Question about OKI C3200n Led Printer
Tevion 3200 dpi scanner
Software driver
Tevion 50615 drivers
Well, my best guess is that you will not get them. To run the Tevion, you probably will have to use XP mode in Windows 7. Even then, it may be a challenge to find a driver. The usual practice in to check the manufacturer's site for drivers. Sadly, Tevion does not appear to have a website. I supply an address below to its parent company.
I have found a page purportedly with software for a Tevion scanning device. But, I am so doubtful to the authenticity of the site I would not download it on my system to try out without totally backing up my system and expecting to have to restore my system from an iso file consequently. Yes, I would pre-judge the file to be sheer trouble. But it is the only one I have found.
http://ryouri-gourmet.com/tevion-film-strip-scanner/
Tevion are part of Medion Australia Pty Ltd
Level 6, 35 Chandos Street St Leonards NSW 2065
Ph 1300 884 987 M-F 8.30am to 6.30pm (EST)
email: australia@medion.com
Feb 21, 2015 | Computers & Internet
I have a tevion film strip scanner suitable for software Windows XP and Vista but my new laptop is Windows 7 and now it won't work. Can I download the software to use the scanner with my new l
Most things that worked fine with Windows XP and or Vista, can fail with Windows 7 and 8, because the factory that made the hardware in the first place does not ask for certification with Microsoft for their old Hardware. They only spend time and money to get their new hardware certified on the new operating systems.
So if you manage to get any driver, just test it. The software that came with your scanner should work. (At least in the XP compatible mode)
The next thing you can try is to download any free ware scanner software. Perhaps you can get a trail version of SilverFast, for your scanner. As soon as you have to pay for the software, think of buying a new scanner, because sometimes a Windows 7 or 8 compatible film scanner is cheaper than the software.
The SilverFast software starts at 59 dollar, (not even sure they have a compatible package for your scanner) My pro version costs already 300. But perhaps you can download a trail version there to see if it works for you. (Perhaps if you remove the software or stop using when you have to pay for it, the driver keeps working??)
Nov 30, 2014 | Office Equipment & Supplies
How do I change dpi setting
Printers are basically slaves to the software and the drivers that connect the printer to the computer. Increase the dpi in the computer program and then check the printer driver for max dpi setting.
Sep 22, 2014 | HP Officejet Pro 8600 Plus e-All-in-One -...
How do I change the dpi settings on my thermal take mouse?
The buttons on the top(under the scroll) are default for changing DPI. If you can't change DPI from them, install the software for your mouse and open it. You can customise your DPI from there.
Jul 24, 2014 | Thermaltake Tt eSports Element Gaming...
Download new driver for mouse
I;d expect this to work with the standard usb driver. The dpi is adjusted from beneath ((1600 dpi--blue; 3200 dpi--purple; 5000 dpi--red) and weights inserted from the box - purely mechanical. If it is not operational, my guess would be a problem with the usb lead or with the standard usb drivers of your machine. Check for this latter with any other usb connected item that should be usable from the same port.
If repairing the usb lead itself replace it with a cheap usb lead; these are obtainable in most stores now, including supermarkets, and replacement will be easier than an attempt at repair.
Nov 10, 2013 | Rosewill RM-5000L 5000 DPI Laser Gaming...
When I find driver xp for scanner acer s2w 3300u
I've searched high and low and the best looking solution I can find for you is a program/drivers called VueScan.
http://www.hamrick.com/
It's release notes say it works with your scanner without the need for any benQ or Acer software.
Worth a try!!
Jul 26, 2008 | Acer Scan to Web 3300U Flatbed Scanner
I have lost my CD for Tevion flatbed 3200 6400 dpi ccd how can I download the drive.
Here is a place that has drivers for your product
http://www.medionusa.com/
From what I have read this company makes your product and the serial number will take you to the driver
Apr 15, 2008 | Office Equipment & Supplies
OKI C3200n Led Printer Logo
95 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
