Question about Lavazza Coffee Makers & Espresso Machines
Error 21 lavazza LB2300 - Lavazza Coffee Makers & Espresso Machines
Error code 11 lavazza blue
Lavazza LB 2210 error 82/84
Aug 20, 2013 | Lavazza 2210
My lavazza blue esspresso machine lb2200 displaying error-21
Power down, press and hold language button, power up and the machine should go through a rinse cycle and start heating. That is what I did anyway and the fault cleared .
Mar 01, 2013 | Coffee Makers & Espresso Machines
Need a canadian supplier for lavazza espresso point capsules
Lavazza Products may be ordered online in Canada from the following site:
http://www.espressocoffeeitaliano.com/ourproducts.php
Contact Information:
Espresso Coffee Italiano of Canada Ltd.
(authorized distributor of the Lavazza Espresso Point System)
201 Drumlin Circle, Unit #3, Concord, ON
L4K 3E7, Canad
Tel: 905-907-5049
Fax: 905-760-5606
Email: info@espressocoffeeitaliano.com
Dec 13, 2011 | Lavazza Espresso Point Capsule Machine
Lavazza Espresso point not heating up
The electronic control board is defective, it must be repaired or replaced.
To get a dealer address send an email to: f.vitare@lavazza.it. I could help you, but, I live in Canada. Guru
Nov 15, 2011 | Lavazza Espresso Point Capsule Machine
I hav error 21
I had the same issue with Out of Service 21. The pump was making noise during Self-test, then the error. I took the entire thing apart. I removed the pump, cleaned all the plastic/rubber parts, and reassembled. All seems to work now. The final piece that I cleaned was a tiny black washer inside the bottom portion of the plastic assembly that inserts into the pump solenoid. In the bottom of that piece (about 1/2 threaded) you'll see a star-shaped piece of plastic threaded INSIDE the barrel. I turned that out, cleaned the tiny black washer that blocks the hole, cleaned the spring, and turned the star piece back in. That seems to be what fixed it for me. However, error 21 in the manual indicates ANY issue with water flow.
Apr 24, 2011 | Lavazza LB2210 Aluminum
I have an lavazza 2301 and its says out of servie 21 call service can i fix it by my self or do i need to all a service dude? if i can, how do i fix it?
Aug 11, 2010 | Lavazza LB2210 Aluminum
Lavazza coffee machine will not heat up the coffee
For Lavazza A Modo Mio only call 0800 599 9200 -they can help over the phone or if still no solution they will refer you to Lavazza UK who have the answers for AMM.
Feb 05, 2010 | Lavazza Espresso Point Capsule Machine
Coffee Makers & Espresso Machines Logo
128 people viewed this question
Top Lavazza Coffee Makers & Espresso Machines Experts
ray gallant
nikolay nikolov
Tom Chichester
Are you a Lavazza Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
