Question about Canon Office Equipment & Supplies
Cannon pixma mx922 paper jam - Canon Office Equipment & Supplies
I had a very bad jam (paper tore...you know the drill...see upper panel). My wife and I used a chopstick and hemostats to gently, gently lift the rollers and ease the paper out (lower panel...most of the paper has been pulled out). The stick should be applied to the support between the rollers. You have to go from roller-pair to roller-pair, easing the paper out without ripping it.
Posted on Aug 13, 2014
SOURCE: says paper jam but there is none. pixma mp450
Take any paper out of the paper feeder and get a plastic ruler the softer the better lift the top of the printer up so you can see where the print cartridges are now push the ruler down through the paper feed roller be careful because you could break the rollers go from left to right right to left twice and check for any debris once you have done this unplug the printer for about 20 seconds then plug back in and let it reset then try copying or printing a doc and see how you go!
Posted on Mar 11, 2009
SOURCE: Paper Jam
I have just had the same problem on one of these Canon MF4150 machines.
The manufactures warranty on our machine had expired just one week before this happened so I had to fix this myself.
The problem we had (which is very likely to be the same cause as yours) is when we removed some torn jammed paper, it had somehow pulled off a spring from inside the machine. The spring was linked to the paper jam sensor.
It does involve a LOT of work to fix it, and unless you are very 'techy' it may be quite a difficult task to do this for the 'average' person.
I had to completely disassemble the machine: Take off the front first (lift up the cover and there is 2 screws at the front and 2 clips on the bottom of the machine) Then remove the 2sides and finally the top (screws should be easy to see, to get the sides off, un-clip along the front edges and gently move them outwards and slide them backwards to release the clips on the back) being careful with the wires going to the scanner part). Then look for the fuser unit which is near the top at the back, there is a black rounded cover over the fuser. To remove the cover, look for 2 small clips one at each side and unclip the cover and gently lift upwards.  Under the cover on the left side you will see a small plastic rod which goes from the left side to a small tab in the middle, if you look about half way along that rod you should see a tiny spring, make sure this is clipped on properly and that you are able to rotate the rod and it should spring back to the proper position when you let go.
Once this is done, put it all back together again and it should work fine.
I'm sure a lot of other people probably have this same problem too so I hope this helps someone.
Posted on Sep 09, 2008
SOURCE: paper jam problem in pixma mp145. E3 error.
I have trying resseting and the error message does not clear. I have checked the printer througly and there is no paper jam.
Posted on Nov 29, 2008
  • 52 Answers
hi
just recently had these problems
symptoms:
LED flashing E3 code and alarm light was solid. But dissapeared when opened the coved and came back on when closed the cover.
Also the when the cover was open the inks did not slide out to the left and stayed to the right side.
There was no paper jam, but error said paper jam.
Solution:
1. I took a thick piece of paper, from like a paper folder ones, thick enough to go in the printer and not curl up when pushed..
2. turned off the printer and turned it back on.
3, while printer was turning on,and makings sound as it does normally when turning on, I pushed through the piece of paper and the rotors stoped for a millisecond.
4.the rotors started again and pushed out the paper by it self with out my force.
5. I let the printer get started. and then turned it off and then on.
6. this solved all of my problems.
this was the first problem ever with this printer in 3 years.,preety good printer.
Posted on Nov 04, 2009
pineworks
  • 4041 Answers
SOURCE: My cannon pixma ip 1600 keeps giving an error
Hello there
You may not see a paper jam, so this is worth trying.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 25, 2010
Replace rear entry to printer after paper jam
You have to push it back until you hear the click of the correct position :)
Jul 23, 2016 | Canon Pixma MX922
Color photos are really off color.
Hi George!
Are using Genuine Canon Ink & Paper?
Here are some links to your printer troubleshooting videos etc.
Canon Support Drivers PIXMA MX922
Jun 30, 2015 | Canon Pixma MX922
False paper jam error code 1311.
Don't shake printer. Check top panel front panel and rear panel. The switches have to click to reset so it all jaded to be opened regardless if you know there is no paper inside. Clean the paper dust with alcohol to get the paper dust off.
Jun 01, 2015 | Canon Pixma MX922
How do I clear a paper jam
http://printermanualndriver.com/search/how-to-clear-paper-jam-in-canon-mx922/ Chk here
Feb 03, 2015 | Canon Pixma MX922
How do I get a paper conformation for faxes on a cannon mx922
From page 98 of the fax users manual:
"This report is printed after each fax reception.
• At the time of purchase, the machine is set so that RX REPORT is not printed at all.
You can set the machine to print RX REPORT each time it receives a document, or only when an error occurs by selecting RX report in Auto print settings under FAX settings."
You should have the manual on the cd that came with the printer. If not try the link listed.
Canon Consumer Home Office PIXMA MX922
Dec 22, 2014 | Canon PIXMA MX922 Wireless All-in-One...
Paperjam
Some units has a REVERSE position. or Un-plug the unit turn up-side-down and remove the jam with tweezers.
Jul 26, 2014 | Canon Pixma MX922
How do you clear a error code 6000 on a canon pixma printer mx922?
This is a "line Feed Error" signal which can be cause by many things. Most of the time it is the result of a small bit of paper still jammed in the feed rollers,..or someone dropped something in the paper path,...like a paper clip or staple, or rubber band or a cat toy. Open the cover and when the head comes to the center pull out the power cord. Now you can move the carriage to the far left and examine the paper path. Remove the rear turn around door and use a flashlight to examine every part you can see. Use the light to examine the purge unit area looking for a jam. Move the carriage to the far right and use the light to look at the timing disk inside the cover on the far left. It should still be there and vertical.
Jul 15, 2014 | Canon Pixma MX922
How do I take apart canon pima mx922?
There is not a lot that you can do to take these apart. You can start by removing the paper tray. It should pull straight out.
There is also a release to open the printer up. This gives you access to the ink cartridges. You should not see any paper from this perspective but there is a chance that there will be some paper stuck there.
Feb 17, 2014 | Canon PIXMA MX922 Wireless All-in-One...
1,499 people viewed this question
old marine
old marine
