Question about Kitchen Appliances - Others
Ice maker (U-line Eschelon CLR 2160 W-40) not working P1 error message displayed
SOURCE: u-line CLR 60 B ice maker
U-Line's tech line is 1-800-2547. The compressor, condenser fan and circulation pump operating at the same time?
Posted on May 25, 2008
SOURCE: NO POWER GETTING TO UNIT
realized that there was nothing wrong with the unit....It is suposed to drain out water when running and need to jump start it...so alls good thanks for getting back to us...now were chilling.E.Bates
Posted on Jul 15, 2008
  • 10 Answers
SOURCE: CLR 2060 Clear Ice Maker
just a guess but did you make sure that the fan under the unit is turning? if you don't get rid of the heat at the condensor the freeze tray can't get cold.
Posted on Dec 19, 2008
gewiz
  • 1263 Answers
SOURCE: web page errors
if you're using IE8 try the compatibility view,
Make sure that the page displays correctly within ie7 or ie6.
Let me have some feedback
Regards
GeWiz.
Posted on Jul 24, 2009
  • 4090 Answers
SOURCE: Webpage error details
Usually associated with bad java script lines. Is it your coding or coding on a website? Check you are able to activate Java on your browser
Posted on Aug 01, 2009
Uline Echelon Ice Maker P1 error code
P1 is a indicator of a slow or clogged drain check to make sure that every thing is draining good if line is clear make sure pump is coming on to pump the water out of the bin. once all is clear unplug the unit for an hour then plug back in this will clear code unless you still have a drain issue.
Jan 17, 2014 | U-Line Icemaker
Can anybody help me figure out why I get the below message and how I can fix it? Thank-you Webpage error details User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1; Trident/4.0; .NET CLR...
Internet Explorer 7 cannot display a particular element on a Web page on that Web site.
Workaround 2 loadTOCNode(2, 'moreinformation'); You can turn off friendly HTTP error messages in Internet Explorer. This workaround still lets the error message appear. However, Internet Explorer does not move away from the page after the error occurs. This workaround works only for Internet Explorer 6.
To do this, follow these steps:
  1. On the Tools menu, click Internet Options.
  2. On the Advanced tab, click to clear the Show friendly HTTP error messages check box under the Browsing section, and then click OK.
  3. Close the browser.
Follow this link for more workarround
http://support.microsoft.com/kb/927917/en-us
Thanks
Sandeep
Mar 16, 2011 | Microsoft Internet Explorer 8
No ice and P1 code
The P1 code generally indicates that their is something wrong with the pump. Besides making sure the pump can drain correctly you will have to call for service
May 13, 2010 | U-Line Icemaker
Webpage error detailsUser Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1; Trident/4.0; SIMBAR
User Agent: Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 5.1; Trident/4.0; .NET CLR 1.1.4322; .NET CLR 2.0.50727; MAAU; .NET CLR 3.0.4506.2152; .NET CLR 3.5.30729; MAAU)
Timestamp: Wed, 21 Jul 2010 17:11:22 UTC
Message: Type mismatch.
Line: 179
Char: 1283
Code: 0
URI: http://api.msappspace.com/apprendering/152296/profile.right/07212010083001/1_0_0/render.app
Line: 179
Char: 1283
Code: 0
Message: Object doesn't support this property or method
Line: 279
Char: 17
Code: 0
URI: http://api.msappspace.com/apprendering/108417/profile.right/07212010080001/1_0_0/render.app
Line: 298
Char: 17
Code: 0
Oct 21, 2009 | Microsoft Internet Explorer 8
Er if code on display
ER means Error code......
The If error message indicates that the fan for the ice maker has failed. The main control board receives a feedback signal from this fan motor for the ice maker. If the feedback signal is abnormal or missing, then the error message will be displayed. The fan motor for the ice maker could be bad. You could also have a bad wiring connection between the motor and the control board. A remote possibility would be that the control board is bad. This is not likely since you noticed the ice melting in your storage bucket.
I recommend calling a service technician to diagnose and repair this failure.
Sep 20, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Error message P1
P1 means a drain issue. Either you have a kink in the drain line or you could have a bad pump.
Sep 19, 2009 | U-Line Icemaker
I have a Uline CLR 2160 ice maker. I am trying to
Your display will only show ice or off. There is no temperature settings.Now when I give the directions to put it into clean make sure the green led above the symbols is on steady. If you hold down the on/off key and hit the light key 3 times then release the on/off key last.(give a 1/2 second delay from releasing on/off key. It should go to CL. If led lights dont comeon then let me know.
Aug 08, 2009 | U-Line Refrigerator Ice Maker
Web page errors
Regards
GeWiz.
Jul 21, 2009 | Microsoft Internet Explorer 8
Webpage error details User Agent: IE/8.0... 4Code: 0 URI: http://mca.gov.in/DCAPortalWeb/dca/js/homepage. Unable to login using IE but able to login using Google Chrome. Please advise reasons.
User Agent: Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; Trident/4.0; GTB6; SLCC1; .NET CLR 2.0.50727; Media Center PC 5.0; .NET CLR 3.5.30729; .NET CLR 3.0.30729; msn OptimizedIE8;ENUS)
Timestamp: Sat, 16 Jan 2010 23:49:28 UTC
Message: 'DOM' is undefined
Line: 33
Char: 88
Code: 0
URI: http://www.facebook.com/?ref=home
Message: HTML Parsing Error: Unable to modify the parent container element before the child element is closed (KB927917)
Line: 0
Char: 0
Code: 0
Jul 18, 2009 | Microsoft Internet Explorer 8
Leak out of the from of the ice machine - flashing p1
P1 means a problem with your drain. Most of the time its a kink in the line. Double check your drain line or it could even be a bad drain pump.
Mar 18, 2009 | U-Line CO2075F-B Echelon Refrigerator Ice...
Kitchen Appliances - Others Logo
55 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
