Question about Skeetervac SV-3100 Mosquito Exterminator
Skeetervac sv2000 skeeter vac engine won'T STAY RUNNING help fbrandt@centurytel.net
2 Suggested Answers
grueck
SOURCE: my skeeter vac will not stay lit but gets lots of gas
If it lights, use a c-clamp or something to keep the fuel button pressed in until it will stay lit without the button pressed. This took me 3 hours before it would finally keep running normally. If that doesn't work, the jet and engine chamber might need cleaning. This takes some additional work and you may need to make a new fiberglass gasket since the original one falls apart after a few seasons.
Posted on Jun 13, 2012
Car won't stay running
If the problem only happens when the engine is cold, a bad electric sensor is likely to blame. If the car stalls even when the engine is warm, the cause is likely a faulty electric fuel pump.
Why is it that my car starts but won't stay running? ' Reference.com
https://www.reference.com/vehicles/car-starts-won-t-stay-running-6449388a9326285d Car won stay running Google Search
Dec 15, 2016 | Cars & Trucks
New filter new fuel pump won't stay running
Well your engine has a carb, so it could be dirt in the carb, or a vac leak, or several other possible causes.
Does the choke close when the engine is first started ? Have you checked the fuel line to see if the pump is providing gas ?
Apr 25, 2013 | 1987 Dodge Raider
My skeeter vac will not stay lit but gets lots of gas
May 13, 2012 | Skeetervac SV-3100 Mosquito Exterminator
My craftsman 32cc leaf blower won't stay running
Check age of gas. Cannot be more than 30 days old.
Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage.May need to clean or replace carburetor.
Nov 06, 2011 | Craftsman 4 Cycle Blower/Vac
Car back fires in the engine and wont stay running after a few tries it will but stalls then turn key and runs ok untill its cold again?anyone have a clue??? plugs have been changed and check engine light...
Most probably the vac is leaked. Spray some carb cleaner at the intake (while the engine is running) and see if the sound changes after addinh the carb cleaner. If it still misfires add some more carb cleaner to clean the nozzles of the MPFI system. it should help.......sodeep
Jun 23, 2009 | 2003 Kia Spectra
Won`t stay running after it warms up not overheating
is it carb, or efi ? and what size engin?
May 30, 2009 | 1985 Ford F 250
Trying to use SpeedStream 5100 with new DSL Provider
I have Centurytel myself, so maybe I can help:
A link to your Speedstream 5100 router:
http://www2.windstream.net/downloads/links/SpeedStream211.pdf
And the typical setup for the westell 6100 that centurytel uses:
Centurytel will provide you with your username and password.
PPPoE Configuration:
VPI 8
VCI 35
Protocol: PPPoE
Hope this helps.
Jun 12, 2008 | Efficient Networks SpeedStream 5100 Modem
POP3 server has not responded in 60sec. A timeout has occurred while communicating with acct. centurytel.net
could be a number of problems.
To test this I tried to telnet to mail.centurytel.net on port 110 and it did not work. Of course this is assuming that the incoming pop3 is set to: mail.centurytel.net
If it is possible that the MX record is not set to point to the right IP which is:
mx3c35.carrierzone.com internet address = 209.235.147.40
mx4c35.carrierzone.com internet address = 209.235.147.41
mx1c35.carrierzone.com internet address = 209.235.147.38
I would suggest that you contact the hosting provider and ask then to look into the reason telnet is not working.
Jan 27, 2008 | Computers & Internet
Ge Electric Double oVen
This may be related to a problem I have helped others solve. The solution is available free at my website. I have at last count helped over 1000 oven owners with a similar problem. http://fp1.centurytel.net/Powerman/Dreaded%20F7%20Problem.pdf Hope it works for you too.
Aug 09, 2007 | GE JKP45 Electric Double Oven
Skeetervac SV-3100 Mosquito Exterminator Logo
409 people viewed this question
Top Skeetervac Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Skeetervac Pool and Spa Expert? Answer questions, earn points and help others
