Question about Acer Aspire Z5700 PC Desktop
Cd/dvd drive rejecting discs as soon as inserted
5 Suggested Answers
Drawsalot
  • 38 Answers
SOURCE: do not read the cd or dvd disc.
Two possibilities that are immediately apparent. One, the lens on the drive is dirty. Stop by a department store and buy a CD/DVD laser lens cleaner CD and put it in the drive several times, making sure that it tries to read it each time. This can brush away the debris on the lens and it may work again. Two, the drive motor or lens assembly (that moves) has failed. My experience is that these drives have a 2-3 year life span. Luckily, they are now bargain-priced and you can pick them up at your local discount store and replace them yourself.
Posted on Nov 12, 2007
SOURCE: cd/dvd drive problem
Try with another brand of disk; the Matsushita UJ870 drive of our 5315 burn my Sony CD's but not my Philips CD's (my Compaq V2617LA with an older Matsushita UJ840 drive has burned Phillips CD's in the last two monts)... Remember: CD and DVD lassers are different. I think because of that, i haven't see problems with Sony, Philips and Samsung DVD's... only with CD's...
Posted on Jul 07, 2008
techniwiz
  • 275 Answers
SOURCE: ACER 4520 CD-RW/DVD-ROM its pops up insert disc
you can try two solutions
1) go to device manager and uninstall the primary and secondary ide controller under the IDE ATA/ATAPI controllers and than restart the system and than chk it if that works out
2 ) if the first option doesnt work try to update the firmware of the drive
Posted on Oct 31, 2008
benwabnick
  • 2404 Answers
SOURCE: my acer 4620z isnt readivn the cd/dvd drive
take a slightly damp q-tip and wipe down the laser in your drive. after this then try several dvd's and cd's and see if the drive will play them.
If after this it doesn't then the drive is bad and will need to be replaced cause the laser is bad and can't read discs properly.
Posted on May 18, 2009
CD/DVD rom in laptop not working
The drive could be defective.
Dec 28, 2013 | Computers & Internet
Mini cd wont load in dvd drive
try cleaning the lens with a q-tip and alcohol
Apr 22, 2012 | Toshiba Computers & Internet
Cd software disc will not load on to my computer. Isn't being recognized
If in case the cd was not recognized upon loading it to the computer you may do the following to check wether the cd is faulty or the cd drive.
  1. Verify that the correct disc (CD/DVD) is used when prompted to insert the disc.
  2. For programs on DVD, verify that the drive containing the DVD is a DVD drive and not a CD-ROM drive. Most DVD drives will have DVD printed on the front of the drive. For programs on DVD, consider the following:
  • DVD drives can read both DVD's and CD's.
  • CD-ROM drives can read only CD's.
  1. If multiple disc drives (e.g., CD-ROM and CD-RW, or DVD and DVD-RW, or CD-ROM and DVD-RW, etc.) exist on the computer that can read the disc (refer to the items under Step 2), insert the CD or DVD into the other drive and try the program again.
  2. If you are attempting to install a program and the installation does not begin after inserting the CD/DVD into the proper drive, refer to the program's instructions for the installation procedure.
  3. Clean the CD/DVD in the following manner:
  1. Place a small amount of nonabrasive liquid soap on the shiny side of the CD/DVD.
  2. Using your fingertips and warm water, gently rub the soap on the CD/DVD in a circular motion.
  3. Rinse the CD/DVD thoroughly and dry it using a clean, soft T-shirt or lint-free towel. (Do not use paper towels or tissue paper.)
  1. Try to use a different CD or DVD in the drive to see if that disc can be read.
  2. If possible, insert the problem CD or DVD into the DVD or CD drive of another computer to see if the issue persists.
Mar 16, 2011 | Logitech C500 Up to 1280 x 1024 pixels 30...
Rejecting blank discs. roxio will copy a disc then reject the blank disc inserted whatever the format. repetedly asks ----- please insert blank disc.
hi,
You need to update the Roxio program to bypass this problem.
or you can get the the lastest version of the program.
Sep 09, 2010 | Roxio Easy CD & DVD Creator 6...
DVDs I burn will not play on other players. Players reject disc
Check that the burner is finalizing the discs. This can be set in Roxio or in the optical drive properties. In Windows 7, right click on the optical drive, choose Properties, then the Recording tab. Then the Global settings lets you choose to finalize the disc on eject. Try a different brand of DVD+R and check that the other players support DVD+R discs. (I know some DVD players only support DVD-R.)
I hope this helps.
Apr 15, 2010 | Roxio Easy CD & DVD Burning
I put in a blank cd and I cannot burn it because in my computer it shows that there is no cd inserted
Here you go...I hope this works for you....
CD/DVD Is Not Recognized
spacer.gif spacer.gif spacer.gif spacer.gif Many times, after inserting a disc into the CD or DVD drive, the disc is not recognized by that drive. CD-read and DVD-read issues can be caused by many sources. Perform the procedures presented in this General Computer Advice article when troubleshooting CD-read and DVD-read issues.
Begin with the first procedure and continue through the list. Try using the CD or DVD after each procedure is completed. For any procedure that requires changing current system settings, record the original settings before completing the procedure.
  2. For programs on DVD, verify that the drive containing the DVD is a DVD drive and not a CD-ROM drive. Most DVD drives will haveDVD printed on the front of the drive. For programs on DVD, consider the following:
Apr 01, 2010 | LG GSA-H55N DVD-RAM Burner
Do not recognize any cd/dvd in dell vostro 1510 bios A13
i have dell vostro 1510 labtop < bought from SA 2 y ago, dvd rom not work, always rejected when inserted, also bluetooth and toutch pad not recognized, i use windows 7
find me a solution
Jan 24, 2009 | Dell DVD-rom DVD Drive
Laptop Disk Drive want reject.
If you mean the CD or DVD drive,,,then you can take a paper clip and bend it straight,,then put the paper clip into the tiny hole in the front of the CD tray and gently push,,,this will open the tray enough for you to grip it by hand and pull it out the rest of the way.
Jan 19, 2009 | Sony (DW-D56A-10/20) (DWD56A1020) DVD...
Dvd burner is not recognized by windows XP sp2 when blank media inserted to burn a movie.
well u need to check for the latest software available for your dvd drive try and find the latest software on net according to your company,and check wether the software ur using comaptible with ur windows
Jan 23, 2008 | Computers & Internet
Acer Aspire Z5700 PC Desktop Logo
29 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
