Question about Watches
How do I set the day and date on Weide wh 1104 watch
  • 4 Answers
SOURCE: Seiko Diamatic Day Date Automatic Watch No: 219050
I have a Seiko Diamatic 780632. To set the day and date, pull the crown once and wind it upwards (away from you) to set the date; winding it downwards (towards you) will set the day. To set the time, you have to pull the crown twice and wind it towards you.
Posted on Nov 14, 2007
  • 14 Answers
SOURCE: Watch has correct day and date only 1/2 each day
The watch thinks at Noon it is really midnite, so you must scroll 12 hours ahead to repair this. There are usually 2 "clicks" on the stem of the watch when you pull it out, 1 will set time, 1 will set the day/date, be careful to pay close attention to which is happening when you pull out the stem, and setting should go well after that.
Posted on Dec 01, 2007
escapement
  • 2334 Answers
SOURCE: how to adjust day date on older rolex perpetual day date watch
There isn;t any downloadable manuals for Rolex watches, but operation of Rolex Day-Date is very simple:
1) when you unscrew the crown, it is in winding position,
2) when you pull out the crown to the first click, it is in day and date setting position (depending wich way you turn the crown).
NOTE: to adjust the day or date, previously you have to advance hands forward, passing 12 o'clock (midnight) mark and stop advancing at 4.00 a.m. using the crown in position as described in chapter 3. When done - push the crown fully in, then pull out to the first click and only then adjust the day or date.
3) when you pull the crown further out to the second click, it is in time setting position.
To find the daytime or night time on the watch: pull out crown to the second click and advance watch hands forward till you pass the 12 mark on dial. If the date changes as you pass it - it is the night time (midnight). If the date do not change as you pass it - it is the daytime (noon).
After all settings being done, allways screw the crown back down as it protects the watch from water and moisture.
Never use watch in sauna- it's not designed for that.
Do not forget to rate, please.
Posted on Mar 07, 2009
Cool_dud 09
  • 206 Answers
SOURCE: Day, date and time for a Bulova TFX watch
Step 1. When the second hand re a ches 12 o ’ clock (the zero or 60th second mark ) , pull the crown all the way to the “OUT ”position (you will hear two “ cl i ck s ” ) .All hands will stop.
Step 2. Turn the crown to move hands FORWARD (clockwise) until you see the date (for date only) or both day and date change.This establishes midnight, t h e b e ginning of the day.
Step 3. For A.M .time, continue to move hands forward until the minute hand is approxim a t e ly 5 minutes beyond the desired minute marker ;then ,gently turn b a ck to the same marke r. For P. M .time , follow the same procedure ,but first a dvance  the hands past 12 o’clock .
N O T E : The date will advance automatically at midnight, p rovided that A . M .a n d P. M .h ave been established (Steps 2 and 3).The watch calendar is pro grammed for a 31-day cycle.The  refore ,on the fi rst day of any month fo l l owing a month with fewer than 31 day s , the date must be advanced manually (see Step 5).
Step 4. When the time standard by which you are setting your wa t ch ( e.g.,telephone beep) re a ches the 60th second, push the crown all the way to the “ I N ”position . All hands will start instantly.
Step 5. Pull the crown to the “ I N T E R M E D I AT E ”position (one “ cl i ck ” ) . Your watch will continue to tell time. S l ow ly turn crown one way until the correct date a p p e a rs .Then for day/date models, s l ow ly turn crown the other way until the correct day appears .
N O T E : The day is printed in two successive positions on the day indicator: i n English and in Spanish on U. S .m o d e l s ; in English and in Fre n ch on Canadian mode l s It is possible to make use of either position. The display will automatically re m a i n in the language ch o s e n .
The date should never be ch a n ged manu a l ly between 9:00 P. M . and 3:00 A . M .a s this might affect the calendar mechanism and the accuracy of the date. ( Theme chanism will not be damaged if the crown is turned accidentally during this
time peri o d ,howeve r. )
Hope it helped U!
Posted on Jul 30, 2009
escapement
  • 2334 Answers
SOURCE: Bucherer Day/Date Setting Problem
You have to change day by the means of moving hands clockwise. Move as long as the desired day appears in window, then adjust the date and set time. Rate me, plz.
Posted on Mar 31, 2010
Testimonial: "Thanks so much. I thought I had tried what you suggested already, but apparently I hadn't. The watch is now set correctly. Thanks again!"
Weide wh1103 watch.hands stopped working.function buttons work ok.battery powered.hands move when turning winder button.
The Weide watches use springs for their electrical connectivity and I've found that they don't work very well. I had the same problem and after tinkering with all of the connections I came to the conclusion that they were built to not have the battery replaced.
Nov 01, 2017 | Watches
Tip
HOW TO SET DAY / DATE ON AN ANALOG (STEM) WATCH
mcdevito75 here, Over Forty (40) years ago, watch manufactures added, to some of their ANALOG (wind up) and almost all of their DIGITAL (button display) watches the FEATURE of the, MONTH or DAY of the WEEK and the DATE, not only was the time of day available but also the DATE which you no longer had to go searching for, it was readily available on your wrist. The PROBLEM came with SETTING the CORRECT MONTH or DAY of the week and the DATE as some MONTHS HAD 31 DAYS rather than 30 DAYS, this meant you had to CYCLE your watch at least 62 times to get to the CORRECT DATE and mant times, when you finally did reach the CORRECT DATE, the day of the week was off, meaning more CYCLES thru the 24 hours.-------- HERE is the EASY way to SET the MONTH or DAY / DATE on your QUARTZ / MECHANICAL (STEM) watch without haveing to go thru the 24 hour cycle so many, many times. Not only is this, WEAR on your fingers, you can also damage your watch with some many cycles of the 24 hours to SET the correct MONTH or DAY / DATE. ------ HERE ARE THE BASICS,---------- Your ANALOG or STEM watch either QUARTZ or MECHANICAL should have a TWO (2) position STEM we are only familiar with the ONE (1) position we use to set the TIME, there should be TWO (2) positions to the STEM. First pull out the STEM to adjust the MONTH or DAY depending on your watches display, if your watch DISPLAYs the DAY of the week, set the DAY to one (1) DAY before the DAY you want, don"t worry about the DATE (number) yet. Once you have the MONTH or DAY set, push the STEM back into the watch, NOW with a finger nail just under the STEM (usually from the back of the stem as there is more room) gently lift the STEM to it"s first position, It may take some practice so be patient, once the STEM is in it"s first position you should be able to turn the STEM to adjust the DATE (number), if so Adust the DATE (number) to ONE (1) DATE before the DATE you want, This way your watch will be adjusted to change the DAY / DATE at the correct time. Once you have the DATE (number) adjusted to ONE (1) DATE before the DATE you want, push the STEM back into the watch, NOW pull the STEM out to adjust the time, go thru the 24 hour cycle to adjust to the correct DAY DATE (number) and time of day.------------ Your QUARTZ or MECHANICAL (stem) watch is now adjusted to the correct DAY / DATE and will change at the correct hour which is generally 12--1 AM.
on Jul 20, 2010 | Watches
Tip
on Jul 09, 2010 | Watches
How do i set the day ? Mine is stuck on sun.
I would try removing the battery for 10 minutes reinstall the battery if it doesn't help there's a problem with the circuitry.
Hope it helps thank you.
Jun 10, 2015 | Novelty 30M Waterproof Analog & Digital...
I am looking for instruction manual for Weide sports watch WH902
Does exist a function to beep hour a hour in model Weide WH2309?
free-shipping-watch-fashion-weide-sports-watches-wh-2309-with-quartz-led-watch-for-watches-men-aq2i4dbsyqjd0wgvev1j31bb-4-0.jpg
Nov 10, 2011 | Watches
How to set an Armitron watch. Can't set the days correctly.
mcdevito75 here, The stem has 2 positions, Carefully slip a fingernail under the stem and lift, it may take a few trys to get used to it, in this first position you should be able to set the DATE very easily and Maybe the DAY of the wwek also, turn the stem 1 way to change the DATE and the other way For the DAY of the week., Let"s figure you can only set the DATE in this first position, First thig to do is set the DAY of the week, go thru the watches 24 hour cycle and set the DAY to 1 DAY before the DAY you need, now in that first position of the stem, set the DATE to 1 DATE before the DATE you need, now in the 2nd position we all know pull the stem out to set the time of day, go thru the 24 hour cycle to bring up the DAY of the week and DATE you need. Now your watch is set and will change on tome at around mid-nite.
Jul 21, 2010 | Watches
Mar 31, 2010 | Watches
Adjusting day/date on a self winding Seiko, 7S2GB
mcdevito75 here, Your stem has 1 positions to set the date easily without haveing to cycle the watch 60 times. First pull the stem out to set the day, set the day 1 day before the day you want, next, push the crown back in, NOW! Slip a finger nail just under the crown from the back as there is more room, it may take some practice so be patiernt and gently, gently lift the crown to it"s first position, once in it"s first position turn the stem and see the DATE change, set the DATE to 1 DATE before the DATE you want, NOW pull the stem out to set the day date and time of day. Your watch is set and the day date will change on time, a little past mid nite.
Apr 14, 2009 | Seiko SGF204 Wrist Watch
Setting my day date on watch
mcdevito75 here, The stem has 2 positions, first, set the day to 1 day before the day you need, now, slip a finger nail just under the stem and gently, gently lift the crown to it;s first position, set the DATe to 1 date before the date you need. Push crown back in, now pull crown out to set the date and time of day. Your watch is set and should change around mid nite
May 03, 2008 | Seiko SLL003 Wrist Watch
Can't seem to get AM & PM set properly
Had Pulsar analog watch. Couldn't set either day or date properly due to being unable to signify AM or PM. When days changed one or the other would be 12 hours off.
""googled" adjusting Pulsar watches" and found site which explained how. You set day of week and date to previous day and date and then move watch time ahead until day and date are correct. Then set watch time. Seems to work.
url: www.pulsarwatches.com.au/manuals_pdf/94_1.pdf
Apr 22, 2008 | Watches
Watches Logo
188 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
