Question about Canon ImageRUNNER 3570 Copier/Printer
Always paper jam
Jam code(0108),
jam code(0107),
jam code(0106),
jam code(0105).
  • 109 Answers
There is so many reason for that
where the jam when u try to copy 1 copy
Posted on Mar 21, 2010
The machine always detect a paper jam without a paper?
Is there a small piece of paper over the paper jam sensor?
Feb 01, 2015 | Office Equipment & Supplies
My samsung scx-4623f always "paper jam in exit area" every time i print even though i always put out the jammed paper in the exit area.
While Samsung SCX-4623f printer always "paper jam in exit area" you get paper checks or trigger sensor paper cup
cong ty bao ve support
good luck
Jul 07, 2014 | Samsung SCX4623F Laser All-in-One Printer
Can not copy two sided.paper always jam
Check for some obstruction in the paper path where the paper stops. There can also be paper cuts in some of the sensor arms that may be giving hesitation delys csusing the jams. Jam codes in service mode will also help isolate the problem to a more specific area.
Jun 17, 2011 | Canon NP 6050 Copier
CLP-310. paper jammed and it can't be removed. Can the roller be removed to get the paper out? that's the only way the jammed paper is going to come out.
I would recommend that you take it to a authorized printer repair shop and have them remove the paper. Printers have sensors that if not properly installed upon servicing the machine it will give error codes and stop the unit from printing.
When I have paper jams on my printers I always pull the paper from the discharge side to prvent any sensors being bent or broken. Good Luck!!!
Sep 21, 2010 | Samsung CLP 315 Laser Printer
RZ 220 Risograph error code A-16-525 after paper jam indication. No jam was present.
The master is stucked on the print drum,open print drum remove master and try again.
Let me know for futher help.
Jan 26, 2009 | Riso RZ220 Duplicator
Paper jam and error code e012 on ir6000
You could very well have a worn registration clutch, it's behind the the gray roller that sits to the right under the drum. Good luck! If that doesn't do the trick you may have to change your transfer settings in service mode
Oct 14, 2008 | Office Equipment & Supplies
Paper jam
My KX-FT73CX Fax always Paper jam when turn the machine
Sep 02, 2008 | Panasonic KX-FL501 Plain Paper Laser Fax
Always paper jam.
Check to see if something isn't blocking the paper path.
You could try cleaning the feed rollers as well.
Jun 12, 2008 | HP LaserJet 2420 Printer
Epson Aculaser C900 - Paper Jam Notice, but no Jam?
Step1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step
Turn off the printer.
Step
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Step
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
Step
5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step
6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step
7
If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
Step
8
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
Step
9
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Jan 14, 2008 | Epson AcuLaser C900 Printer
684 people viewed this question
old marine
old marine
