Question about GE 31GT659 31" TV
Picture too wide for screen
The picture on my GE 31GT659 set has been slowly growing bigger over the last 5 years. It cuts off both the right and left side of the picture although no black areas show on screen. (also top & bottom but not as severe) It's like the picture is zoomed in part way. Important info like the timeclock during a football game is off the side of screen. Are there any adjustments for horizontal and vertical size? Chassis # CTC187CH Serial # 630470845 I'm capable of soldering & swapping out whatever parts need changed, but I don't have any test equipment 'cept an old dmm. Thanks,
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
Your problem is called blooming as you might be aware of very high voltage in tv. you can check 1 high output voltage fron power supply. 2 if it is ok then the problem is in horizontal section.you can check cap.in hor. section at last flyback transformer. hope this will help.
Posted on Oct 01, 2007
6ya staff
SOURCE:
GE 31GT659 31 Picture on right is vertically drooping
Check the degaussing posistor. Replace it. It can be located at the main power regulator section. Will look like this.
Jul 29, 2012 | GE 31GT659 31" TV
Projection is too close cuts the screen what do i do
have you tried zoom setting in the menu? wide, full , or zoom?
Feb 16, 2012 | GE D52GW12 52" Rear Projection HDTV-Ready...
My tv screen is too wide horizontally. I can't see but what's in the middle of the picture. Do I need to purchase a new tv or is this something that can be fixed?
go into video set up and take tv out of zoom mode
it sounds like you have it set to zoom a standard definition signal and that will make picture become bigger than the screen and cut picture off
hope that helps
Mar 25, 2011 | Polaroid TTM-2401 TV
No picture
The main problem is from theTV menu.I would recommend you press,menu,then settings,then display settings,and last tv screen. After, you'll get options on how you want to make your screen look like.Example:wide screen, Automatic, etc.
May 31, 2010 | GE 32GT740 32" TV
Screen goes black, picture grows over time but is dark
i suspect that you have a problem in the yb board that's the first thing that i would do.
good luck
[email protected]
Oct 30, 2008 | Philips 42PF9630A 42 in. Plasma Television
GE 31
check electrolitc capacitors in horizontal circuit
May 09, 2008 | GE 31GT659 31" TV
I need to know how to access the verticle hold to adjust TV
what do you mean that the picture streched out.this is a strange problem.as vertical problem does not strech it either have a line inthe middle of the raster, shrink both at the top and bottom of raster,lines run up and down on the raster.kindly explain your problem in detail then i will be able to help you.
Mar 19, 2007 | GE 31GT659 31" TV
Bottom of picture is cut off
Usually when the vertical starts shrinking slowly, it is due to capicators getting out of tolerance in the vertical output section of the chassis. If it can be adjusted out through a service menu, you'll probably need a tech with the right equipment to perform it.
Jan 01, 2007 | RCA F27440 27" TV
Televison & Video Logo
175 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
