Question about Vehicle Parts & Accessories
Car wont start, runs then stops - Vehicle Parts & Accessories
  • 80 Answers
Kindly run a diagnostic scan on the powertrain of the car
Posted on Oct 20, 2013
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
2005 chevy impala was running hot stopped put water in it now it wont start back motor turns over but wont start battery dead
Head gaskets blown or cracked head. It only takes 1 time of running hot to cause damage as the heads are aluminum and the blocks is iron.
Oct 13, 2016 | 2005 Chevrolet Impala
Car wont start
Run and start are two different things, if it starts and runs from a jump it might just need a new battery. While running, the car stops running and wont start, then I would check the alternator by removing the negative cable while the car is running, and if it shuts off then the alternator is the problem.
Nov 30, 2013 | Saturn 2002 VUE 4 CYL
Dodge truck 2004 1500 5.7 liter hemi is running and suddenly stop and wont start, what is the problem?
needs re setting as the egr valve could set off the sensor on the exhaust
Sep 02, 2012 | 2004 Dodge Ram 1500
I was driving down the road and my motor stopped
the alternator may of went bad and stopped charging so the car died when the battery went dead. Charge the battery and test to start with. Are you saying wont turn over ot turns over and wont start. If it turns over and wont start then it could be several things. Will need to get it diagnosed to be sure
Nov 16, 2009 | 1996 Ford Taurus
Toy starts runs 10 seconds and stops change fuel filter now wont
When you tur the key forward do you hear the fuel pump running? You should hear a low hum for about 20 seconds near the gas tank and then it stops. If you hear this your pump is good. If it keeps running or you can't hear it at all it's bad or the main fuel pump fuse is blown.
Jul 28, 2009 | 1990 Toyota Camry
Ithe engine stops during driving and wont start
Try Crank Position Sensor it is a known issue with the ML's. They breakdown and are very easily affected by heat.
Jul 20, 2009 | Mercedes-Benz ML320 Cars & Trucks
Vehicle will not start
Put a fuel pressure guage on the test port on fuel rail. With fuel injected engines if pressure is too high or low car wont start.
Cycle key off to run (not start) you should hear the pump run a few seconds and stop.
Jul 08, 2009 | 2002 Hyundai Accent
Sputtering then stopped running and wont turn over.
Wont turn over are you sure as wont start is differant than wont run
Wont start could be Battery/starter/or engine siezed.
Wont run is not the same,,, that could be lacking power /low on oil/water/ Fuel/or even engine lacking power like down on compression which is all the above plus more ....
So check it out let us know again. Ron
Jun 29, 2009 | 1986 Honda Accord
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
