Remote control RCS-KS09 for Model KS0911, incorrectly defaults to room temperature of 38 degrees. Batteries have been replaced, but with no effect. What to do?
SOURCE: danfoss thermostat control frozen at
See the link on the Danfoss site.  This has helped me http://heating.consumers.danfoss.com/xxNewsx/5dbcb2f9-e888-4d2d-9761-7470786749c9_CNP1.html
Posted on Dec 09, 2008
SOURCE: Wall Hung A/C unit remote
I just got onto a technician who solved the problem for me. What he had me do was:-
  1. Pull dowwn the slider and use a pen to press the ACL button.
    That didn't fix it so...
  2. Take off the slider (the way you would to change the batteries). There is an ABCD slider switch and mine was set to "C". I moved it back to "A" and now it works! I am not sure how it got to "C" though ???
The other thing is I had been messing around with the "Manual/Auto" button under the grill on the wall unit. It was set so that the A/C was off. I'm not sure if that is significant.
Hope that helps.
Cheers,
Garry Rogers (ausgaz)
Posted on Jan 04, 2009
jumptrout51
  • 3361 Answers
SOURCE: Carrier Comfort 13 Puron model 24ACA3 / FV4NB006
Verify 24 volts at the low voltage transformer inside the air handler. If it is OK, jump out the red/green and yellow thermostat wires. If everything comes on, replace the thermostat.
Posted on Jun 08, 2009
SOURCE: where can i buy RCS-5S1E and RCS-7S1E and what are
problem solved, bought remote
Posted on Jan 07, 2010
  • 9 Answers
SOURCE: need replacement remote
Call 954-771-1415 ask for Ivan* universal remote for mini splits
Posted on Jun 03, 2010
Where can i find replacement remotes RCS-KS09 for old sano
You can buy them from electrical shops but you have to marry them to your device ,the instructions come with the remote,follow them step by.step,.
Jan 14, 2017 | Heating & Cooling
I have a Heat and Glo gas log fire. It is switched on at the moment and won't switch off with remote. I have put new batteries in remote. Can someone tell me how to switch it off manually
I understand your frustration. Call 1 (888) 427-3973 if these do not work.
1) The on/off switch on the fireplace and/or wall may be in the on position. This will over ride the remote control feature.
2) The remote is in the thermostat mode (SMART-STAT and RCT-MLT models) and the temperature of the room has not exceeded the desired temperature setting by 2 degrees Fahrenheit or 1 degree Celsius.
3) Batteries in the hand-held transmitter are old and underpowered. May work up close and will not work a few feet away.
4) Hand-held transmitter is outside of the 25' of operation.
5) Hand-held transmitter has been dropped and the frequency has been moved off the frequency of the receiver.
http://www.heatnglo.com/Owner-Resources/Troubleshooting-and-FAQs/Common-Questions/Remote-Controls.aspx
Oct 25, 2016 | Heating & Cooling
Can't link my new lifestyle 48 remote control to my lifestyle 38 system?
If the remote does not work as you expect
If your system does not respond when you press a button on the remote, it could be time to
change batteries. For information on the type of batteries to use and how to change them,
refer to "Replacing the remote control batteries" on page 51
In some buildings, you may experience "dead spots" where the remote control will not
operate effectively. If this happens, move the remote a foot or two and try again. Also make
sure the cord that connects the power supply to the media center (and contains the remote
antenna) is stretched to its full length and is separated from other power cords. If these
efforts do not work, move the media center a few feet to a location where it provides a better
response.
If the batteries are fine and the suggestions concerning "dead spots," above do not work,
you may need an antenna extender. To contact Bose
customer service to request one, refer
to the address list included with the system.
Source
Dec 31, 2013 | Audio Players & Recorders
Remote is inaccurate
did you change the batteries ?
Dec 07, 2013 | Mitsubishi Heating & Cooling
Skytech receiver batteries keep going dead
Joe,
The heat from the fireplace can have an adverse effect on the life of the batteries. Sometimes simply re-positioning the receiver to a cooler location under the firebox and/or adding a heat-shield can improve battery performance with the Skytech remote receivers.
As a test, you could even place the receiver outside the fireplace for a period of time to gauge the effect of heat on the unit.
According to the owner's manual for the Skytech 3301 Thermostat Remote:
"For REMOTE RECEIVERS that operate on BATTERY POWER, these heat conditions can cause batteries to discharge when temperatures exceed 115 degrees F. Studies show that alkaline batteries, when exposed to a constant temperature of 120 degrees F, can lose up to 50% of their operating power. When the battery cools down, it will partially recharge itself, but constant heating and cooling will reduce the battery's normal life expectancy."
Hope this helps!
Dec 01, 2012 | Skytech 3301 Thermostatic Gas Fireplace &...
Cant program remote
I'm going to assume you are meaning that you are unable to set the "target temperature" for the thermostat?
This remote control system can be thermostatically controlled when the transmitter is in the THERMO mode (THERMO must be displayed on the screen). To set the DESIRED room temperature, press the MODE button to place the transmitter into THERMO mode, then press the UP or DOWN button to select the desired
room temperature. The highest SET temperature is 99 degrees Fahrenheit (32 degrees Celsius).
The complete owner's manual can be downloaded from the product page below, just scroll down to the bottom and click the link.
Skytech 3002 Thermostat Fireplace Remote
Sep 23, 2012 | Skytech 3002 Fireplace Remote Control with...
Mr.Steamer Commercial Steambath CU750A temp is to high it is out of control
There are only 3 likely causes. The first and most likely is the room sensor inside the shower. This is a resistive type sensor that communicates the temperature in the room to the controller via ohm ratings. There is an equivalent ohm rating for every degree of temperature it correlates to and that is how the temperature controller knows what temp it is in the room. Often in commercial steam rooms clients tend to spray cold water on the sensor which causes damage and alters the ohm rating to the point where the sensor is relaying incorrect room temps to the controller, causing high or low temperatures. Normally when the room is hot, it causes the alloy metal of the sensor to be hot. When cold water is sprayed on it, it immediately bring down the temp of the alloy and the thermal shock warps the metal causing the resistance values to change. Set your multi-meter to ohms and remove the sensor wires from the back of the controller. You will do your ohm reading on the sensor wires. Check the actual room temperature with a thermometer. At room temp 77 degrees you should be getting 10,000 ohms, at 100 degrees you should get 5827 ohms, and at 120 degrees you should get 3759 ohms. Note as the temp goes up the ohms go down, this should help you determine if your sensor is good. The other possibility is your steam solenoid valve is stuck in the open position. Simply check if there is voltage running to the solenoid. If there is no voltage but the room is filling with steam your solenoid is stuck open and needs to be replaced. The last is the controller, and by process of elimination if the sensor and steam solenoid are good then the controller may be the issue.
Feb 02, 2012 | Mr Steam Mr. Steam Commercial Steambath...
Why do I have to press the remote control several times (between 6 and 12) to get the gas heater to turn on? And when the temperature reaches the set point and turns off heater, it will not go back on...
The first thing I would do is make sure that your batteries are in good shape and that connection in the remote and baterry ends are clean.
You can easily clean the ends on your batteries by rubbing them briskly on a piece of denim or other semi rough cloth and use a fine grade of sandpaper to clean connections inside the remote. Thank you
Jan 06, 2011 | Desa International GWN30T GLOWARM® Gas...
My daughter has Mitsubishi split type air conditioner, model MXZ-2A20NA. The problem is that one of the unit puts out more cold air than in called for on the remote resulting in a room temperature that...
The best thing for you to do is to call Mitsubishi Tech. Support directly..they are first class and will probably know exactly what the issue is...
For technical application questions, please call:
Mr. Slim: 1-800-433-4822 (press option #3).
heatman101
Aug 26, 2010 | Mitsubishi Heating & Cooling
Temperature varies 13 degrees around setpoint on aux heat
I don't have the book for this particular unit but, check the sequencers that control the electric heat mode, as the regulator heat pump works good. The part may have a time or temperature delay that is too long for you. Also if it has a remote thermostat, check the heat anticipate setting. You will have to check the installation manuel, but its usually .6 to .8, but I don't think that is the problem.
Nov 28, 2007 | GE Zoneline AZ55H09D Air Conditioner
Heating & Cooling Logo
296 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
