Question about Microsoft Windows XP Home Edition
Tiny print - dpi setting changed
I accidently changed the dpi setting in the control panel to 20% now all the words are a tiny blur! I'm trying to change it back, but I'm having to guess where to click on the screens. I think I'm on the ''settings'' tab in the display options of the control panel, but I'm not sure. The box has 5 tabs - 2 tabs on the top row, 3 tabs on the bottom row.
    Problem Solver:
  • 5 Answers
No need in putting the intsallation disc in. Just fallow these steps and you can change the text size and icon size. However you can only change one at a time.
  • Right click Desk top
  • Select the Appearance Tab
  • Click the Advance Button
  • Where it says item: Change to Icon and the numbers on the right allows you to change the size of the Icon.
  • Below that is Font: This allows you to change the font style and to the right allows you to change the size of the text.
  • Once changed to desired size click ok.
  • Then it takes you to the previous screen then click Apply
Posted on May 08, 2009
  • 3 Answers
You could try putting the installation disc back in that shud reset it back to factory settings
Posted on Apr 24, 2009
Why possible is 300 dpi printing images and text matter
What is DPI PPI and Why Do They Matter
To some extent, we're all photographers these days. With a camera on every phone and digital SLRs coming down in price, we've all got a trove of photos waiting to be shared. When it comes time to share online, print, or email our favorite images, many are unsure about how to set the image's resolution...
If you've found yourself in this spot, don't worry - dots per inch (shortened to DPI from here on out) is a concept that even confounds some professional graphic artists. Here's a primer DPI so you can stop worrying about technology and start sharing your photos.
Getting started
Digital photos are comprised of pixels, much like the individual boxes on a sheet of graph paper. DPI tells you how small those pixels will be when the image is printed. For example, "300 dots per inch" means that 300 pixels fit across each inch. If your photo is 600 pixels tall by 900 pixels wide, for example, it would come out at 2" x 3" inches if you were to print at 300 DPI. Keep in mind that most digital photos are several thousand pixels in either direction, but for the sake of simplicity, we'll use the more manageable 600 x 900 pixels.
Separating pixels from presentation
It's important to separate DPI from the raw pixel dimensions, and this is where even the pros slip up. DPI is not an indication of image quality or clarity. When you print that 600 x 900 pixel image at 300DPI, it'll likely look pretty sharp, because every inch is densely packed with pixels.
Now imagine printing that same image, with the same number of pixels, at a mere 30 DPI. As each inch would have only 30 pixels across, the density drops immensely and the image prints much larger: 20" by 30". What was once sharp now appears blurry, because each individual pixel is now ten times larger than before. By separating DPI from actual pixel count, we can understand that raising DPI doesn't magically improve a photo. DPI simply takes the same data (the original pixels) and alters how we'll view them.
Pin it It's all about context
Another factor is viewing distance. Just think of the eye chart at your doctor's office. If you're a bit nearsighted, the tiny letters at the bottom are illegible specks, while the letters at the top are easily discerned. In actuality, each tiny letter may be half an inch tall, but the distance makes them seem microscopic. Now consider our 600 by 900 pixel image. When we printed it at 30 DPI, the giant pixels made it look blurry. Were we to look at it across the doctor's office long hallway, however, it may look just as sharp as the 300 DPI print did in our hands. This illustrates how DPI is more about context than quality.
Pin it Pixels Per Inch
You'll notice I've been talking about DPI in relation to printing only. This is because while printers can produce a variety of DPI settings, a computer display's resolution is fixed - its pixel density is part of the physical hardware, and cannot be altered. When talking about displays instead of print, most use the term PPI, or "pixels per inch."
If you intend to put your 600 x 900 pixel image online, switching the resolution to 30, 300, or 3000 PPI is completely arbitrary, because the computer display can't change its density. As modern desktop displays usually have a PPI in the low 100s, the 600 x 900 pixel image will appear around 6" by 9" (mobile displays may be much higher). Of course, your web browser could display the image smaller if need be, but it will do so by averaging and eliminating pixels, not squeezing them to be physically smaller. This is why it's always important to keep your end goal in mind when working with images.
In summary:
• An image is defined by its pixel dimensions - # pixels tall by # pixels wide
• DPI/PPI determines the scale and pixel density at which image will be displayed
• What appears blurry from close up may look fine at a distance, so consider how an image will be seen
• Printers can produce a range of DPIs, while displays have fixed resolution
Whether you're a blogger dealing with an upload limit or are just trying to print a photo to hang on the wall, understanding DPI/PPI can go a long way. I hope these tips help you feel more in control of your images and how you share them with the world!
Oct 07, 2014 | Canon LASER SHOT LBP-2900 Printer
With what do you want to increase the DPI and fro what?
DPI is only used in printing. Papers mostly print in 72 DPI and glossy magazines, print there pictures in 300 DPI.
Once you shot a picture, with a camera, giving you a picture of 1200 x 800 pixels, you could print that picture at 300 DPI to a size of 4 x 3 inch. But even if you would print a 8 x 6, the picture could look good.
If you don't need to deliver pictures for print in magazines, it does not matter how many dpi you are using. Using .png, actually tries to compress pictures so they don't use a lot of space on the net (or on your drive. The info you lost by the compression, can't be regained, by trying to make a picture with more DPI.
I do try to explain in a few words something one graphic schools the need lots of lessons for. I tell you it can be done, making more DPI, from an existing picture, but it won't change anything to the sharpness or quality of the picture.
Jun 24, 2014 | Cameras
Printing problem
If your Printer is printing blurred text, you need to change your printer settings:
This can be done as follows:
1. First choose File and Print
2. Click Advanced at the bottom. Tick ON Print as Image and change from 600
dpi to 300 dpi
3. From the Print menu, choose Printer Properties
4. Then click on the tab Paper / Quality and choose Advanced
5. In Printer Features - Graphic Mode - choose Raster
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/printer-support/
Apr 09, 2013 | Canon LASER SHOT LBP-3000 Printer
Canon SD1300 setting for 300dpi size 2.75 x 2.975 how to set camera
It's not a camera setting.
DPI is "dots per inch". This only has meaning when the picture is output (usually printed, but also displayed on a screen). You can make two different-sized prints from the same photo file, and they will have different DPI settings even though they come from the same file.
A photo editing/printing program will let you control the DPI when you print a photo (and some will let you change the value when you save the file).
Mar 29, 2012 | Canon PowerShot Cameras
Mar 29, 2012 | Cameras
How do I adjust the darkness of the printing, it is currently set at 2 out of 4 darkness?
You will need to follow below process.
Print quality settings always affects on print resolution and toner usage.
to change print quality setting:
1. go to Start/settings/control panel/printers
2. then go to printer's properties.
3. go to paper/quality TAB. and select the setting that you want to use. you will get following options.
a) 1200 dpi: This setting uses ProRes 1200 to provide fine-line detail at 1200 x 1200 dpi.
b) 1200 dpi effective output quality: This setting uses ProRes 1200 to provide fine-line detail at 1200 x 1200 dpi.
c) 600 dpi: This setting provides 600 x 600 dpi output with Resolution Enhancement technology (REt) for improved text. (this is what you may need to get)
d) Economode: this settings use less toner of your printer. This is useful for mostly draft printings. You can turn this button on freely of other printing-quality settings.
Select the needed settings. Test a print.
And if it is perfect you wont be charge to give recommendation...lol
Aug 12, 2009 | Samsung SRP 350 Thermal Printer
HP F4280 won't print Excel documents. It will print Word documents.
Try opening your Excel 'Page Print Setup', and changing the 'Print Quality' setting from 1200 dpi to 600 dpi. It worked for me...
Dec 26, 2008 | HP DeskJet F4280 All In One Printer InkJet
HP2100 laserjet won't print inserted pix in Word 2007 doc
I ended up fixing this problem myself.
I needed to set the printing resolution in the HP printing dialog box to 1200 x 1200 dpi as the HP2100 can print at this resolution.
Select: Print/Properties/Advanced/Graphics. Then set the printquality to 1200 x 1200 dpi.
Rod Salter
Dec 15, 2008 | HP LaserJet 2100 Printer
Problem printing
The toner cartridge roller may be defective or there are outside light going inside the printer, causing the bands.
Mar 05, 2008 | HP LaserJet 1018 Printer
Resolution
You could check your DPI setting in the display, being a large monitor your DPI setting shoul be up around the 75 - 85 Hertz.
To access this
Control Panel --> Display --> Settings --> Advanced --> Monitor and then click the drop down box and see what the DPI is set to and keep trying the different options until it is clear.
Hope this helps.
Dec 04, 2007 | Gateway GT4010 (RBGT4010) PC Desktop
Microsoft Windows XP Home Edition Logo
336 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
