PC Laptops
Problem for PC Laptops
Generic problem for all PC Laptops
Asus A6000 power shutdown
By 999tay on Sep 25, 2007
My Asus A6000 starts up, runs for a few minutes then shuts down. Any ideas.
Same Problem
Aug 22, 2008
-   this laptop will turn on, but will shut off and a blank black page is all that is shown. will work at other places but not where it should. -   keikookw
Nov 09, 2007
-   Mine would do it on battery or ac power. I was able to troubleshoot that I thought there was a battery problem. I could remove the battery and it would run ok. Now it doesn't start at all.-   bundio
Solution #1
posted on Sep 26, 2007
Not Helpful)
MUKHTAR
Rank: Wiz  Computer Hardware  Expert
Rating: 78%, 871 votes
see it is working on battery or direct power from adoptor .
bye
Was this helpful?
Yes
No
Solution #2
posted on Aug 08, 2008
Not Rated)
Jackkron
Rank: Apprentice
Rating: 0%, 0 votes
The CPU heatsink has it's thermal paste dried. Fixed one A6000 with this fault. Works perfect now.
Was this helpful?
Yes
No
Solution #3
posted on Nov 16, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
try removing hard drive and see if it starts up .... remove any recent upgrades ! , remove wireless card, remove everything you can and than try start it up , also try restoring bios to defult
Solution #4
posted on Oct 15, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Shutdown can be caused by several things.
Easiest, operating system corruption...
Try starting up your laptop, and hit the "setup" key, usually F2 or Del... once there, leave it running for 15 to 20 minutes. If it stays up, then you have a problem with the OS.
If it dies again, you may have issues with cooling of the chipset or CPU. Make sure your system gets sufficient air cooling. some systems have the ability in the setup menu to monitor the CPU core temps and voltages. Watch these also.
Last, but not least, you have a power supply problem. This too will cause a shutdown...  Hope this helps...
Popular Solutions for PC Laptops
Questions and Unsolved Problems for PC Laptops
Answer
what are the best upgrades for acer travelmate 4200
Answer
drivers for integrated cameraof NEO GL31 laptop with Genuine Intel(R) CPU T2400 @ 1.83GHz
Answer
installing windows 7 upgrade won't install. now operatimg system disc don't run
Describe your PC Laptops problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptop Experts
Top Computer & Laptop Repairmen
in Newport, KY
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
