Question about Kidkraft My Sweet Vanity and Stool 13017 New
2000 Mazda mpv could start without the dash assembly and speedometer
My 2005 mpv mazda van meter on the dash board keeps going off and on
I think your saying the speedometer is working then not working as that could be the speedometer cable is broke/damaged and just buy on and install.
May 08, 2014 | Mazda MPV Cars & Trucks
I had my 2000 Mazda MPV jump started after I left my lights on and killed the battery. The next day my radio and speedometer are not working and I have to manually shift my car to get it moving and it...
I think it may be an electrical issue but I think it's just a fuse. There are 2 fuses I would check. One of them is a 15 amp fuse inside the fuse panel inside the vehicle (see fuse layout below) and the other is a 40 amp fuse in the fuse panel under the hood of the vehicle in the engine compartment (see other picture below). I marked the fuses to check and hope this is the problem.
Mar 19, 2012 | 2000 Mazda MPV
My 1997 Mazda MPV Hold light keeps flashing
There is a speed sensor for the transmission inside the speedometer gauge.
if the speedometer cable is broken the hold light will blink. indicating a trans
malfunction code and the transmission will not work properly.
do not drive too long without a speedometer cable.
May 01, 2011 | 1997 Mazda MPV
1999 Mpv hold light flashing and speedometer stop working, change speedometer and still same problem..????
Hello your speed sensor is malfunctioning this is connected to your speedometer.this is usually located on the top of your transmission 10mm 0r 3/8 bolt single plug this will restore your vehicle speedometer.
Feb 04, 2011 | 2000 Mazda MPV
Mazda mpv 2000 front passenger door is jammed shut. All the locks unlock besides that one. can't open the door. Mechanic said they must break panel from inside. How can I get the door to open without...
Your latch assembly may be frozen, or the door actuator faulty (a common problem on this vehicle).
Check out the following forum posts:
The basic problem:
http://forum.mpvclub.com/viewtopic.php?t=24351&highlight=door+actuator
Photos of the latch assembly:
http://forum.mpvclub.com/viewtopic.php?t=16431&highlight=panel+door+locked
How to disassemble the door panel (if you can open the door!):
http://www.mpvclub.com/diy.php?id=8
Aug 01, 2010 | 2000 Mazda MPV
2000 Mazda MPV My check engine light has come on and it won't start. I have checked the fuses, any ideas?
Check the battery and try to jumpstart your car. Or borrow an OBD II scanner and plug it in to the connection under the dash/steering wheel area and see what the error code, problem is.
Mar 14, 2010 | 2000 Mazda MPV
Mazda 2000 mpv does not start
Couple of things it could be.
Try turning it over without touching the gas pedal. Sounds like you flooded it.
Check the coil and engine management sytem. Its probably that.
Nov 04, 2009 | 2000 Mazda MPV
Hi in need of a wiring diagram fuse box Mazda bongo
look here: http://www.bongoforum.co.uk/forum/Blah.pl?
Apr 07, 2009 | 1997 Mazda MPV
Kidkraft My Sweet Vanity and Stool 13017 New Logo
16 people viewed this question
Top Kidkraft Toys Experts
john h
Module Fixer
ray gallant
Are you a Kidkraft Toy Expert? Answer questions, earn points and help others
