Question about Haier HCM050EC Chest Freezer
Haier model hcm050ec freezer not freezing - Haier HCM050EC Chest Freezer
It wont freeze and only comes on for a second then makes a small pop sound almost cant tell its on.does it need coolant or frion and can i do it myself
pop generally is from some safety device. make sure there isn't an electrical problem. Home antifreeze systems can gunk up system. and there usually isn't a convenient way to add it.
Jun 06, 2014 | Haier HCM050EC Chest Freezer
Does it need frion or some kind of coolant wont freeze and only comes on for a second and can i repair myself
If it only comes on for a second, it;s almost certainly the compressor.. Don't attempt it yourself.
I have a freezer that ices up about 12inches from the bottom model#HCMO5OEC and will not freeze the food
your freezer has a freon leak and the leak would need to be found, fixed and recharged for it to work again...
this would cost more then a new freezer...
heatman101
Aug 17, 2010 | Haier 3.5 cu. ft. Chest Freezer HNCM035E
Deep freeze compressor not kicking on.
Sounds like the relay contacts are staying open.
Jul 29, 2010 | Haier Freezers
Haier freezer and it wont freeze what should i do?
dear sir/madam
please make sure your freezer,s tempreture sensore is right location .if it,s alredy is in right location then reset the selectore swith to turn off and again turn possition.
hope answer the question.
thank you
Jul 03, 2010 | Haier 3.5 cu. ft. Chest Freezer HNCM035E
I have a haier deep freeze model hcm050ec what is the pressure suppost to be
I am assuming you have some refrigeration smarts. As a general rule the evap in a freezer is 10 degrees low than the box temp. Take the pressure of the low side then look on a P/T chart for that refrigerant and determine if it is where it needs to be. Usually somewhere around -10 to-15 degrees for a zero or colder box.
Sep 25, 2009 | Freezers
HCM050EC 5.0 Cu. Ft. Freezer.. The chest freezer only stay cool when the tempt knop is at max...
Sounds like its either a thermostat issue of the compressor is faulty of the unit needs regassing.
Sep 10, 2009 | Magic Chef Freezers
Haier HUF138PA-Freezer not freezing
just bought one that a repair man had already been through with similar issues. i wanted it as a fridge so this was no problem. took me about 5 minutes to figure out the reason it wasn't freezing though...the switch at the top that turns the light on when you open it also turns on the fan when you close the door. the door however sits just a tad too low to fully engage the switch. put a piece of tape over the switch and let it cool for 24 hours. chances are this will solve your problem!
Jan 10, 2009 | Haier 20.5 cu. ft. / 580 liter Upright...
Haier HCM050EC Chest Freezer Logo
27 people viewed this question
Top Haier Freezers Experts
Victor Nwachukwu
Victor Nwachukwu
Charles T Nevin
Charles T Nevin
christian nielsen
Are you a Haier Freezer Expert? Answer questions, earn points and help others
