We have a dry pro 793 its showing error code e3043 temperature is abnormal. Not printing film how to resolve the problem
2 Suggested Answers
SOURCE: Canon IPF 710 with error code E161-403E,
The error apeared when i stated to print !
How to solve it.
It is about 6 month since we started to use your product.
Posted on Jun 15, 2010
I have Toshiba e-studio 257 and have an error code C970 on the screen. Can you help me?
C3D2 EPU board memory old parts detection error: The EPU board cannot detect the new process unit when the equipment is started in the EPU replacement mode ([7] + [START]). C410 Thermistor or heater abnormality at power-ON: Abnormality of service call the thermistor is detected when power is turned ON or the temperature of the fuser roller does not rise in a specified period of time after power is turned ON. C430 Thermistor abnormality after abnormality judgment: Abnormality of the thermistor is detected after a specified period of time has passed from power-ON (including ready state). C440 Heater abnormality after abnormality judgment: The temperature of the fuser roller has exceeded the range of control or does not even reach the range. C450 Thermistor abnormality during printing: Abnormality of the thermistor is detected during printing. C4C0 Fuser unit new/old detection fuse abnormality C550 RADF I/F error: Communication error has occurred between the RADF and the scanner. C551 Document feeder model detection error: An optional document feeder that is not compatible to this equipment is installed. C570 Communication error between Engine-CPU and IPC board C580 Communication error between IPC board and finisher C5A0 EEPROM communication abnormality (LGC board) C8E0 ADF communication abnormality: The system has to be stopped because the control abnormality occurred C940 Engine-CPU abnormality C970 High-voltage transformer abnormality: Leakage of the main charger is detected. CA10 Polygonal motor abnormality: The polygonal motor is not rotating normally.
These are the error cods list. If you wish to get some details; check the site linked here. Pull up older posts.
Jul 08, 2016 | Toshiba Office Equipment & Supplies
E003 Error code in canon ir2420 photocopier
Code E003-0000 Description Abnormally low temperature (detected by main thermistor)
After the temperature detected by the main thermistor has reached the specified value, it does not reach the specified value during initial rotation. Remedy - Check the connector of the fixing film unit. - Replace the fixing film unit. - Replace the DC controller PCB. Error Codes Canon iR2420 Code E003 0000
Oct 28, 2015 | Canon Office Equipment & Supplies
How to remove an error e000000-0001 for canon 4035i. I have tried to remove but I fail
Abnormally high temperature (detected by main thermistor)
The main thermistor detected an abnormally high temperature (240 deg C) during temperature control. - Check the connector of the fixing film unit. - Replace the fixing film unit. - Replace the DC controller PCB.
Mar 10, 2015 | Canon Office Equipment & Supplies
Canon 2318
That,s it means Error Code E003-0000
THANK'S
Jun 26, 2013 | Office Equipment & Supplies
Model:- Canon ER 3530 Error Code :- E00000-0001
this is error code for abnormal temperature in fixing assy. You can try to clear the error, but if cllear doesn't help you, call service for fixing film unit replacement.
Procedure:
While the copier is in ready to copy mode or showing error:
1) Press the asterisk key " * " on the control panel.
2) Press the 2 and 8 keys of the keypad at the same time.
3) Press the asterisk key " * " on the control panel
Now choose: COPIER>FUNCTION>CLEAR>ERR, turn off and on
Hope that helps!
Aug 26, 2011 | Canon Office Equipment & Supplies
I have an System ERROR E001 following Error E808 on my canon 2016j copier and waht shal i do me out guys
E001 0000 Abnormally high temperature (detected by main thermistor)
E001 0001 Abnormally high temperature (detected by sub thermistor)
The sub thermistor detected an
abnormally high temperature (295 deg
E808 0000 Fixing drive circuit failure
- The heater does not turn on.
- A fixing drive motor failure was
detected.
- Replace the fixing drive motor.
- Replace the power supply PCB.
Feb 19, 2011 | Canon iR 2016i Black and White Copier
IR2318L CANON COPIER IS SHOWING CODE E000003-0000 AND HAS STOPPED COPYING,WHAT COULD BE THE PROBLEM?
Heater temperature error (abnormal drop; low-temperature detection)
The main thermistor reading is lower than 140°C when paper is moved.
Main cause:
The fixing film unit is faulty (i.e., the main thermistor (TH1) has poor contact
or has an open circuit; or, the fixing heater is faulty). The main power
supply PCB is faulty. The DC controller PCB is faulty.
Caution:
To clear the error, execute the following in service mode:
COPIER>FUNCTION>CLEAR>ERR.
Action:
1. State
Turn on the power switch, and clear E002/E003. Thereafter, turn off and
then on the power switch. Does the fixing heater operate?
NO: See "The fixing heater fails to operate."
2. Wiring
Is the wiring from the DC controller PCB to the fixing film unit normal?
NO: Correct the wiring.
3. Fixing film unit, DC controller PCB
Try replacing the fixing film unit. Is the problem corrected?
YES: End.
NO: Replace the DC controller PCB.
Feb 02, 2011 | Canon imageRUNNER 2200
MY MACHINE IR2016J SHOWING AN ERROR MESSAGE SYSTEM ERROR E007.KINDLY LET ME ME WHAT TO DO NOW
E007-0000 ABNORMALLY LOW TEMPERATURE (detected by sub thermistor)
A fixing film sensor failure has been detected.
Fixing film rotation error
C:
Fixing film sensor failure
The fixing film sensor is faulty.
R: - Check the connector of the fixing film sensor.
- Replace the fixing film sensor.
if you are not a tech you should call for one to replace the faulty part.
Nov 13, 2010 | Canon iR 2016i Black and White Copier
WILL NOT PRINT CODE E000002-0000
this means that there abnormal readings of temperature in fixing assy.
To get rid of the error you can do two things:
First:
Press * ( add. function key )
press 2
press 8
Press *
This will allow you to enter service mode.
Choose COPIER
Under FUNCTION tab, choose CLEAR and choose ERR
This will clear E002 error.
Turn off and on.
If it works, that means that because of i.e. blocked vent cover, or too much of a/c,... had influence on temperature readings in fix. assy.
If that doesnt help, you need to replace fixing film assy.
Hope that helped
Jun 04, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Canon ir 2016j
E003 0000 Abnormally low temperature (detected by main thermistor)
0001 Abnormally low temperature (detected by sub thermistor)
sub thermistor has reached the
Jan 09, 2010 | Minolta EP4000/5000 CS/PRO Copier
37 people viewed this question
jasbo
jasbo
