Question about Gear Head mp2850blk mp2850blk
I have a 2.4 g wireless mouse model number MP2850
I have a 2.4 g wireless mouse model number MP2850 that will turn on but then turns off two or three seconds after powering on. It turns off seconds after i turn the switch on but i found that if i turn it on and then immediately swipe a finger over the sensor it stays on. My problem is that it doesn't do anything on my iMac even after putting in the nano receiver in the usb port. Nothing happens even when i get the light to stay on. I tried a windows computer as well and the driver installs itself but the mouse wont move as much as I try to make it do so. Is there any way to get it working?
3 Suggested Answers
customers184
  • 154 Answers
SOURCE: Mouse won't install
You may need to check your BIOS setting. The mouse be disabled there. You can access the BIOS thru the boot menu when your computer frist starts up. If the mouse is active as a usable feature, then you may have to a hard boot of your operating system with the OS(Windows Vista, XP, 2000, etc.) Cd you recieved with the computer. If that does not work, then you will have to a complete reinstall of your operating system.
Posted on Dec 06, 2009
SOURCE: My mouse won't stay on. I've been using a
I have a Mac and I took out the interface hub, and took out the batteries. Then I replaced the interface hub and while replacing the batteries I held down the command key. It worked. I got this idea because I found an answer for PC that said to hold down the key that has two arrows making a circle. Mac doesn't have that key so I used the command. All I can say is that it worked for mine
Posted on Nov 03, 2012
Mouse keeps turning off
Hi if the the mouse keeps turning off then there might be a prob with the power source on the mouse (i.e battery),change the battery if havent done that or check the contacts for the battery inside the mouse. If all this fails and issue doesnt affect the keyboard,it might be the prob with the mouse itself. Hope this will help you. Cheers
May 04, 2013 | A4tech Computers & Internet
How to fix a gear head MP2850 wireless mouse that turns on then off
So i just bought on of these mouses, I had heard they were good for what they are but i am having similar problems. It turns off seconds after i turn the switch on but i found that if i turn it on and then immediately swipe a finger over the sensor it stays on. (weird right) You may want to try that and see if it works. Now my problem is that it doesn't do anything or my macbook pro doesn't see the mouse. Nothing happens even when i get the light to stay on.
Mar 18, 2012 | Gear Head Computers & Internet
How do I setup a wireless mouse on a desktop
To setup a wireless mouse regardless of its type, do the following:
1. Insert the USB transmitter (this could look like a mini plug or a stick) and wait for windows to complete installation.
2. Once this is successful, turn on the mouse by holding down the power button. Or insert the disc that came with the mouse and run the installer. The installer will install the device drivers and setup your mouse's configuration panel which will reside in your system tray.
Make sure that the mouse has batteries and that it is switched on for it to work. It will glow red when it is switched on.
Jul 06, 2011 | Gigabyte Wireless Optical USB Mouse GMW7C
Hi there, I've got a Toshiba mouse, model number
Maybe mouse needs new batteries.
Take that "Small(wireless) part and put try it in another usb port
Aug 25, 2017 | Toshiba C99704 Mouse
Does the labtec wireless mouse turn itself off when not in use
You should always safely shut down and turn off your computer before plugging or unplugging the mouse from the PS/2 mouse port. If you do not safely turn off your computer, you may damage the mouse port, the mouse, or both.
Your Labtec mouse should detect and function by simply connecting it to the computer´s PS/2 mouse port or USB port. If you have 3 Button Labtec Mouse (M/N: M-CAC64), your mouse will work in the PS/2 and serial port with the supplied adaptor. If you are using the 3 Button Labtec mouse, we recommend using the PS/2 port. To determine the model number of your device, turn it upside down and look at the label. Model numbers are indicated by "M/N:". This will help you determine what system ports your Labtec mouse can be connected to.
Thank you
Mar 14, 2010 | Labtec Wireless Desktop Keyboard/Mouse...
My Kensington wireless keyboard (Ci70) just stopped working. I have no idea why. The mouse works just fine. XP Pro SP 3. Have rebooted. Unplugged the USB interface device. Plugged back in. Rebooted....
Replace batteries in keyboard and re-sync the devices
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>- --> Synching Mouse or Keyboard with Wireless Optical Desktop trnsp.gif Question My mouse or keyboard doesn't work with my Wireless Optical Desktop (Model Number: 64373). What's wrong and how do I fix this problem? trnsp.gif Answer Your mouse or keyboard has lost its sychronization with the Wireless Optical Desktop, which can occur after changing the batteries, for example.
To synchronize your wireless device with its receiver:
  1. Move the device within three (3) feet of the receiver.
  2. Press the button on the receiver.
    If the receiver has an LED, the light blinks.
  3. Within ten (10) seconds, press the button on the underside of your wireless device.
    If the receiver has an LED, the light glows solidly when synchronization is successful.
Early production units of some wireless devices may require repeating the above instructions two or three times.
Timing, distance, and objects impeding the wireless signal may influence your success. While usually unnecessary, some customers have reported better results by:
  • Holding the wireless device very close, within three (3) inches of the receiver.
  • Entirely ignoring the receiver's light.
  • Simultaneously holding the buttons on both the receiver and the device for from ten (10) to twenty (20) seconds.
Dec 12, 2009 | Kensington Computers & Internet
I have microsoft bluetooth optical mouse 4000 it suddenly stopped connecting to the receiver, as I cannot move mouse anymore
Just to clarify, this is a wireless optical mouse, right? Please try the steps below:
1. Use fresh batteries.
2. Make sure that the mouse is turned on.
3. Check if there's a connect button on the wireless receiver and underneath the mouse. If there is, try holding down the two connect buttons at the same time for five seconds and then release them both.
4. Try moving the mouse.
5. Make sure that there are no possible wireless interference between the wireless receiver and mouse like the base of a cordless phone, cell phone etc.
If same problem occur after doing the steps below, then you may want to contact the manufacturer for RMA. This Microsoft 4000 has a three year limited warranty.
Thank you!
Nov 11, 2009 | Microsoft Wireless Optical Notebook Mouse...
Wireless keyboard and mouse not working, battery in receiver?
The receiver should not have a battery. It gets its power from the USB port. Try uninstalling both keyboard and mouse via (Control Panel...Device Manager) and reinstalling them. Sometimes the drivers get corrupted and reinstalling them will fix that. Also there are on/off switches on the mouse and maybe the keyboard. Check that someone hasn't turned them off to save batteries when not in use.
Sep 17, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Wireless mouse/ keyboard will not work when 2nd computer is on
There must be interference on the signal from the mouse by the second PC
Make sure that there are no power cables close to the mouse or receiver, I have seen this cause problems many times.
You could also try changing the channel in the router settings in case this is causing the problem, it may be on the same channel as the mouse but only interferring when the second PC is turned on, ta, HPC
Nov 16, 2008 | Logitech V250 (9675380403) Mouse
Gear Head mp2850blk mp2850blk Logo
42 people viewed this question
Top Gear Head Computers & Internet Experts
micky dee
Are you a Gear Head Computer and Internet Expert? Answer questions, earn points and help others
