Question about Refrigerators
Humming sound and not cooling
Woke up this morning with my refrigerator making a loud humming sound and the inside temperature is in the mid 50's. Does this sound like a compressor problem?
  • richard_lack Apr 25, 2009
    Had a handy man come out and fix it. You were right. It was not defrosting and it was low on freon. Thanks for the feedback.
  • Refrigerators Master
  • 4,655 Answers
Make and model number? May be not defrosting but will be able to help you better with the most important information. Sea Breeze
Posted on Apr 24, 2009
I have a KitchenAid Refrigerator Model Number: KBFC42FTS. Bottom drawer freezer over cools -10 degrees.
Does that unit have a low temperature monitor built in? Maybe that is what is making the noise when your temps dip to -10 degrees. Actually, that is great because the lower the temps the longer you can keep food in the freezer so I would not be overly concerned about that aspect. BTW, have you tried to isolate the source of the humming noise?
Sep 19, 2017 | KitchenAid Refrigerators
Refrigerator not cooling properly
Sounds like the motor. If the motor isn't running properly or at all then the cooling systems are affected and the fridge runs warm.
Oct 19, 2015 | Refrigerators
Yesterday morning I noticed that the unit was buzzing. The refrigerator door had been left open and the temperature inside was 70 degrees. The freezer temperature was 20 degrees. This morning, 24 hours...
Hi
You have condesation built up in your freezer whereby the evaporator fan or the vents are most likely blocked off.
Turn fridge off. Empty freezer and either put a pot of boiling water inside freezer or with the aid of a hair dryer try to defrost the freezer. If you are able to remove the back panel on the freezer that would be ideal as you can directly target the frost.
Good luck
Ash
Sep 06, 2011 | Refrigerators
Condensation on inside of refrigerator and frozen water build up in one of the drawers. Fan makes loud humming sound as well.
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 28, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Wiped down refrigerator and now it is not cooling
i would suggest to check the climate control setting & make sure it's at the mid range setting usually 4 or 5.. sounds like you bumped it when cleaning
Aug 01, 2010 | GE Profile 21.6 cu. ft. Side-by-Side...
Ge eterna refrigerator loud humming
suspect you have a problem with the defrost system and hence the noise with the fan. take back panel off inside the freezer and if i'm right, melt ice off with a hairdryer. get back to me to say the results if you want
Aug 23, 2008 | GE Profile PSW26P Stainless Steel Side by...
Kirland Refrigerator
It sounds like your compressor has failed. The hum is the compressor trying to start and the click following is the over current protector opening.
Jun 16, 2008 | Refrigerators
GMAC 5100 Speakers
I think that the internal power supply is at fault the rrpair would be to repair it
Aug 12, 2007 | Gateway GMAX 5100 Computer Speakers
Refrigerator not cooling.
compressor has failed. not a diy job
Apr 25, 2007 | Amana ASD2622HR Side by Side Refrigerator
Refrigerators Logo
120 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
