Question about Nikon D80 Digital Camera with 18-135mm Lens
Nikon D80 black spot center of photos
I have a Nikon D80 with a 18-55 mm and 55-200 lenses. Every picture has black spot in the middle of each photo. I have tried changing the lenses and the filters but the spot remains the same position. Can you help me or do i need to send it in for reapir? Could it be dust behind the shutter? If it is dust is there a way to manualy open the shutter and clean it?
    New Friend:
For D80, go to setup menu, select Mirror lock-up so we can see and access the sensor!
Posted on Jan 07, 2010
  • 101 Answers
Yes you can.
put the camera in manual (M)
and from the settings you can have the option CLEAN SENSOR..
use it to clean the Sensor !!
and then turn the cam of and then back on it should do the job !!
Hope it worked !!
Posted on Mar 10, 2008
  • paul pulimoottil
    paul pulimoottil Mar 10, 2008
    Better give it for service !! in a professional shop !
  • 34 Answers
There is dust on the imaging sensor, and it will need to be cleaned off. A local repair shop can take care of this, or search photography forums for proper technique. Note, improper cleaning can damage the sensor, so use caution.
Posted on Sep 26, 2007
SOURCE:
I have an 18 - 200 mm sigma lens. problems are: 1. its lock does not work. the lens slides down to lower zoom magnification one raised to a diagonal position. 2. when fully extended, the thrid tube...
Send it in for repair
Sigma Canada
www.sigmacanada.ca/
SIGMA ART 24-35MM F2 DG HSM LENS. Lens details >> · More photos with this lens >>. SIGMA 24-70MM F2.8 IF EX DG HSM. Lens details >> · More photos ...
Lenses ' Sigma Corporation of America
https://www.sigmaphoto.com/lenses
Browse Sigma lenses including over 45 camera lenses available for most major mounts including Sigma, Canon, Nikon, Sony, Pentax and Micro Four Thirds ...‎Wide Angle Lenses · ‎Telephoto Lenses · ‎View All Lenses ' Sigma ... · ‎Art Lenses
Jul 27, 2017 | Sigma AF 28-200 Lens
Sometimes photos are overexposed using A or P mode on my Nikon D80 with 18-200 mm lens. I remove the lens, then re-attach it and all is fine. What is happening? Poor contacts?
Contacts should not have anything to do with the metering. That is done in the camera itself and not the lens. If a photo comes out overexposed, which is normal when using P or A mode, as metering isn't perfect, use the exposure compensation (+/- menu or button) to reduce the exposure as much as you feel is necessary. Exposure can be subjective so you should trust yourself more than the camera.
Jul 20, 2010 | Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR...
Black spot on the picture
Hi cutesaying, if it is on all you photos in the same location it is one of two things, worse case is a bad sensor location (unlikely), most likely is there is crud on the sensor. You can perform a sensor cleaning if you fee up to it with specialized tools. Search the web for sensor cleaners there are many. Changing our lens is the most likely way dirt, and the like, gets on the camera sensor.
Jun 18, 2010 | Nikon D80 Digital Camera with 18-135mm...
I just purchased the Zeikos fisheye lense for my 50mm Nikkor lens and when I attach it, it doesn' take fisheye photos - just regular with some distortion around the edges... am I using this incorrectly?...
The 50 mm lens is a full frame lens, and the D80 is a DX camera. This means that the 50mm lens puts an image out that is bigger than what the D80 can "see". The good part of this is that the D80 (and most of the other Nikon DSLR's) use only the image from the center part of an older lens. The bad part is that if you put the fisheye filter on it, the fisheye effect that is mostly seen at the edges of the lens doesn't show up on the D80 sensor. If you could put the fisheye filter on a DX lens, it would give you the full effect.
Sep 24, 2009 | Nikon D80 Digital Camera with 18-135mm...
Can i use a Quantray AF LD 70-300 mm lens with my nikon d80? Thanks.
That depends. If the Quantaray lens has a Nikon mount, then yes, no problem, it'll work on the D80. If it has a different mount, then it won't fit onto the D80.
Sep 02, 2009 | Nikon Cameras
A black spot keeps appearing in my photos nikon D80
It seems that there is some dust particle on the sensor. Try cleaning the sensor as per the instructions in the manual and then check. In case the spot still appears, then the CMOS sensor might be damaged / burned out and you will need to replace it.
Jul 19, 2009 | Nikon D80 Digital Camera
Dark photos
  • Be sure camera is set to the Green auto, not the A (A= aperture priority)
  • Be sure your white balance is on auto.
  • Be sure your EV is set to 0
  • Be sure your lens is on M/A, not M
  • Check the internal meter. See if it is showing a middle of the graph reading when the camera is on auto. If it is and you still get dark pix, might be time for Nikon repair.
Mar 12, 2009 | Nikon D80 Digital Camera
1 round fog spot on photos
mm i have a canon powershot s5 is and i dropped it in the mall one day then turned it on and had this little black squiggly on every photo, and i cleaned it and everything and it wouldnt come off, so i thought i would have to have it professionally cleaned, (which [by the way] i think you should try) but then this girl accidently dropped it again and i turned it on and the squiggly disappeared so i dont know if that helps you or not but you should try having it professionally cleaned, it might cost a bit though, good luck, cheers.
Nov 24, 2007 | Panasonic Lumix DMC-FZ5 Digital Camera
Nikon D80 Digital Camera with 18-135mm Lens Logo
1,026 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
