Question about John Deere Garden
My john deer jx75 turns over when you try to start it , but wont start up
  • 130 Answers
SOURCE: my john deere jx75 lawn mower won't start up.
There's a lot of safety features on tractors. Your owners manual would be the best place to check. I'll throw out a common spring time start up issue: dead battery. If you didn't have it on a trickle charger over the winter, tractor batteries die in 2 or 3 years. If it has started recently, check for a blown fuse.
For safety features, make sure you're sitting in the seat, brake on, clutch fully depressed, and any attachments (blades) disengaged.
Posted on May 02, 2009
  • 69 Answers
SOURCE: JOHN DEERE 318 LAWN TRACTOR WONT START
ok, since you have the points, I assume you have the B43g Onan
engine. Was it running before the new parts were installed?
Check your point gap and make sure it is .016, plugs ahould be gapped at .025 Make sure your plug wires are good too. Should be somewhere between 0 and 10,000 ohms per foot, when measured with an ohmmeter. Once everything is rechecked for gap distance, make sure there is no spark by pulling plug out, leaving wire on and ground the outside of plug to the chassis of the tractor.
Crank over and look for the spark. Coils are about $100, so you want to eliminate everything else first.
Diagnosing a points ignition for no spark is really simple. Do you have 12V at the coil? Do you get a spark when you connect and disconnect the negative terminal of the coil to ground? If not you have a bad coil.
Posted on May 19, 2009
SOURCE: I have a lx 255 john deere wont start
You have a defective ignation coil. When the engine gets hot, the winding in the coil opens and the engine stops. After it cools down, it will again make contact and start again. If you don't know where the coil is, follow the wire from the spark plug. The spark plug wire is attached to the coil from the factory. It's easy to replace with a 1/4 inch socket set. Set the magnet to coil gap with a standard business card.
Posted on Jul 27, 2009
harlan301
  • 205 Answers
SOURCE: john deer 310 g wont start after it sitts a day
if its turning over check your spark. if you have spark remove the air cleaner and spray some carburetor cleaner to see if it start than stops- let me know
Posted on Oct 14, 2009
nova2nv
  • 197 Answers
SOURCE: John Deere 425 AWS no start, no nothing???
If engine cranks over and have no spark try a time delay module located under thermostat housing.
Posted on Nov 13, 2009
NEED HELP WITH THE "BLADE BRAKE CLUTCH CONTROL" ON A JOHN DEERE JX75 WALK-BEHIND MOWER.
Don't worry I'm sure you will get the solution of your problem, just check the link I attach.
Best Manuals
May 23, 2017 | John Deere Garden
John deere L110. Battery is good it will not turn over. I think it is the solinoid. any advise?
might try another battery, if the amps are down in it it wont start. could be a safety switch. or connection. if the solenoid is clicking you might replace it. they are like $12.00
Apr 15, 2017 | John Deere Garden
Wont start light dont work
If choked off. Pull a spark plug. May be full of gas.
Apr 03, 2014 | John Deere Garden
My jd jx75 shakes excessively w/o the blade engaged.
Make sure the motor is mounted tight to the frame.Thank you for asking and I hope this helps you.Please leave me a 4 thumbs up.
Jul 16, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John deer 310 g wont start after it sitts a day
Oct 13, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John deere stx38 wont move transmission locked up?
Engine OFF, raise drive wheels and check if transmission is locked
Jul 14, 2009 | John Deere Garden
My john deere jx75 lawn mower won't start up.
May 02, 2009 | John Deere A,b,g Tractor Carburetor Float...
Garden Logo
18 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
