Question about ASUS Eee 4G Notebook
Htc diamond wifi problem
I am using htc diamond when im using wifi on my house i can connect and it show's that i am connected on my htc but the problem is i cant still surf to the net using opera or I.E but my other device was working fine like laptop and other cellphone..i tried to use my htc on wifi spot and its working fine..pls help me with this..im using wrtg54usb pci its not a totaly router but it can give access point to other device..
  • Anonymous Mar 22, 2014
    Im connected to the Wifi and have access
I have got an htc touch diamond phone and i want to use internet on it and also want to connect to my pc but i dont have a software/hardware or cd. i have installed active sync. on my pc but the device...
if you have installed active sysnc then the device should connect. If it doesnt i would check in my computer to see if it is showing as connecte. Also when you connect the usb lead to the phone it should pop up a selection on the phone to how you want to connect make sure you choose active sync. the screen only appears for a few seconds then it will connect with the last selected option
Mar 13, 2011 | HTC Touch Diamond Smartphone
Not getting picture messages and no internet
Do you have the data plan activated on your SIM with ATnT?
Oct 02, 2009 | HTC TYTN GSM Phone
Phone showing communication error while setting up gmail
I believe you should firstly configurate your wifi connection with the wireless router, and after testing your connection (using your internet explorer for example) you will not receive any connection problems while configuring you gmail account.
Aug 29, 2009 | HTC Touch Diamond Smartphone
Cannot connect htc diamond with pc via usb
get the genuine cable form the vendor. Most llikely the data cable is not working. USE GENUIENE DATA CABLES
Aug 04, 2009 | HTC Touch Diamond Smartphone
Could not connect with wi fi
Thats a pretty awkward error message your getting... You should talk to your carrier about the gprs services thing, but you can also try 'get settings' - from your carrier. To do this, go to start>settings>phone>services tab. Then select network service and tap get settings and select standard. If it is on home only, that might be your problem, even though I have never tried home only.
Feb 23, 2009 | HTC Touch Viva Cell Phone
Wifi Dosn`t Turn on
Try a soft reset, its under the back cover.
If that doesn't help, do a hard reset, press the power button, volume down button, and the ok/enter button. At the same time press the reset button in the back. Keep holding all keys down (execpt reset) until you get a message on your screen giving you further instructions.
If you installed 'modification' programs that add a function/feature that changes windows mobile settings, or your data connection, etc. Try uninstalling it, and don't download it again unless you know it full supports your diamond (there and different versions of the diamond as well to make a note of)
Jan 18, 2009 | HTC Touch Diamond Smartphone
Htc mogul
depending on what company it was/is on they probably locked out wifi, im having the same issue, and im still searching for the answer
Oct 25, 2008 | HTC PPC-6800 Smartphone
How to unlock Htc Touch Diamond !!
follow my shared experience to ulock HTC Touch Diamond. Was locked with Orange operator in UK
http://internetbisnisonline.co.cc
Aug 08, 2008 | HTC P3600 Pocket PC
Wifi
go to your wireless settings, where you can see the connections that your phone can find, hold your stylus on the connection and remove the settings. after that set up a new connection. problem should be solved
May 24, 2008 | HTC Touch P3450 Smartphone
ASUS Eee 4G Notebook Logo
378 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
