Question about D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B)
DSL-2640B problem on loading pages
Hi!
i need some help.. my router has several problems on loading pages.. but is basically a random problem..
i go on some pages and it's all ok.. then i open or refresh one page and the browser tell me that the page is not found..
the adsl service works well, i tested it.. and i got the same problems in all my pc/mac.. with no Firewall at all..
help me plz!
tks a lot! =)
  • metalsir Apr 24, 2009
    hi!
    tks for the reply..
    i got the latest original firmware of the router..
    and i gat the same problems with the latest firefox (mac/pc/ubuntu) and the latest ie (i tested only on pc this)..
    i'm getting mad.. :|
    yup.. done.. no benefits..
    Scholar:
  • 132 Answers
It can be two things. Your router software has an issue. You can check to see if you have the latest firmware for it.
It can also be your browser that you're using to get on the net and view the router pages. Make sure all your updates and patches are done. You could try emptying temp internet files, cookies, cache and history to see if that helps too.
Posted on Apr 24, 2009
  • Blue Sky IT Strategies
    Blue Sky IT Strategies Apr 24, 2009
    Did you try the second suggestion too?
Forgotten password and username to access router
If you forget the password, you need to reset the device to the factory default settings. In that case, all configuration settings of the device are lost then you need to reconfigure the router,
To reset the device to factory default settings, follow the instructions from this link,http://global.dlink.com.sg/site_support/DSL-2640B/Manual/DSL-2640B_manual_v2.pdf
11_20_2011_12_11_30_am.pngHope this helps.
Nov 07, 2011 | D-Link - DSL-2640B Wireless Broadband...
My dlink dsl-2540u router not connect to the internet. Dsl led blinking & sometimes totaly off.
Contact your ISP immediately- the issue you have is called no sync. Basically with the DSL led going completely off- that would point to a bad modem, however the fact that you have no sync otherwise indicates your DSL provider may need to service your DSL line.
Jul 09, 2011 | D-Link ADSL2/2+ Modem/Wireless Router...
Dsl-2640b always hang
Just download and install free open-source Router Commander program, that fully compatible with your router. This program designed to prevent router to hang. Very recommend. I solved my hangs problem with this software.
Apr 21, 2011 | D-Link DSL-2640B Wireless 11/54Mbps ADSL2+...
Dlink DSL-2640B LAN & Internet keep disconnecting , very random and it's painful
There are many reasons why this might be happening.. You could try the following steps..
1) Disconnect the power from router for a minute and reconnect and check. 2) Try changing the wireless channel and Network name and try re-connecting and in change LAN slots at the back of the router. 3) Check if there is an firmware update for your product and update if any update is available. 4) If none of the above steps work you will need to reset and re-config your router. ( For that you need the CD given with the router and you will need the ISP settings.)
Hope this helped
Feb 15, 2011 | D-Link DSL-2640B Wireless 11/54Mbps ADSL2+...
I'm having problems tring to connect to ATT HS DSL, flashing green light but can not connect to internet, what settings on DSL-2640B do I need???
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Jan 07, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
How do I change channels on the 4 Port Wireless Router, ADSL2/2+. Need to change from channel 9 to channel 1.
Manual for DSL-2640B:
ftp://ftp.dlink.co.uk/dsl_routers_modems/dsl-2640b/DSL-2640B_Manual_v1.pdf
How to change channels see page 27.
For manual channel setting "Enable Auto Channel Scan" needs to be
disabled / not selected.
Note: default login user and password for the router is both admin.
Login opening Internet Explorer entering http://192.168.1.1 as address page.
Sep 01, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Connection on/off randomly
Try to install Router Commander software that was especially developed to solve this kind of problems.
Apr 05, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Listenning port bit comet
BitComet requires you to be able to receive incoming connections. If you're behind a NAT router but don't have port forwarding configured properly, incoming connections will be stopped by your router (won't get to your computer).You need to configure port forwarding, so your router knows that the incoming connections are for BitComet and will be allowed through (= forwarded) to your computer.
There are several versions of your router:
DSL-2640B, DSL-2640Bv2,...
Go here, scroll (almost all the way down) and find your router model.
On the next page, skip the advertisement (upper right corner) and look for BitComet.
Simply follow the instructions on that page - they are precise and correct.
In general: You can use ANY port, but I would prefer a listen port between 49152 and 65534 because they're classed as "Dynamic and/or Private Ports" by IANA, so nothing else should be using them by default and they're not the standard ones blocked by ISP's or trackers, but - as I said - you can enter any other port you wish.
If you have any more questions, just come back and let me know - I'm happy to help.
Good luck & thanks for rating!
Mar 13, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Dlink 2640b cannot get both internet and dsl to work together
Unplug both devices,and remove the cable/dsl line input to modem, wait 5 minutes, plug cable back it, then turn on modem, wait a minute, then plug in router.The signals should mesh.If not, buy a new router, theyre cheap!~
Dec 14, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B) Logo
216 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
