the voltage at the diode input this will give you the power (volts times amps). It's always worth trying as it's cheaper than replacing the unit.
Oct 14, 2007 | Neff H7871N2GB Convection / Microwave Oven
Dewalt 7.2-18.0 Volt One Hour Charger Logo
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
