Question about Whirlpool WFC7500VW Washer
My whirlpool wfc7500vw1 keeps saying f07 what do I do
3 Suggested Answers
  • 867 Answers
SOURCE: need help with whirlpool wfc7500vw1 got code A-09
It is a fill time error, usually caused by a blocked inlet filter or a defective inlet solenoid.
Posted on Mar 11, 2012
  • 4 Answers
SOURCE: whirlpool f07
If i recall correclty the Error may be the filter. Check on the front panel on the lower section. If there is something clogged then the filter will not allow for proper water flow and it could shut the machine down.Also, check to see if you lines coming into the machine are not leaking. If the pressure is too low it can trigger the computer to shut down the machine. We had a pinhole leak in a line and it did the same.
Posted on Jun 17, 2012
I need the part number for the plastic button assembly on a whirlpool wfc7500vw washer
Here's the parts diagram. You should be able to find it and order it here. https://www.searspartsdirect.com/model-number/wfc7500vw1/1198/0153200.html?sid=ps:GOOGLE:Dynamic%20Search%20Campaign%20-%20Categories:whirlpool:&k_clickID=bc276823-c73d-402e-8108-8dca92f89665&gclid=CjwKCAiAnabTBRA6EiwAemvBd9ZcgjLmZK2G078ABQNcyGMj1_hA2h07z9UCh0fNoaGyjVBYHsWyyRoCLgEQAvD_BwE&kenibpid=p.590.bc276823-c73d-402e-8108-8dca92f89665.cr368030
Jan 23, 2018 | Whirlpool Washing Machines
Whirlpool model #WFC7500VW1 F25 Failure Code: won't go into high spin. Motor reaches max speed fine in diagnostics.
Please check your model number. Whirlpool has no models that start with WFC7500V0. There is a WFC7500VW1 front load washer. The F25 error indicates a problem with the drum motor tachometer. (The motor rotation speed reported to the main control isn't appropriate for the cycle.) This can happen if the shipping bolts aren't removed.
If the washer is ready to be used, then you need to unplug the washer before continuing the diagnostics. Remove any clothes from the tub first. Check that the wires between the motor control unit and the central control board are seated properly. Make sure that none of the wires in the wiring harness are broken or have corrosion at the connectors. Replace the wiring harness if it is damaged. If the wires are good, plug the washer back in. Check the resistance at the tachometer and motor. Replace any failed part. Check if the drum spins properly when you spin it by hand and when the motor is powered. If the motor is spinning at the appropriate speed, replace the motor control unit. If the drum won't spin easily when you push it by hand, replace the bearings.
Some of the parts for the WFC7500VW1 are available here: http://www.appliancepartspros.com/parts-for-whirlpool-wfc7500vw1.html .
I hope this helps.
Jul 29, 2016 | Whirlpool Washing Machines
Whirlpool WFC7500VW1 won't start
My Whirlpool washer model WFC7500VW1 will not start--the green Start button keeps blinking and the red Door Locked button keeps blinking. I do not get any error codes.
Feb 23, 2013 | Whirlpool duet Washing Machines
How do you get front control panel off to have access behind it. whirlpool mod.WFC7500VW1
Remove the screws on the back of the top panel, slide the panel back about a half of an inch and lift off. You will then have access to the control panel.
Oct 15, 2012 | Whirlpool WFC7500VW Washer
Whirlpool f07
Jun 17, 2012 | Whirlpool WFC7500VW Washer
Need help with whirlpool wfc7500vw1 got code A-09
Mar 11, 2012 | Whirlpool WFC7500VW Washer
Its on a model # wfc7500vw1 it keeps showing up f30
Door lock error. Make sure the door is completely closed and no clothing is blocking door lock.
Jun 20, 2011 | Whirlpool Washing Machines
THE CODE SAYS F07 AND SHUTS DOWN. SOMTIMES I CAN RESTART IT AND SOMETIMES I HAVE TO WAIT UNTIL THE NEXT DAY
F07 is the code for a motor problem.  It could be the MCU ( motor control unit) the cable from the MCU to the motor or the motor itself.  odds are it's the MCU but you might want to have a tech out instead of buying either of the expensive parts first.
Aug 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F07 error message
F07 - Motor Control Unit (MCU) Error - Disconnect power and unplug unit. Check wire harness connections between drive motor and Motor Control Unit (MCU), and between MCU and the Central Control Unit (CCU). Reconnect power and plug unit in.
Check the MCU by looking for operations of the drive motor, and check drive motor for powered rotations. Replace failed component.
Note: If this failure occurs during high-speed spin, the door will be unlocked after three minutes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool WFC7500VW Washer Logo
71 people viewed this question
Dan Webster
Dan Webster
Sal De
