Question about Siemens Lands Phones
Set base siemens 7010 - Siemens Lands Phones
Siemens 7010 it will not switch on
Phone should turn on by itself. Have you left the phone in the base long enough for the battery to charge. It could take up to 24 hours. If you want to change the battery there is normally a section of the case on the bottom back of the handset that slides down to reveal the battery. Check the cost of the battery first, I have found that sometimes it is better to upgrade to a new phone due to the price of replacement batteries.
Apr 12, 2014 | Lands Phones
NSN 1600, restored to factory settings, no internet access, internet light blinking fine, help
Some people find configuring Nokia Siemens Residential Router 1600 with BSNL is a little difficult. So I would like to present a tutorial to setup Internet connection with BSNL using Nokia Siemens Residential Router 1600. Just like other BSNL modem/ router models, we do not need any setup disc to configure Nokia Siemens Residential Router 1600. All we need is to follow some simple steps and adding some values. We can also setup wireless and wireless security from the web based setup page Configure Nokia Siemens Residential Router 1600 In order to configure Nokia Siemens Residential Router 1600 with BSNL follow the steps below.
1. Connect Nokia Siemens Residential Router 1600 to computer using Ethernet cable
2. Power on Nokia Siemens Residential Router 1600
3. Type 192.168.1.1 on address bar of Internet Explorer and press enter
USER Name: admin
Password : admin
Now you can access the web based setup page of Nokia Siemens Residential Router 1600.
Apr 09, 2013 | Computers & Internet
Siemens Gigaset 4200 Cordless keep searching for base
The handset should be returned to the charging station, let it set for a few seconds. If this is a satellite phone, make sure the main phone "base unit" is connected to phone outlet and plugged in. After the phone has established its physical connection with the base again you can remove it and use it like normal.
May 18, 2012 | Siemens Gigaset 4200 Cordless Expansion...
No view of Olympus 7010 screen after dropping
You'll have to take the camera in for service to replace the component that was damaged in the fall.
Unfortunately, the cost to repair the camera will most likely be as much or more than just buying a new, replacement camera.
Feb 13, 2012 | Olympus Stylus 7010 µ 7010 Digital Camera
I had switched off my Gigaset C200 for one week and when I switched it on again so still flashes "base 1" on the phone's display. I tried manually connect to the base with PIN 0000 but still...
YOU SHOULD HARD RESET THE UNIT
When restoring factory settings:
u Handsets are de-registered
- When resetting via the menu:
all Gigaset handsets
- When resetting using the key on the
base station: also all handsets of
other GAP capable devices
u Individual settings are reset
u All lists are deleted
u The system PIN is reset to the original
code 0000
u Eco Mode+ is deactivated
Only the date and time are retained.
Resetting the base station via the
menu
₪ Settings ₪ Base ₪ Base Reset
§Menu§
§OK§
Press the display key to confirm
SIEMENS Gigaset C380 User Giude Restoring The Base Station To The Factory...
Dec 27, 2017 | Siemens Gigaset C200 Cordless Phone
I need to lock my siemens 7010 so my children cant use it
you should be able to go into the security settings on the phone and enable a password. You will have to enter this password every time but at least it will keep your children out of it.
Mar 24, 2011 | Cell Phones
Locked myself out of my lifebook s 7010 need to reset code as forgot it after night out reset
You download Wininternals ERD commander 2007, below is the link
Rapidshare Link
Megaupload Link
Easy-Share Link
You can use any of the above link. Extract the file using Winrar and burn the ISO images in a CD.
Boot your system using that CD (Set the first boot device as CD-DVD Rom in your BIOS).
You can easily set a new password using the tools called "Lock Smith"
That's it.
Feb 06, 2010 | Fujitsu Siemens LifeBook S7010 Notebook
I am looking for a user guide for model 7010 Siemens Eircom,my phone no.is0214291987
Thank you for your reply, a daughter of mine solved my problem for me. So,I shall not be needing the User Guide after all.
Aug 31, 2009 | Siemens Lands Phones
How to use sms function on siemens 7010 cordless phone
Try typing "0" twice that may bring it up... Or refer to your manual.
Jul 13, 2009 | Fujitsu Siemens LifeBook S-7010 Notebook
Lands Phones Logo
56 people viewed this question
Top Siemens Lands Phones Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
