How can I set the time on my Akai iPod soundsystem im861 without the remote? How do I cancel the alarm scary noisy clock? Thanks in advance
2 Suggested Answers
SOURCE: alarm clock and time w/ clok smooth ipod system
According to the instructions that we received with our clock. You should be able to get the Instruction manual from prodinfo@gpx.com. It is also supposed to be under the support section of the website www.dpi-global.com but I couldn't find such a link.
However the "Operational Support" insert has the following:
Setting the clock
1. With the unit powered off, press and hold the "Clock/Display/Play/Pause Button" for at least 4 seconds.
2. While holding the "Clock/Display/Play/Pause Button", press the "Hour" and "Minute Buttons" to adjust the hour and minute on the time.
3. When the correct time is selected, release the "Clock/Display/Play/Pause Button" to set the clock
Setting the Alarms
1. With the unit powered off, press and hold the "AL1" or "AL2" Button for at least 4 seconds.
NOTE: An alarm icon will begin to flash on the LCD display.
2. While holding the "AL1" or "AL2" Button, press the "Hour" and "Minute Buttons" to adjust the hour and minute on the alarm time.
3. When the correct time is selected, release the "AL1" or "AL2" Button to set the clock.
4. Press the "AL1" or "AL2" Button consecutively to switch alarm one and alarm two between sounding to a buzzer, the currently set radio station, or a docked iPod.
Posted on Nov 30, 2008
How do i set the alarm on a t231
Setting The Alarm Time of T231
This Timex clock radio has dual alarms that can be set and used independently. The initial default alarm settings are 6:00 AM for Alarm 1 and 7:00 AM for Alarm 2. The procedure for
setting both alarms is the same.
NOTE: The alarm times can only be adjusted when the clock radio is in the OFF mode. If the radio is playing, press and hold the MODE/ALM RESET button until the display briefly shows
'OFF' and then reverts to the time.
1. Press and hold the ALM 1 button until the Alarm 1 time and the Alarm 1 Buzzer indicator begin flashing in the display, then release the button.
2. Press the HOUR / REV button to advance the display to the desired wake-up hour. Observe the PM indicator to confirm that you have set the wake-up hour correctly. If the PM indicator is
'On' the wake-up hour on the display is PM. If the PM indicator does not appear the wake-up hour on the display is AM.
3. Press the MIN / FF button to advance the display to the correct wake-up minute, and then release the button.
4. Press the ALM 1 button once more to confirm the wake-up time setting or after 10 seconds the display will stop flashing and the new wake-up time will be entered automatically. The
display will return to the correct time of day but the Buzzer indicator will remain 'on' in the display indicating that the Alarm 1 is now set to wake you to the buzzer.
5. To change the alarm mode from buzzer to radio, or to cancel the alarm, press the ALM 1 button again. Press the ALM 1 button once more to select the Radio alarm. Press the ALM 1 button once more to cancel the alarm function. The alarm indicators disappear and the display returns to the correct time.
6. Follow the same procedure to set the Alarm 2 wake-up time.
Sep 29, 2014 | Timex Audio Players & Recorders
I have an i-connex ipod docking station model 583258 with clock/alarm and radio but I have been unable to set the clock as I have mislaid the instructions. I am usually pretty good at working these things...
1. Fit the DC power and switch on the appliance by pressing the standby button 2. To set time, press CLOCk button to alternate between 12 and 24 hour format. 3. Press and hold CLOCK button until the set hour flashes on display 4. Adjust time using SKIP/SEARCH 5. Press CLOCK to set the time, same procedure for minute
To set alarm
1. Press AL SET 1/OFF 1 button, then press and hold the same button until the alarm time starts flashing 2. Press SKIP/SEARCH to to set time as above
Jan 17, 2011 | Audio Players & Recorders
How to program Akai VCR VS J700 without a remote control ( Lost it) Is this possible? Set the clock and record in advance etc.
I have had a look at the Curry's Partmaster website. The have a lot of Akai Remotes which seem to be priced around £14.99. You could take a look. If you still have the manual it might tell you the model number of the remote. For instance RC81024. The remotes on this site all have numbers like the above all starting with RC. If you find the remote number it will help chase down the correct remote.
Sep 21, 2010 | Akai VS-J700EA VHS VCR
Just purchased, didn't have any instructions in box. How do I set time and alarm? Thanks
Clock: With the radio off, press the Clock Set button, then the Memory button. The time will start blinking. Use the Hour and Minute buttons to set the alarm time. Press the memory button when you have set the correct time.
Alarm: With the radio off, press the Alarm Set button, then the Memory button. The alarm time will start blinking. Use the Hour and Minute buttons to set the alarm time. Press the memory button when you have set the correct time.
Sep 19, 2010 | Memorex MI4019BLK Alarm Clock Clock Radio...
Ihome--ih8,
I got the iH8 as a present everything works fine except for the ipod alarm. the unit will play my music when i press the play ipod button, and recognizes its plugged in, but when i set the ipod alarm, without taking out the ipod or anything, it doesnt go off with my music, it just buzzes. Idont think it is the ipod because i have updated the software on the ipod and have even tried 3 different ipods with the iH8. i have had the iH8 for about 2 weeks and set it nearly every day, and out of all those times it has gone off with my music only 3 times. How do i get it to work every time!??
Jul 08, 2010 | iHome Ih8 Dual Alarm Clock Radio For Ipod...
Ozaki imini (cute)
This is easy, hold down "mode" until the alarm time flashes, then press "mode" again, it will cycle through a menu, there is an "on" option to turn on the ipod at a certain time, you select "on" then press mode again, it will cycle to the next menu, set the time you want the ipod to turn on, press menu again, then you can select the "ipod off" time, I keep that option off as I want the ipod to stay on until I turn it off. Now you have set the ipod to turn on at whatever time you want. Turn off that terrible buzzer alarm. The confusing thing is the imini has to different alarm modes, not one alarm mode with two alarm sound options like most everything else.
Jan 26, 2009 | Audio Players & Recorders
Alarm clock and time w/ clok smooth ipod system
Setting the clock
Setting the Alarms
Nov 28, 2008 | Digital Products International Clok Smooth...
Alarm
SLIDE THE SWITCH TO TIME DO NOT PUT ON WAKE 1 OR WAKE 2 THOSE ARE LIKE TWO SEPEATE ALARM TIMES YOU COULD SET PUT ON CANCEL OR JUST TIME.
May 28, 2007 | GE RP4842 Clock Radio
122 people viewed this question
 Grubhead
Grubhead
