Question about Jeep Heavy Duty Jxsl10 Rechargeable Spotlight Flashlight Light Needs Battery
I just picked up a Jeep Floodlight model #JXSL10 at a yard sale. Needs a replacement bulb.....any ideas what bulb to purchase?
2000 rhd jeep Cherokee spt fried the wiring harness from the tranny up to the plug next to tran dip stick,i cant find any info to buy a replacement its not available at the dealer Lhd is different
Simple, contact every local scrap yard in your area, ask about the year, make model of your jeep, if they have one or more, then go salvage the harness, maybe pick up two while you are there. Be careful that you don`t damage clips etc. they too are hard to findreplace OEM.
Oct 02, 2015 | Jeep Cars & Trucks
Someone gave me a emachinine tower model t1742 no cords
I have purchased many different computer cords from stores, flea markets, and yard sales. Sometimes, you can find a small computer repair shop in your local area that will help you with the cords you might need and if you are really lucky, they might give you one or at least have a used cord to sell you. I know power cables can run 10 to 25 dollars retail, but I have purchased them for a little as a dollar from yard sales.
Mar 04, 2014 | E-Machines eMachines Desktop PC
BATTERIES FOR MODEL JXSL10
Just take battery out and match it with the same type-12 volt sealed lead acid battery-I think mine cost 30$ online. I haven't had luck finding a replacement bulb. That is what my spotlight needs!
Dec 03, 2013 | Jeep Heavy Duty Jxsl10 Rechargeable...
Matching older RCA TV to Sony Universal Remote - Need RMA code
go please to www.fitness.manualsonline.com or www. remotecodelist.com
God bless you
Jul 02, 2012 | Televison & Video
I have a 2000 Jeep Grand Cherokee and the brake lights are not engaging. I have changed out the brake stop switch, the center brake light bulb was melted and I changed that bulb out and it works when I...
Remove the bulb & use a volt meter to check for power. Harbor Freight has a digital volt meter on sale for right now for $ 3.00. Carefully touch the red probe to the connection in the bottom of the socket & the other to a good ground on the body. Have someone step on the brake, if you have power the problem is the socket ground, the metal connector on the side of the inside of the socket. With a pair of needle nose pliers you should be able to remove the connector to clean it & inspect it for corrosion. If it can't be cleaned to get a proper connection you may check a wrecking yard for a replacement. They can also be purchased at a dealer's parts house.
Jul 20, 2011 | 1993 Jeep Grand Cherokee
I have a 1995 dodge dakota 4X4 and the rear license plate bulb holder, the metal piece over the glass are both corroded. How can I get replacements
The nearest salvage yard is your cheapest and best bet. That model should be plentiful to choose from. Not becaue it is a troublesome vehicle but because there is lots of them out there. You should have your pick of the best parts available. If you have a pick-a- part wrecking yard where you take it off your self then this will be the most cost effective. Good Luck, The Raz
Apr 17, 2010 | 1995 Dodge Dakota
Tial light bulbs keep blowing
Yes, you can replace the socket. Pick up the socket a t your local auto parts store and splice into the wires, or go to your local recycle yard and purchase a tail lamp wire harness and just plug it in.
Jun 01, 2009 | 2001 Pontiac Grand Am SE
Worth the purchase
You can also check for used engines at this database for local salvage yards:
http://www.car-part.com/
Apr 08, 2009 | 1998 Dodge Dakota
Yard sale purchase wiht no manual. Need basic
Most of the manuals are available online at www.cuisinart.com
There is a model # located on the bottom of the coffee maker in tiny microscopic writing that is the same color as the material. Just go to the Cuisinart website and enter your model #. Or, tell us your exact model #, and we will give you a direct link to the manual.
-Tha Mp3 Doctor
Mar 04, 2009 | Cuisinart Coffee Makers & Espresso...
Jeep Heavy Duty Jxsl10 Rechargeable Spotlight Flashlight Light Needs Battery Logo
91 people viewed this question
Top Jeep Camping, Backpacking & Hiking Experts
weirdtop
Tom Chichester
Are you a Jeep Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
