Question about Technics SL-1200 Turntable
The turntable loses its speed
My problem starts since i realised i had a burnt lamp near the plate and wanted to fix it. after i replaced the little lamp next to the plate i reassembled the turntable and i turn it on... so far so good, all lights are on and i am satisfied with the result. i press the start button and the plate starts spinning but i notice that the lamps are dimmer-ing on and off giving low voltage or smt like that. i put a record on and the record sounds like someone is playing with the pitch constantly. i reverse the rotation of the plate with my hand and i find no resistance at all as opposed to other times where there was a strong force going on the other direction. now what i can guess is that the magnets or a portion of them are off! am i right or what seems to be the problem? how can i fi this? is it possible to be fixed by me or is it a specialists duty? thanks a lot in advance for the response!...
  • Anonymous Apr 24, 2009
    fact is that the wires of the lamp did touch a metal plate and there was a current through. there were some sparks and then nothing. after i switched it on i had the result i described in the previous post. nevertheless i disconnected the lamp and switched it on and had the same result. so i did something wrong there. what needs to be done?
    Brigadier General:
  • 8,546 Answers
Perhaps you should retrace your own lamp repair steps. Did you tamper with anything electrical? It seems likely you touched something inadvertently.
Posted on Apr 24, 2009
My 1 turn signal flashes rapidly compared to the other. The rear signal is not working.
The signal flashers fast BECAUSE the rear lamp is not working. Bad bulb? Bad ground? Fix the back lamp and normal speed will be restored.
Mar 08, 2015 | Cars & Trucks
Technics sl1210 mk2 motor speed error
pls use the search function, this is answered 50 times
Jan 08, 2014 | Technics SL-1210 Turntable
Recently purchased used Panasonic SL-HM42 turntable. Works, but turning a little slow on 33rpm (30-31rpms) says DC Servo System on the front. Don't see any set screws on bottom. would like to get platter...
How to tweak the playback speed on Panasonic SL-HM42 turntables
You will need:
  1. 1x small Philips screw driver
  2. 1x small flat-head screw driver
  3. An ear for correct pitch and a little bit of DIY skill!
Step 1 - Remove the wooden base plate
After ensuring that you've removed the the rubber turntable slip mat and securely docked the turntable arm, carefully flip the turntable over onto its lid to expose the wooden base plate, as per below.
Using the small Philips-head screw driver, remove the screws holding the wooden base plate in place, then gently lift the base plate off the turntable.
Step 2 - Expose the pitch adjustment screws
Once the wooden base plate is removed, you will see the speed-controller circuit board on the right-hand side.
To expose the the two speed/pitch-control screws, firstly remove the screw holding the speed-controller circuit board in place, then gently lift the circuit board up on the free side.
Step 3 - Correct the turntable playback speed and pitch
The easiest way I found to correct the playback speed was to flip the turntable carefully back into the original position, allowing the speed-controller circuit board to hang free as shown below.
Next, play a record that you know well and are able to tell when the speed/pitch is correct (assuming you have an ear for correct pitch, that is!), then at the same time using the small flat-head screwdriver, gently turn the speed adjustment screw(s) to adjust the playback speed up or down until the correct playback speed and pitch is achieved (or at least until it no longer annoys you ;).
Turning the screws clockwise (to the right) will increase the speed/pitch, and anticlockwise (to the left) will decrease the speed/pitch.
NB - Both screws allow for fine pitch control, so if the second is already at maximum speed, you can use the first screw for additional speed.
Step 4 - Reassemble the turntable again
When you're happy with the speed of your turntable, remove the record, the mat again & locking the turntable arm, replace the screw holding the speed-controller circuit in place (as per Step 2) and then finally replace the screws holding the wooden base plate, as per Step 1.
Happy listening!
Aug 29, 2013 | Audio Players & Recorders
Speed seems a little slow on 33s. How can I fix this?
If the problem is encountered on both speeds, 45 & 33, then there is a high chance that you are in need of a belt replacement.
Here is a general guide on how to replace a turntable belt.
You can also use it to check the belt status.
Jul 23, 2013 | Aiwa PX-E860 Turntable
My 1210 turntable is slowing down/speeding up, so as the song sounds out of tune....what is the problem, and how do I fix it?
over time the motors go. you can replace it but its nearly impossible since they no longer make or manufacture technics due to controllers taking over the dj world.
May 08, 2011 | Technics SL-1210 Turntable
I just bought a aiwa turntable & stereo at yard sale. the old lady said she never used it but yet the turntable will not turn. i've looked over the manual and can't find any troubleshooting. can you...
Hi Denise, I am in the consumer electronics repair industry. It may be as simple as this... Lift up the MAT on the turn table. This is the black rubber covering that you place the record on. Look through the holes in the plastic turntable (rotate if necessary) until you see the motor/pulley shaft sticking up (brass color). The turntable belt may have dislodged from this pulley. If you see the black flat rubber belt near here, just put it around the pulley again. Make sure it is not twisted and sits flat. Spin table by hand to be sure it is seated properly.
Now you may have to remove the plastic turntable itself if you can't see the belt right away. In this case, remove the C-clip with a flat screwdriver (be sure not to lose it) from the record center post. Lift the turntable plate up shaft. Check to see if the belt is still partially around the plate. You may be able to just see enough to wrap the belt around the motor pulley now. If you need to take the plate off completely, then just place the belt first around the groove on the plate and finese the belt around the motor pulley. Now seat the plate, replace the C-clip and place the MAT back on and it should be good to go.
I had this same problem on a new turntable I got for free. Good luck : )
Oct 17, 2010 | Audio Players & Recorders
Glass turntable in tricity tmc209 says "microwave only" What do I use for convection or combi cooking? Does turntable still need to rotate for convection cooking?
definately dont use the standard glass plate for convectional 'oven' cooking, as it will shatter. i have had TWO plates shatter so far before realising they should only be used for microwave cooking.
Aug 15, 2010 | Microwave Ovens
Pop up inspection lamps blown
Greetings!
The original equipment replacement part number for this lamp is SFDN122-01E and is in stock from www.encompass.com for around $7 plus freight. These are in white only, but you may be able to purchase small, rubberized covers (like a little lamp condom) from an accessory/parts distributor such as MAT electronics or MCM.
To access the lamp first UNPLUG THE TURNTABLE. Lock the tonearm in place. Invert the turntable. Remove the 4 audio insulators, remove the 17 screws with spacer and then remove the other 11 screws. Remove the bottom plate. Remove the 2 screws that hold the lamp circuit board in place. Then remove the lamp screw.
Hope this helps!
Rob
Jan 14, 2009 | Technics SL-1210 Turntable
No control of platter speed
One of the drive circuits on the main board are faulty, and will need to be replaced. This is not an easy fix, so you will need to take it to a qualified service center for service and repair. Not an expensive fix, but a little time consuming in isolating the issue.
- TERMiNAL OPTiC
www.DJPROLAB.com
Mar 08, 2008 | Technics SL-1200 Turntable
Ecoquest air purifier uv lamp replacement
If you haven't done so, try replacing the lamp starter.
Sep 29, 2007 | Ecoquest Fresh Air Air Purifier
Technics SL-1200 Turntable Logo
128 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
