Question about Dremel Multi Max Kit
Multi-max circuit - Dremel Multi Max Kit
Dremel multi max stops when pressure is applyed
I took mine apart due to the same reason. Seems like the yoke that fits over the drive bearing is worn or bent to oversize so that it doesn't make a complete rotation. Hence, a very small or no cutting swath. You can replace the drive head for about 22 bucks plus shipping, (dremel parts) or go to Home Depot and get another one for 70 bucks plus tax. Or do as I did and go to harbor freight and get a Chicago Electric multi tool for about 30 bucks. It works fine. I'm not a professional and don't need a 200 dollar one.
May 07, 2014 | Dremel Multi Max Kit
Uh70600 hoover keeps shutting off
Most vacuums contain a high temperature circuit that will shut off the motor if it gets to hot. Thoroughly clean or replace all filters so the machine can "breathe" easier and stay cool.
Nov 20, 2013 | Hoover UH70600 WindTunnel Max Vacuum,...
Attatching dremel blade
You can't attach this to a Dremel Stylus. This blade is specifically for the Multi-Max tool. A link is below.
http://www.dremel.com/en-us/Tools/Pages/CategoryProducts.aspx?catid=2094
Oct 21, 2012 | Dremel Multi-Max MM462- 1 3/8 inch BiMetal...
My multi max stopped running in middle of my project
call 1300 307044 aus for replacement it may be falty
Jun 03, 2012 | Dremel Multi Max Kit
I have a sony VGN CR-220E which re upgrade to vista ultimate that i could not install the webcam driver ?
According to the spec. it should be OK. Don't forget to download the drivers from Sony.com otherwise it won't work correctly.
Learn more about the Sony VAIO VGN-CR220E/P Model BrandSONY SeriesVAIO CR Series ModelVGN-CR220E/P General ColorCosmopolitan Operating SystemWindows Vista Home Premium CPU TypeIntel Core 2 Duo T7250 2.0G Screen14.1" WXGA Memory Size2GB DDR2 Hard Disk200GB Optical DriveDVD Super Multi Graphics CardIntel GMA X3100 Video MemoryShared memory CommunicationModem, LAN and WLAN Card slot1 x ExpressCard /34 Slot Dimensions13.2" x 9.8" x 1.25-1.67" Weight5.5 lbs. TechIntel Centrino Duo Mobile Technology CPU CPU TypeIntel Core 2 Duo CPU SpeedT7250(2.00GHz) CPU FSB800MHz CPU L2 Cache2MB Chipset ChipsetIntel GM965 Display Screen Size14.1" Wide Screen SupportYes Display TypeWide XGA Resolution1280 x 800 LCD FeaturesXBRITE-ECO technology Operating Systems Operating SystemWindows Vista Home Premium Graphics GPU/VPUIntel GMA X3100 Video MemoryShared system memory Graphic TypeIntegrated Card Hard Drive HDD200GB HDD RPM4200rpm HDD InterfaceSATA Memory Memory2GB Memory SpeedDDR2 667 Memory Spec1GB x 2 Max Memory Supported4GB Optical Drive Optical Drive TypeDVD Super Multi Optical Drive InterfaceIntegrated Optical Drive SpecDVD+R DL Write: 4x max
DVD+R Write: 8x max
DVD+RW Write: 8x max
DVD-R Write: 8x max
DVD-RW Write: 6x max
CD-R Write: 24x max
CD-RW Write: 16x max
DVD±RW: Yes (DVD±R DL/DVD±RW/DVD-RAM)
CD Read: 24x max
DVD Read: 8x max
DVD-RAM Write: 5x max
DVD-R DL Write: 4x max
DVD-RAM Read: 5x max Communications ModemIntegrated V92/V.90 Modem (RJ-11) LAN10/100Mbps WLANIntel PRO/Wireless 4965AGN Network Connection (802.11a/b/g/n)
Jan 01, 2011 | Sony VAIO VGN-CR220E/P Notebook
My dremel is always in max speed
The most likely culprit is the speed potentiometer. Poor design causes vibrations on the printed circuit board. This induces metal fatigue in the potentiometer terminations at the board. Eventually one or more terminals snap off. If you are a whizz with a soldering iron you could remove the pot and then solder a new wire/s onto it and fasten it back onto the board?
Dec 09, 2010 | Dremel Multi Max Kit
Can I buy a new cord for my dremmel multi max? my dog chewed it up and can I order it?
If there is one ck with (ereplacementparts.com) you will need your mod. # good luck
Nov 28, 2010 | Dremel Multi Max Kit
I have a dremel multi-max. It was a display. I
try tool parts direct, they list dremmel.
Apr 19, 2010 | Dremel Multi Max Kit
Need york mega max 3001 instruction maunal
I need an exercise chart for my york mega max 3001 multi gym.
I need it to see what exercises on that gym affects which muscles.
Where can I get one of these?
Neil
Aug 23, 2009 | Exercise & Fitness
Dremel Multi Max Kit Logo
48 people viewed this question
Top Dremel Saws Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ka4iup
ka4iup
Are you a Dremel Saw Expert? Answer questions, earn points and help others
