Question about Sony BRAVIA Televison & Video
Sony bravia kdl-52nx800 screen half black half green
  • 34 Answers
SOURCE: Sony Bravia KDL-S40A12U Blank screen
Hello
on your set there is inverter board that is what lights up th backlight on your TV making everything visible that board has went bad.
Thankyou
Posted on Jul 28, 2008
  • 4234 Answers
SOURCE: Sony Bravia KDL-40W4500 turns off
This can indicate a problem with the high voltage circuits. Since this is a new set, it should still be under warranty. DO NOT open up the unit as that will void the warranty. Return the set or request warranty service. Note the 8 blinks when you request service as that should allow them to bring the correct replacement parts.
Keep us posted.
Dan
Posted on Jan 05, 2009
  • 20 Answers
SOURCE: I have a Sony Bravia KDL-46Z4100 46' I have a green vertical line
this is probly the lcd control module unfortunatley it comes with a new lcd panel
change these.
Posted on Mar 11, 2009
tvtek
  • 1284 Answers
SOURCE: sony bravia kdl 32l4000 - color bars running vertically on screen
In most cases is the screen is covered with vertical lines all the way accross the screen then the T-Con module is at fault. The t-con board is replaceable without having to replace the entire LCD panel which would usually make it cheaper than replacing the TV. The part number I come up with is 1-857-213-11. Please take a moment to rate my answer. Thanks...
Posted on Dec 02, 2009
SOURCE: sony bravia kdl 46s4100 no picture
it sounds like your back light might be going out. You might be able to fix this by installing a new backlight inverter board.
Posted on Aug 05, 2010
Left half of screen is grey,right side is fine.
The T con Board of the LCD panel is faulty. Can confirm by Replacing the Tcon Board.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
May 15, 2016 | Sony BRAVIA KDL-52NX800 52" 1080p LED-LCD...
After power outage, no Sony logo, half screen turns white.
take it in for repair as the power surge has damaged the electronics on a board
quality surge protectors are the preventative equipment to be used for ALL equipment running electronic controls ( includes fridges and stoves,and air conditioners that plug in
Mar 05, 2016 | Sony BRAVIA KDL-52NX800 52" 1080p LED-LCD...
Picture takes sometimes 5 or more minutes to come on when first powered up screen has gray out effect
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 05, 2015 | Sony Bravia Kdl 52nx800 52 Inch Lcd Tv
Sony 52nx800 has total pink screen, no image, how do I fix?
Faults & possible causes to LCD & Plasma TVs are given with illustrations. You can get an idea about the fault to an extent.
Jan 11, 2015 | Sony BRAVIA KDL-52NX800 52" 1080p LED-LCD...
Bottom half of Sony Bravia TV screen has color distortion
Check for loose contacts in power outlet, RC cable, jack and socket.
In order to ensure, it is not caused by the input device, connect a DVD player and see.
Aug 22, 2012 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Left half of my TV screen is completely white
That is only available to Sony authorized servicers. See esupport.sony.com
Jul 31, 2010 | Sony BRAVIA KDL-52S4100 52 in. HDTV LCD
Screen goed black for half second
Check all ur signal connecttion correctly tight and screws,still happen hit the back cabinet couple times, if it occur ur tv have bad soldier joints or lose connection some where in ur electronic boards.
Aug 12, 2009 | Sony Bravia KDL-40S4100 40 in. LCD TV
Half the screen is black
I think its either the X-sus or Y-Sus Boards which control the display. These are 2 boards with heatsinks on them, lots of capacitors and are at either edge of the screen.
Apr 04, 2009 | Sony BRAVIA KDL-40V3000 Television
Televison & Video Logo
241 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
