Question about Majiastic Computer Microphone Pass-through Emulator
Microphone pass-through emulator 1.5.1 crack - Majiastic Computer Microphone Pass-through Emulator
How do you set the switches on AT3525 Mike?
The AT3525 handles very high sound pressure
levels with ease, accepting as high as
146 dB SPL before producing 1% T.H.D. A
switchable 10 dB (nominal) pad is built-in,
increasing its capabilities to 156 dB SPL.
An integral 80 Hz hi-pass filter provides easy
switching from a flat frequency response to a
low-end roll-off. The hi-pass position reduces
the microphone's sensitivity to popping in
close vocal use. It also reduces the pickup of
low-frequency ambient noise (such as traffic,
air-handling systems, etc.), room reverberation
and mechanically-coupled vibrations.
Jun 20, 2014 | Audio Technica Audio Players & Recorders
Serial numbers are not provided through this website. This service is intended primarily for support of issues being faced with devices.
Oct 14, 2013 | Cell Phones
Switsh on mic dose not work can i by pass this
no If you call shure service at 1-800-516-2525 you can order the part
Dec 30, 2009 | Shure SLX24/58 Wireless Microphone System...
I'm playing The Phantom Hourglass on a emulator
f you dont have a microphone just use windows movie maker
open the windows movie maker
click tools > narrate timeline or just click the microphone icon below
then
click show more options and change your audio input source into a mono mix or stereo mix
Oct 25, 2009 | Nintendo The Legend of Zelda: Phantom...
Sims2 Bon Voyage Disc 1- "Backup" problem?
If it doesn't recognise it there probably is a scratch or something like that on it, or you have disk emulator softwarelike Daemon Tools running, which causes games to block. Try closing the emulator software. If you don't have any running, you could try using a crack for the game. A crack is a copy of the game launcher that does not look for the CD when it starts. GO to one of tese sites: gf.wiretarget.com www.gamecopyworld.com and download a "fixed exe" for your version of the game. It is advisable to update your game to the latest version, and then download the late version crack. To open the file the crack is in, you will need a program called 7zip. jJust google it and download it, it's free and perfectly safe. Once you have the crack, overwrite the file of the same name in your Sims folder, and the game should run properly from now. I hope this helps, Yannick.
Jun 10, 2009 | Electronic Arts The Sims 2: Bon Voyage
I want to download playstation 1 software free
An emulator you mean? An emulator is software that 'emulates' hardware.
Here is a website for a popular PS1 emulator.
http://www.epsxe.com/
Enjoy :)
May 03, 2009 | Video Game Consoles & Games
I cannot open ports TCP/UDP for eMule using router 2Wire Infinitu
You need to portforward your router to accept emules port number/numbers. Go to portforward.com. look up your router and follow the instructions. It's pretty easy.
Nov 28, 2008 | Xincom XC-DPG602 Router (XCDPG602)
Psp games on pc
Find yourself a suitable PSP homebrew program for your PC
Jul 17, 2008 | Sony PlayStation 2 (PS2) Console
Emule Show Low ID on Client Computer
Dear sir/madam,
You can update the servers it may be become fast. Go this site and add all servers (add to emule) click this link, they automatically update the servers.
http://ed2k.2x4u.de/index.html
OR try this
First of all you need to know the IP of the computer that you use with Emule.
Then go to the router configuration:
- Choose "NAT Settings", and "Virtual Server".
1- If it isn't enabled, enable the "Virtual Server".
2- In "Well-Known Applications" choose de option "User defined".
3- Now the crucial part. Under the Virtual Server List, in the "Local IP" you place the IP of your computer (on the example, 192.168.1.2, i.e. my emule computer ip), "Port Range" put 4662 and Protocol TCP. "Protocol nº." stays blank, and in the "description" you can put Emule Rule Nº1.
4- Click ADD, to add the rule to the table.
- Again you make the same passes from 3 to add the second rule:
3- In the "Port Range" you place 4672 instead 4662, and on Protocol you place UDP instead TCP. On "Description" you can place Emule Rule Nº2.
4- Click ADD.
5- After making the 2 rules, click Finish, and on the next screen click on Save&Restart button.
In the next time you start Emule, you can acess to the servers without Low ID.
Don't forget to rate the solution
thanks
Mar 23, 2008 | Computers & Internet
Computers & Internet Logo
55 people viewed this question
Top Majiastic Computer Computers & Internet Experts
David Payne
David Payne
Are you a Majiastic Computer Computer and Internet Expert? Answer questions, earn points and help others
