Question about Akai PT5598HD 55" Rear Projection HDTV-Ready Television
Samsung rear project colour problem blue and yellow
I have a samsung rear projector and i turned it on the other day and noe it seems like the colours aren;t alined. there is still the main picture but there is a blue shadowed picture and a yellow as well. how do i fix this problem the model number is sp47w 3hf 1x/xsa ???\r\nplease help
  • Anonymous May 17, 2009
    I have the same problem but our TV has shadows of red and blue.  I am thinking it is a bulb that is out.  Our TV is 5.5 years old.
  • 431 Answers
Hi I am vortash sounds like you have a convergence problem and I am guessing you dont have the manual for this set .. there is one available free from http://www.safemanuals.com
this section here deals with the convergence but their are other things in the settings that can cause this so download your own full copy Regards Vortash samsung rear project colour problem blue and yello - e03fb99.jpg
Posted on May 27, 2009
My mistubishi WS-65713 73 inch tv's colours are off. There is mostly blue and green and some colours are non existent like red and yellow. What is the problem?
Sounds like a convergence problem which is common in these sets
This model uses two of the stk394-250 convergence output devices or chips.
Both would have to be replaced.
Mar 12, 2012 | Mitsubishi WS-65813 65" Rear Projection...
I have a VT465 and the projection back ground is yellow and I can't get it to be white
If you are talking about the actual image that is coming from a laptop being yellow instead of white, then this is caused usually by a bad signal cable running between the computer and the projector.
To be more specific: All colours in a projector get made up in some way between red, green and blue. White is all of these colours at maximum, yellow is made by red and green at maximum but no blue. If your image is Yellow when it should be white, then the blue signal information is not reaching the projector. This can also happen within the projector or computer itself but is less likely. If your using a VGA cable (15 pin cable) then blue is run through pins 3 & 7 (positive and negative respectively), see if your cable is either missing these pins on either end or if they are bent, although it's more than likely within the cable itself. You can test this theory easily by trying to put something blue on screen, if the blue signal isn't getting through then it'll appear black.
If changing the cable doesn't solve the problem try testing the computer by trying to use a different one, and test the projector by plugging in a monitor or another projector.
If you are getting a yellow screen without sending signal and just trying to get the "no signal" or "no input" screen white, then this won't be the case.
Mar 24, 2011 | NEC Office Equipment & Supplies
BLUE SHADOW
Replace optical block Call Encompass Parts
1-800-638-3328
Jan 18, 2010 | Samsung HCN4226W 42" Rear Projection...
Colour has screwed up
Call Encompass Parts Distrubtion 1-800-638-3328 its either your DMD board 180.00 or Light Engine and they do not have any in stock Cost $1,056.00 Try UED 1-800-648-6657>
Dec 31, 2009 | Samsung HLN5065W 50" Rear Projection...
Picture is OK, but colors are off and there is a blue star background that shows on dark colors.
Hello, With most rear projections there is usually an alignment to do with the set up with your TV. This is so the red, blue and green projectors align together to give the correct colouring. This sounds to me what may be causing the outlining of the blue. This can also make it seem off colour. Look in the set up menu of the tv and see if you can find this alignment feature. Usually a cross will appear and you move a blue, red, and green cross with the arrows on your remote to align over the original white one. If this does not work, it may also mean that one of your projectors, that is the red, blue or green one may be failing causing the off colouring. Hopefully this alignment may fix it for you.
Oct 26, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
The colour on my samsung rear projector out of line how do i fix
Sounds like the convergence chip needs to be replaced. You need a good soldering gun and a steady hand. i believe the kits come with full detailed instructions on replacing the chip.
you can get the kit at www.tvrepairkits.com
Apr 24, 2009 | Samsung HCM4216W 42" Rear Projection...
My tv has lost its colour, and its green or yellow sometimes.
Okay that means the other GUNS went out when i refer to guns I mean the other blue and red, they need to be replaced pretty costly but if you value that TV I'd do it.
Apr 22, 2009 | Samsung HCN4226W 42" Rear Projection...
Colour problems with projector
In short If the reds show as red, The greens show as green & Blue shows as blue. I would say thats as good as it can project. It's hard to judge color without seeing it for ones self but usually DLP projectors that use a colorwheel do not have perfect color.
Feb 13, 2008 | Office Equipment & Supplies
Color going
your colour guns (that's what they call the light tubes that produce the 3 main colours, red/green/blue) need to be fixed. One or two of your guns need to have the liquid that protects the lens flushed out. I had the same thing and the repair man came in took the unit apart and removed one of my light guns (blue one) and showed me the dis-coloured liquid. He drained the liquid and added new clear liquid which protects the heating of the gun and everything was perfect again.
Oct 17, 2007 | Samsung PCL541R 54" Rear Projection...
Akai PT5598HD 55" Rear Projection HDTV-Ready Television Logo
190 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
