Question about Proscan 26LB30QD 26 in. LCD HDTV
Get no response from audio out to surround sound sytem my e-mail is jerryhusbands@yahoo.com
    President:
  • 814 Answers
You need to give a lot more detail about you set-up. What type of surround sound Brand name and model number are you using. What type of connections are you using with the coaxial sound output to the surround sound system.Have you tested this coaxial output on another speaker source to make sure that it is not putting out sound. You can do this with a coaxial to rca adapter and use one of the receivers normal sound inputs to see if you are getting any sound from the output of the television.You also must make sure you are using the remote controls of the two components correctly. Check to make sure the volume is adjusted to a hearing level on both remotes.Check all the cables you are using and make sure they are working correctly. If after doing the testing you find that the television is not putting out sound. You will need to contact PROSCAN for customer support help.You can use their website at www.oncorpus.com. Go to the customer support section and ask for help with your problem. You can also call them at 1-888-977-6722. I hope this has helped you with your problem.
Posted on May 21, 2009
No audio output in rear or surround
Assuming you have the sound configuration in the correct mode, then the chip circuit responsible for funneling sound to the rear and surround speakers is defective.
Jan 19, 2015 | Audio Players & Recorders
How i can connect a subwoofer to my Optimus Stav 3350,
Use a set of Bose speakers. The wiring goes from the speaker terminals on the amplifier to the sub. the right and left speakers connect to the sub.
Dec 29, 2011 | Optimus STAV-3350 Receiver
I need to connect a surround sytem to my tv but cannot find an audio out on it
Depending on the TV you have and the surround sound system you can use the following:
An optical out cable.
Headphone jack to headphone jack (a cable with a 2.5mm headphone jack on both ends) you then plug this into the headphone jack in the TV and the other end into the audio in jack in your surround sound system.
You can also use a standard scart lead to plug into your TV and surround sound system.
May 03, 2011 | Televison & Video
I have yahoo id i wand configure to my outlook express i am getting this error There was a problem logging onto your mail server. Your Password was rejected. Account: 'pop.mail.yahoo.com', Server:...
There was a problem logging onto your mail server. Your Password was rejected. Account: 'pop.mail.yahoo.com', Server: 'pop.mail.yahoo.com', Protocol: POP3, Server Response: '-ERR [SYS/PERM] pop not allowed for user.', Port: 995, Secure(SSL): Yes, Server Error: 0x800CCC90, Error Number: 0x800CCC92
make sure your password is correct because this error description states that your password is incorrect
Jul 08, 2009 | Microsoft Outlook Express
How do i get sound through my tv once the camcorder is connected to it,
Are you connecting the audio RCA cables to the camera and TV and selecting the correct audio input ?
I had a similar problem with missing audio. In my case I am using a surround sound audio system and had to connect the audio cables directly to the Suround sytem and change the audio input.
Jul 07, 2009 | Canon FS100 Flash Media Camcorder
System echos when dvd is in. When I mute the Bose sytem I can hear the TV sound without the echo.
The echo you hear is the audio delay between your TV speakers and Bose speakers. Muting (or lowering the volume) on the TV will eliminate the echo. Some TVs have a setting to turn of TV speakers entirely, allowing you to listen to your TVs audio strictly through your Bose system.
Dec 20, 2008 | Bose 3·2·1 II System
The surround sytem
bad amp this riddled with faults bad design dont waste your money on this dump it i repaired loads of these this model is bad news and un reliable
Sep 01, 2008 | Technics SA-DX940
Need hook up diagram for Samsung HDTV using HDMI with Cable box and Samsung 5.1 Surround Theater System
you can run a fiber optic cable out of the tv into the surround system if the sytem has a fiber optic input, or your tv should at least have red and white rca cables for audio out, then you just pick any input on the surround sound and any audio from dvd players ect thats hooked up to the tv will be sent through that one input on the surround sound. The only thing you'll have to do is turn the volume up or down on your sound system.
Jul 09, 2008 | Televison & Video
Surround mixer
Download a software called "SRS Audio Sandbox".Install it and set it as the default device.It will give u 5.1 channel sound and is well supported by Creative Sound Blaster 5.1.It is a demo version.U need a crack to register it.I am using the same and it is working absolutely fine.If u need the brack then mail me at : vikki2005310@rediffmail.com.
For more solutions to any computer related problems mail me.I will be there to help u.
Bye
Vikas
Oct 11, 2007 | Creative Labs Sound Blaster 5.1 Audio...
Proscan 26LB30QD 26 in. LCD HDTV Logo
133 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
